boxkita Posted May 8, 2022 Share Posted May 8, 2022 You going to make a down payment on a house with that cat? or have prices come down a bit? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Febreze Mee Posted May 8, 2022 Share Posted May 8, 2022 I was actually thinking about buying $XXX.XX of gummy worms with it, just to flex at the movies tonight! MILKRUNÂ - Click Here Link to comment Share on other sites More sharing options...
awfulwaffle Posted May 8, 2022 Share Posted May 8, 2022 bathtub full of sour patch kids is the answer Link to comment Share on other sites More sharing options...
Febreze Mee Posted May 9, 2022 Share Posted May 9, 2022 Bathtub full of sour patch kids, in the house I put a down payment on, after the running around the movies with hundreds of dollars worth of gummy worms, all of which will be paid for by this catalytic converter I sell MILKRUNÂ - Click Here Link to comment Share on other sites More sharing options...
ohno06gt Posted May 9, 2022 Share Posted May 9, 2022 Got a big whiff of oil burning after a drive today. Went poking around and realized the banjo bolt on the rear passenger head is leaking. I removed the screen and replaced washers about 4k miles ago. Â Is it possible to snug up that bolt without removing turbo? Not sure if there is access from the bottom, going to check it out tomorrow. Link to comment Share on other sites More sharing options...
LegacyGT007 Posted May 9, 2022 Share Posted May 9, 2022 Got a big whiff of oil burning after a drive today. Went poking around and realized the banjo bolt on the rear passenger head is leaking. I removed the screen and replaced washers about 4k miles ago.  Is it possible to snug up that bolt without removing turbo? Not sure if there is access from the bottom, going to check it out tomorrow.  Yes you can get to it without pulling the turbo. I just went through this recently. You would have to remove your intercooler and heat shield around the turbo. After that there is a small bracket from the turbo to the block that you can remove. Then you should have the clearance to get to the bolt. A 17mm wrench should fit in there without too much interference. I used a ratcheting one because it's easier. It took me several times to snug it down enough without leaking. Make sure you have new copper washers. Link to comment Share on other sites More sharing options...
awfulwaffle Posted May 9, 2022 Share Posted May 9, 2022 Bathtub full of sour patch kids, in the house I put a down payment on, after the running around the movies with hundreds of dollars worth of gummy worms, all of which will be paid for by this catalytic converter I sell millennial paradise Link to comment Share on other sites More sharing options...
Max Capacity Posted May 9, 2022 Share Posted May 9, 2022 Yes you can get to it without pulling the turbo. I just went through this recently. You would have to remove your intercooler and heat shield around the turbo. After that there is a small bracket from the turbo to the block that you can remove. Then you should have the clearance to get to the bolt. A 17mm wrench should fit in there without too much interference. I used a ratcheting one because it's easier. It took me several times to snug it down enough without leaking. Make sure you have new copper washers.  Harbor Fright will have short/stubby ratching box end wrenches, that will make it easier. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
SubOperator Posted May 10, 2022 Share Posted May 10, 2022 Still have the unused gift card from HB with money from returning those 6 ton stands. May check the store out but it's dangerous trip without a plan. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
BoozeRS05 Posted May 11, 2022 Share Posted May 11, 2022 Finally replaced my leaking invidia UP today, installed an OEM unit I had sitting around. Was able to pull off that project in about 2.5hrs start to finish, which I’m pretty damn proud of and didn’t cut or hurt myself. Still only was able to manage 14.5lbs of boost though, but logs look clean for the most part. Also bought an oring kit from HF to replace various shrunken orings around the car - MAF sensor and steering pump, dipstick. Is there a comprehensive engine hose kit for our cars? Samco used to make something I swear or misimoto? EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Febreze Mee Posted May 11, 2022 Share Posted May 11, 2022 I found this on Rallysportdirect.com And in the case you hadn't already come across this thread, here it is: https://legacygt.com/forums/showthread.php/question-there-complete-silicone-hose-set-readily-availablei-275834p2.html MILKRUN - Click Here Link to comment Share on other sites More sharing options...
m sprank Posted May 11, 2022 Share Posted May 11, 2022 I found this on Rallysportdirect.com And in the case you hadn't already come across this thread, here it is: https://legacygt.com/forums/showthread.php/question-there-complete-silicone-hose-set-readily-availablei-275834p2.html    Lines for the coolant reservoir feeding the turbo do not fit. Cant remember if any other are incorrect of the top of my head. I had Venair custom make the kits for the LGT. I tried to sell them here on the site. It was a bust. Thats why no other manufactures ever pulled the trigger.    Funny how I see threads now asking for parts I custom made years back and threw in the trash because they did not sell. Yet, people expect larger brands to make them now. LOL. :lol: Link to comment Share on other sites More sharing options...
boxkita Posted May 11, 2022 Share Posted May 11, 2022 Lines for the coolant reservoir feeding the turbo do not fit. Cant remember if any other are incorrect of the top of my head. I had Venair custom make the kits for the LGT. I tried to sell them here on the site. It was a bust. Thats why no other manufactures ever pulled the trigger. Â Â Â Funny how I see threads now asking for parts I custom made years back and threw in the trash because they did not sell. Yet, people expect larger brands to make them now. LOL. :lol:Â wish I had bought more of the full kits. Sitting on enough kits to finish my cars but not enough to do more. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 11, 2022 Share Posted May 11, 2022 I have just pulled the first Free Range Racing kit off the car and for the most part it lasted. The only hoses that were weird was the head recirculation and PCV hoses were sweating oil? I have another kit in stock but may not use it. Likely going back in with OEM and sleeve clamps this time. Link to comment Share on other sites More sharing options...
