cww516 Posted January 23, 2019 Share Posted January 23, 2019 https://legacygt.com/forums/showthread.php/thegiraffe-2010-legacy-gt-adventure-thread-268385.html Assuming that's what you're thinking of, it looks like they only did knuckles and struts, doesn't appear that anything inboard of that was changed. Link to comment Share on other sites More sharing options...
x1conroe Posted January 23, 2019 Share Posted January 23, 2019 JDM alternator cover Link to comment Share on other sites More sharing options...
ArmyVetMP Posted January 27, 2019 Share Posted January 27, 2019 Just had the Timing Belt replaced for the 2nd time on my 2010 Legacy. Had an Oil Change and Takata Airbag Recall done at the same time. Car is 218,000 miles strong! Link to comment Share on other sites More sharing options...
Zee199969 Posted January 29, 2019 Share Posted January 29, 2019 Did a little weight addition yesterday. Because of the way I have the license plate relocate mount installed, it is unevenly weighted and tilts to one side if I hit a decent bump/dip. Found some archery counterbalance weights that I'm hoping will correct this. Started off with 4oz My "Build" Link to comment Share on other sites More sharing options...
eckseleven Posted January 29, 2019 Share Posted January 29, 2019 Hadn't done some good cold weather pulls while watching my boost in a while so tried yesterday. It was around 20F. Highest I saw was 19.5 and it is tuned for 18. So not too bad considering the temps and the Nameless DP. The concerning thing however is my car seems to have a bit of a stumble above 4k RPM and WOT. At first I thought my tires were trying to spin (roads did have some slick spots) and traction control was cutting power. I disabled it though, and still got the same behavior. Naturally I suspect a coil pack but there was no CEL. Shouldn't I see a CEL if it was a misfire? Car runs perfect otherwise. Link to comment Share on other sites More sharing options...
FLlegacy Posted January 29, 2019 Share Posted January 29, 2019 That could the fuel stumble known to be an issue on the stock system. Link to comment Share on other sites More sharing options...
ripstik Posted January 29, 2019 Share Posted January 29, 2019 Hadn't done some good cold weather pulls while watching my boost in a while so tried yesterday. It was around 20F. Highest I saw was 19.5 and it is tuned for 18. So not too bad considering the temps and the Nameless DP. The concerning thing however is my car seems to have a bit of a stumble above 4k RPM and WOT. At first I thought my tires were trying to spin (roads did have some slick spots) and traction control was cutting power. I disabled it though, and still got the same behavior. Naturally I suspect a coil pack but there was no CEL. Shouldn't I see a CEL if it was a misfire? Car runs perfect otherwise. its surprisingly hard to get a CEL from a coilpack that is on its way out. it basically needs to misfire 10 times in the span of a few seconds. you can track your misfires for each cylinder with the AP, the are marked roughness cyl 1,2,3,4. if it ever counts more than 1 or 2 I'd say that coil is nearing its end. Link to comment Share on other sites More sharing options...
eckseleven Posted January 29, 2019 Share Posted January 29, 2019 I'll have to get some logs next time. I'm aware of that fuel stumble problem but didn't think that could be it since this came out of nowhere. I had done dozens of full pulls during the etuning process a couple months ago with no issue. Only thing different now is the temp has dropped 40-50 degrees. Link to comment Share on other sites More sharing options...
FLlegacy Posted January 29, 2019 Share Posted January 29, 2019 Mine stumbles occasionally if the stars are aligned correctly. Link to comment Share on other sites More sharing options...
GTEASER Posted January 30, 2019 Share Posted January 30, 2019 Ever since the McDowell tune mine has had the famous stumble. Its at throttle tip in between 2500 and 3200 rpms, not wot. If I peg it, it goes away. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
soares Posted February 5, 2019 Share Posted February 5, 2019 Just got some fresh Mobil 1 synthetic into the front & rear diffs. Had some trouble locating front fill plug LOL Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Loya1ty Posted February 5, 2019 Share Posted February 5, 2019 Since the temps got up into the 60s the past 2 days, I did a quick rinse of all the salt accumulation since the car wash line was 20+ deep. Took more time to enable and then winterize the water/hose lines again, since next week wants to snow again -_- Link to comment Share on other sites More sharing options...
Falcor Posted February 5, 2019 Share Posted February 5, 2019 Finally fixed the driver's side headlight bulb that was not seated correctly. It's nice to have 2 good headlights again. Link to comment Share on other sites More sharing options...
Golferdude1087 Posted February 6, 2019 Share Posted February 6, 2019 I got 4 new stainless steel lines installed and put in a warranty claim with goodridge because that's the second one that failed. Customer service so far has been excellent and they are concerned as to why two failed the same way Sent from my VS996 using Tapatalk Link to comment Share on other sites More sharing options...
