Sarang Posted November 15, 2018 Share Posted November 15, 2018 ^^ That's going to feel like a different car when you get it back Link to comment Share on other sites More sharing options...
wrxwhit Posted November 15, 2018 Share Posted November 15, 2018 What’s worse than pulling the tranny down and come to find out your South Bend clutch is not the correct application DOH!!! Also found out after talking with a South Bend rep, there rated torque is to the crank not the wheels, so the stage 2 daily had no chance with my 376 tq as it’s rated 315 crank. He talked me into the stage 3 Endurance and gave me invoice pricing under a grand woot woot. But cars gotta sleep up in the air till next week Link to comment Share on other sites More sharing options...
cww516 Posted November 15, 2018 Share Posted November 15, 2018 Glad to hear that's what the problem was and not something worse. Probably means I should change out my stage 2 endurance bookmark for a stage 3 endurance bookmark...  edit: no future mod plans expressed or implied there, just hedging my bets. Link to comment Share on other sites More sharing options...
FLlegacy Posted November 16, 2018 Share Posted November 16, 2018 I seem to recall the stock clutch was good for 350 ft lbs at the crank. I know mine hasn't slipped yet. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
spb Posted November 16, 2018 Share Posted November 16, 2018 wrxwhit what do you have for your suspension? (springs/struts) Looks like Koni assembly, but when I search for 2010 LGT, koni website they only show shocks. Link to comment Share on other sites More sharing options...
cww516 Posted November 16, 2018 Share Posted November 16, 2018 Pretty sure he just has inserts, but the Dupli-Color school bus yellow paint and the Koni labels really complete the look. Link to comment Share on other sites More sharing options...
spb Posted November 17, 2018 Share Posted November 17, 2018 Picked up my car from the shop. They did a nice job. Struggled with that pin though ($). Things are nice and tight. Still getting used to the shifter. This is the tightest shifter I ever drove so sometimes I feel like the gear did not engage while it did. I am sure I will get used to it. RSB - although I am feeling an improvement I cannot say it is dramatic to a point I don't recognize my car. Maybe I need to push it a little more. But things are pretty slick out there right now. Â Dropped it off at a local shop. Installing - Whiteline RSB - Boomba SSP - Perrin Bushing - Perrin Stop Link to comment Share on other sites More sharing options...
amusa Posted November 17, 2018 Share Posted November 17, 2018 Oil change, Checked the fluid and LCA’s bushing and install OEM side corner cargo nets. Link to comment Share on other sites More sharing options...
Humble Rumble Posted November 17, 2018 Share Posted November 17, 2018 Swapped all four corners to Akebono ceramic pads. Just so sick of the squeal and dust and don't need super aggressive pads for the winter. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
spb Posted November 17, 2018 Share Posted November 17, 2018 Rumble, what did you have before? Link to comment Share on other sites More sharing options...
Humble Rumble Posted November 17, 2018 Share Posted November 17, 2018 I initially had Hawk HPS 5.0 all around, couldn't stand the squeal and dust, swapped the fronts to Carbotech AX6 for my track day, never bothered to swap them back out after, and their squeal and dust were even worse, although the dust sprays off really easy. At this point, I just wanted something quiet. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
Shadow_419 Posted November 17, 2018 Share Posted November 17, 2018 Swapped all four corners to Akebono ceramic pads. Just so sick of the squeal and dust and don't need super aggressive pads for the winter. I'm running Akebono ceramics in the front. Put those in when I did my front brakes and painted the calipers recently. Very happy with them for daily use. Link to comment Share on other sites More sharing options...
amusa Posted November 18, 2018 Share Posted November 18, 2018 I run Akebono in all my vehicle’s for many years. For the same reason brake dust. Link to comment Share on other sites More sharing options...
spb Posted November 19, 2018 Share Posted November 19, 2018 After spending some more time on forums, about to pull a trigger on: - Centric Premium Brake Rotors - Hawk Performance Ceramic Brake Pads - Goodridge Stainless Steel Brake Lines - ATE TYP200 Brake Fluid - 1L - Permatex 24125 Ceramic Extreme Brake Parts Lubricant, 8 oz. There goes another $490. Plus install at the shop. How do I block this site? Link to comment Share on other sites More sharing options...
Scubaboo Posted November 19, 2018 Share Posted November 19, 2018 After spending some more time on forums, about to pull a trigger on: - Centric Premium Brake Rotors - Hawk Performance Ceramic Brake Pads - Goodridge Stainless Steel Brake Lines - ATE TYP200 Brake Fluid - 1L - Permatex 24125 Ceramic Extreme Brake Parts Lubricant, 8 oz. There goes another $490. Plus install at the shop. How do I block this site? You got off easy, you didnt end up buying Brembos. Link to comment Share on other sites More sharing options...
spb Posted November 19, 2018 Share Posted November 19, 2018 And that's exactly why I need to block it!! . . . . So how much would it be for brembos, sir? Link to comment Share on other sites More sharing options...