NORULZleggy Posted May 11, 2022 Share Posted May 11, 2022 Lines for the coolant reservoir feeding the turbo do not fit. Cant remember if any other are incorrect of the top of my head. I had Venair custom make the kits for the LGT. I tried to sell them here on the site. It was a bust. Thats why no other manufactures ever pulled the trigger. Â Â Â Funny how I see threads now asking for parts I custom made years back and threw in the trash because they did not sell. Yet, people expect larger brands to make them now. LOL. :lol:Â This is because people want to do and buy stuff on the cheap. What I have seen over my years in the car world is people with really no funds by these cars and want to make them fast on an ebay budget. That's fine and all, but we see what happens down the road. Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 11, 2022 Share Posted May 11, 2022 Venair TB hose picked up from Infamous is still in good shape. Sad I missed the kits. OEM FTW at this point. Link to comment Share on other sites More sharing options...
rhino6303 Posted May 11, 2022 Share Posted May 11, 2022 I have just pulled the first Free Range Racing kit off the car and for the most part it lasted. The only hoses that were weird was the head recirculation and PCV hoses were sweating oil? I have another kit in stock but may not use it. Likely going back in with OEM and sleeve clamps this time.My venair head breather hoses sweat too. It's normal for silicone hoses with oil vapor to sweat. Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 11, 2022 Share Posted May 11, 2022 Good to know. Very strange, likely exacerbated by my #4 ringland failure. Bummer is the mess left behind on top of the block. It was clean. Came out oily dirty mess. All others with coolant or oil were in pretty good shape. Only only that tore while I was tearing the motor down was at the return to the top coolant tank. Link to comment Share on other sites More sharing options...
Haze Posted May 11, 2022 Share Posted May 11, 2022 Tore the engine down. Bad vertical scoring in #4 at the 12:00 position and #2 has the same to a lesser extent. Pistons look OK from the top, gonna have to split the block to see if I can find what went south and salvage this crank. Link to comment Share on other sites More sharing options...
Scottydunno Posted May 11, 2022 Share Posted May 11, 2022 Welp not I, but a professional.... I had a my windshield replaced. Over spring break for my son, we road tripped down to Georgia then back up to Taxachusetts with another visit in Virginia. Anyways, while driving through SC I heard a loud smack on the windshield. First thought was "that's gonna be bad hit" welp it sure was... the final length of the crack was almost halfway across the windshield. Original windshield finally got replaced and WOW! It's amazing the difference... LOL Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 12, 2022 Share Posted May 12, 2022 Tore the engine down. Bad vertical scoring in #4 at the 12:00 position and #2 has the same to a lesser extent. Pistons look OK from the top, gonna have to split the block to see if I can find what went south and salvage this crank. Same. But I had hard ringland failure on #4. Link to comment Share on other sites More sharing options...
Haze Posted May 12, 2022 Share Posted May 12, 2022 Same. But I had hard ringland failure on #4. Got my block apart and pulled the pistons. No obvious ringland failures. Unfortunately, the crank and almost everything else inside this engine is too worn to reuse. My plan to put this car back together on the cheap with parts I had laying around might be dead. Link to comment Share on other sites More sharing options...
JMack Posted May 12, 2022 Share Posted May 12, 2022 not today, but last night (super late). Replaced RH front LCA (B-Spec style aluminum with poly bushings), inner and outer tie rods, hub/bearing. Found out that my car (no real list of what has been done) has Epic Engineering Springs on all 4 corners (thanks everyone who has tried to help with that) with Koni Inserts, solid adjustable Front Sway bar with solid end links, bar stops, everything... Someone has put some money into it. Oh, it also had whiteline tie rod ends and LCA to knuckle ball joint (ALK, both of which were pretty well shot). Link to comment Share on other sites More sharing options...
NORULZleggy Posted May 12, 2022 Share Posted May 12, 2022 Got my block apart and pulled the pistons. No obvious ringland failures. Unfortunately, the crank and almost everything else inside this engine is too worn to reuse. My plan to put this car back together on the cheap with parts I had laying around might be dead. That isn't going to last long , Cheap and Subaru work with only 2.5i cars. Link to comment Share on other sites More sharing options...
awfulwaffle Posted May 12, 2022 Share Posted May 12, 2022 I am willing to donate some parts from my garbage pile if we're making a turbo franken-EJ, for science Link to comment Share on other sites More sharing options...