Humble Rumble Posted February 7, 2019 Share Posted February 7, 2019 I got 4 new stainless steel lines installed and put in a warranty claim with goodridge because that's the second one that failed. Customer service so far has been excellent and they are concerned as to why two failed the same way Sent from my VS996 using Tapatalk If you go through a third set, I'm going to chalk it up to something unique on your specific car, because I've literally not seen a single other 5th gen with that issue with the Goodridge lines. Would make me thing that something is rubbing somewhere or something along those lines. Glad to hear they've been helpful in getting them replaced though. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
FLlegacy Posted February 7, 2019 Share Posted February 7, 2019 If you go through a third set, I'm going to chalk it up to something unique on your specific car, because I've literally not seen a single other 5th gen with that issue with the Goodridge lines. Would make me thing that something is rubbing somewhere or something along those lines. Glad to hear they've been helpful in getting them replaced though.Google search: https://www.google.com/search?q=goodridge+stainless+brake+line+failure&oq=goodridge+stainless+brake+line+failure&aqs=chrome..69i57j33l2.18576j1j4&client=ms-android-verizon&sourceid=chrome-mobile&ie=UTF-8 It really isnt unique failures happen in all manufactured products. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
Golferdude1087 Posted February 7, 2019 Share Posted February 7, 2019 If you go through a third set, I'm going to chalk it up to something unique on your specific car, because I've literally not seen a single other 5th gen with that issue with the Goodridge lines. Would make me thing that something is rubbing somewhere or something along those lines. Glad to hear they've been helpful in getting them replaced though. No this is the second set, i replaced 1 line and then a different line on the original set failed. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted February 7, 2019 Share Posted February 7, 2019 picked up my car yesterday and finally it is all fixed... runs perfectly and no more issues. Link to comment Share on other sites More sharing options...
GTEASER Posted February 7, 2019 Share Posted February 7, 2019 picked up my car yesterday and finally it is all fixed... runs perfectly and no more issues.So what was the issue? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
DrD123 Posted February 9, 2019 Share Posted February 9, 2019 Trying to fix a bad rock chip from Thursday - using the Permatex kit (every video/product literature thing I have seen looks the same, so probably whatever is cheapest is fine) - really hoping it works well - so far, looks pretty good - there was a chunk that had a surface penetrating crack on two sides, and one that wasn't, so hoping that stays still and I don't end up with a divot in the windshield. It's on the passenger side, so not in my line of sight, but annoying nonetheless (was a dually pulling some contractor box sort of trailor that flung the rock - I hate construction vehicles - they have deep tread on the tires to go in the dirt/mud, but never ever can be bothered with getting the rocks out before going on the road) it's sitting in the sun curing now. Doing one on my wife's van at the same time - that one is coming out pretty perfect, it looks - can't even see the tiny cracks! Had safelite repair one on my windshield a couple of years ago and wasn't overly impressed, so also sort of doing an experiment to see which is better/worse or of they are about the same) Link to comment Share on other sites More sharing options...
DrD123 Posted February 9, 2019 Share Posted February 9, 2019 Turned out better than the Safelite folks (I think the tech was rushing, even though it was an appointment...) as the cracks in the windshield are pretty much invisible. The surface looks ok - you can see where the chip is, but it's better than having a big divot in the windshield, I suppose! (the crack didn't travel at all, but you can see it bulging up ever so slightly - other repairs look similar around them... Wifes van turned out pretty close to perfect, but it wasn't as bad a chip. Link to comment Share on other sites More sharing options...
dgoodhue Posted February 10, 2019 Share Posted February 10, 2019 The 1st rock chip, I had repair by a windshield place came out awesome, I had a hard finding the repair. I have 3 other repairs since then, have not been as great and they have all been noticeable. One of them looked like bug splattered on my windshield. I never thought about fixing it myself, I bet I could do a better job than most of the windshield repairs I have gotten. Link to comment Share on other sites More sharing options...
NVAKeith Posted February 11, 2019 Share Posted February 11, 2019 Replaced a dead TPMS sensor. Decided to go all in and bought a tire bead breaker and a TPMS scanner/programmer which included eight new sensors. All for $322. Will be a while to break even but since I have two sets of wheels with sensors 6-8 years old it should work out over the next two years or so (at least that’s what I’m telling myself). Link to comment Share on other sites More sharing options...
FLlegacy Posted February 11, 2019 Share Posted February 11, 2019 Thus evening my car didnt want to start, I tried 3 times and nothing but cranking over. So I let it sit for a few minutes with the key off, then cranked it again and it slowly sputtered to life. No CELs, but some strong smells of exhaust and fuel. Nothing amiss with the AF ratio and no issues on the drive home, I hope it was just a fluke. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
Golferdude1087 Posted February 11, 2019 Share Posted February 11, 2019 Not done yet, but in the process of collecting funds for a LED Cbar switchback for the facelift headlights. Should be installed and completed by Mid march. Group buy interest to follow. (cost to be around $200 plus headlights) Link to comment Share on other sites More sharing options...