wrxwhit Posted November 19, 2018 Share Posted November 19, 2018 wrxwhit what do you have for your suspension? (springs/struts) Looks like Koni assembly, but when I search for 2010 LGT, koni website they only show shocks.   The konis are off the late model wrx with oem top hats and 3.6r h&r lowering springs. Ride quality is perfect in Massachusetts!!  So didn’t realize that the stage 3 endurance South Bend comes with the flywheel as it just arrived today.... looks nice!!   Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Zee199969 Posted November 19, 2018 Share Posted November 19, 2018 (edited) So didn’t realize that the stage 3 endurance South Bend comes with the flywheel as it just arrived today.... looks nice!!  whats up whit! I didn't see a flywheel listed for it. Also curious to hear how it feels vs the stage 2 clutch EDIT: nevermind on the clutch link, found the one with flywheel: https://www.southbendclutch.com/clutches/FJK1001FW-SS-TZ-11552/ Edited November 19, 2018 by Zee199969 My "Build" Link to comment Share on other sites More sharing options...
wrxwhit Posted November 19, 2018 Share Posted November 19, 2018 (edited) Oh wow, so I assume it’s a lighter flywheel. I had no clue when I phoned in the order lol!! Also got dealer pricing and paid $950 not $1237. Well, got an oem flywheel I need to sell, not returning it A good read  https://www.torquecars.com/tuning/dmf-solid-flywheel.php  Sent from my iPhone using Tapatalk Edited November 19, 2018 by wrxwhit Link to comment Share on other sites More sharing options...
Zee199969 Posted November 20, 2018 Share Posted November 20, 2018 Oh wow, so I assume it’s a lighter flywheel. I had no clue when I phoned in the order lol!! Also got dealer pricing and paid $950 not $1237. Well, got an oem flywheel I need to sell, not returning it  How much you want for the OEM flywheel? My "Build" Link to comment Share on other sites More sharing options...
Shadow_419 Posted November 20, 2018 Share Posted November 20, 2018 Oh wow, so I assume it’s a lighter flywheel. I had no clue when I phoned in the order lol!! Also got dealer pricing and paid $950 not $1237. Well, got an oem flywheel I need to sell, not returning it A good read  https://www.torquecars.com/tuning/dmf-solid-flywheel.php  Sent from my iPhone using Tapatalk Flywheel on 5th gen is single mass anyway so a new flywheel for you. I just had mine resurfaced when I did my clutch. Link to comment Share on other sites More sharing options...
swells Posted November 20, 2018 Share Posted November 20, 2018 Are aFe cold air intakes worth the money? I currently have a K&N filter but was thinking about ordering one of these.  https://www.amazon.com/aFe-TR-4303P-Takeda-2010-2011-H4-2-5L/dp/B004WNJYC6/ref=sr_1_1?s=automotive&ie=UTF8&qid=1542699280&sr=1-1&keywords=TR-4303P Link to comment Share on other sites More sharing options...
Perscitus Posted November 20, 2018 Share Posted November 20, 2018 Are aFe cold air intakes worth the money? I currently have a K&N filter but was thinking about ordering oneAvoid at all costs. Keep the intake system stock, down to the paper filter element, or at most do a non-oiled drop-in such as AEM Dryflow, Cosworth, Amsoil EaO Nanofiber, etc.  This has been discussed at lenght even fairly recently. Search the forum for intake info, intake resonance, MAF spikes, MAF instability, IAT inaccuracy, heatsoak, Load error, etc. Link to comment Share on other sites More sharing options...
dgoodhue Posted November 20, 2018 Share Posted November 20, 2018 Are aFe cold air intakes worth the money? I currently have a K&N filter but was thinking about ordering one of these.  https://www.amazon.com/aFe-TR-4303P-Takeda-2010-2011-H4-2-5L/dp/B004WNJYC6/ref=sr_1_1?s=automotive&ie=UTF8&qid=1542699280&sr=1-1&keywords=TR-4303P No, air intake change the MAF calibration and often make the car slower unless tuned for the air intake change. Link to comment Share on other sites More sharing options...
Scooby Fan Posted November 21, 2018 Share Posted November 21, 2018 It has been going down to "freezing" 0C/32F the last few nights and there is supposed to be a storm coming in tonight ....so....time to put on the winter wheels and tires  I have been waiting for the call to go in for hip replacement surgery so I can assure you hunkering down and swapping rims was not a lot of fun!! Then as an extra bonus, when I went to reset the tire pressure, my little air compressor crapped out and I had to go find a gas station with an air pump:spin: On the bright side, while I was pumping air into my snow tires....a guy drives up in a Pontiac Sunfire and wants to know what the name of the color is on my Legacy... he had me repeat it a number of times and then wrote it down in a note book.......Says he likes it so much he is going get his Sunfire painted the same color?? Who knows? A decent paint job is worth more than his car, but it took some of the sting outta my sore hip and crapped out compressor ....Oh well...off to the auto parts store tomorrow Link to comment Share on other sites More sharing options...
