Drogos Posted September 23, 2013 Share Posted September 23, 2013 I would use the upgraded STI (Exedy) clutch and STI flywheel. what do you mean? OEM sti clutch made by exedy or aftermarket Exedy in STI fitment ? Link to comment Share on other sites More sharing options...
KCwagon Posted September 23, 2013 Share Posted September 23, 2013 what do you mean? OEM sti clutch made by exedy or aftermarket Exedy in STI fitment ? I was referring to the Subaru factory STI clutch made by Exedy. There is also a Subaru factory HD STI clutch also made by Exedy. I will try to find the part numbers. Link to comment Share on other sites More sharing options...
Drogos Posted September 24, 2013 Share Posted September 24, 2013 had no clue about 2 variants, any year will do ? Link to comment Share on other sites More sharing options...
Eric Posted September 24, 2013 Share Posted September 24, 2013 I was referring to the Subaru factory STI clutch made by Exedy. There is also a Subaru factory HD STI clutch also made by Exedy. I will try to find the part numbers. I think the HD ones might be here on page 15: http://www.subaru.com/content/downloads/pdf/spt/perf_parts_catalog.pdf st302104s000 STi HD clutch cover st301004S020 STi HD clutch disk There is a review of it here on the second page: http://www.iwsti.com/forums/drivetrain-components/107053-spt-clutch-kit-worth.html "The motor does rev a little faster.... It mainly is just a pain in my ass since this clutch is so much more grabby and hard to push down/release." Note that this reviewer also installed the 15.8lb STi lightweight flywheel. In the Subaru catalog they note that "Some clutch judder may result when clutch is partially engaged". I wonder how that would compare to the FX350? Link to comment Share on other sites More sharing options...
dahoseman Posted September 24, 2013 Share Posted September 24, 2013 I can't imagine they would be able to sell anything in stock-form that is as jumpy as my FX350. People would think something is wrong. I am actually worried that the clutch shutter might actually break or rattle parts of the car loose. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 24, 2013 Moderators Share Posted September 24, 2013 After 2500 miles my FX350 has gotten significantly better. That's not really much consolation though if you are dealing with what I dealt with prior to 2000 miles or so... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
MNRZR Posted September 24, 2013 Share Posted September 24, 2013 After 2500 miles my FX350 has gotten significantly better. That's not really much consolation though if you are dealing with what I dealt with prior to 2000 miles or so... Do you think it's getting better or are you just getting better at modulating the on/off switch I've been in the same boat since about 600 miles on my FX350. I'm now at 1800 miles and hoping it gets better. I'm still not convinced that it's not just an operator issue. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 24, 2013 Moderators Share Posted September 24, 2013 Likely a bit of both, but I believe the clutch itself has significantly changed. My wife drove the car once a while ago when it was bad. She recently drove it for a second time this weekend and also noticed that it's much better. I'd say the improvement is at least 80-90% clutch related... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
MNRZR Posted September 24, 2013 Share Posted September 24, 2013 I hope you're right. The first gear shudder is the only complaint I have for this clutch. Pedal effort is better than stock and it absolutely holds the stage 2 VF52 power of my car. Link to comment Share on other sites More sharing options...
.Catalyst. Posted September 24, 2013 Share Posted September 24, 2013 I agree - the take off shudder is/was the worst facet of this clutch upgrade for me too. Now that I have truly broken this in with many miles it is much much better. Completely avoidable now with a different takeoff, but even if I don't rev up, it's not nearly as violent as before. My glovebox will never be the same and I have some new rattles that started after going through the clutch break in period (which is more like 5K miles to eliminate this issue). Other than that though this thing holds great, super friendly pedal effort, predictable engagement, and smooth between all gear changes. Can't wait to throw more power at it! My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
Turkeylord Posted September 24, 2013 Share Posted September 24, 2013 Does anyone have experience with both the FX300 and FX350? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 24, 2013 Moderators Share Posted September 24, 2013 Nope. FWIW, I hould be selling my FX350 setup shortly. Ideally I'd like to sell the whole setup with TSK3, newly installed flywheel, and clutch pieces--should allow the new owner to bypass most of the really rough "shudder" stage since the clutch parts will already be broken in. Am I supposed to mark the parts somehow when removing a clutch with the plans to reinstall? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
MNRZR Posted September 24, 2013 Share Posted September 24, 2013 What are you going to install in place of the FX350? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 24, 2013 Moderators Share Posted September 24, 2013 What are you going to install in place of the FX350? A spec.b 6mt Probably worth mentioning that up until about 1500 mile I was planning to go back to a stock clutch. At this point with where the clutch is, I probably wouldn't change anything if I wasn't moving to a 6mt. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Turkeylord Posted September 24, 2013 Share Posted September 24, 2013 FWIW, I hould be selling my FX350 setup shortly. Ideally I'd like to sell the whole setup with TSK3, newly installed flywheel, and clutch pieces--should allow the new owner to bypass most of the really rough "shudder" stage since the clutch parts will already be broken in.Dibs! Link to comment Share on other sites More sharing options...
KCwagon Posted September 25, 2013 Share Posted September 25, 2013 Dibs! Dang, missed another one , Second dibs Link to comment Share on other sites More sharing options...
dahoseman Posted September 26, 2013 Share Posted September 26, 2013 Does anyone have experience with both the FX300 and FX350? I had a FX300 and FX350 installed on the same car. The pressure plate was defective on the FX300 and ruined the clutch, so CM sent me a FX350 as a replacement. The FX300 was smooth as butter and had good clutch feel. The FX350 shakes my car like an earthquake in 1st and 2nd gear. Link to comment Share on other sites More sharing options...
PhillyWilly Posted September 26, 2013 Share Posted September 26, 2013 Have people reported the shudder to CM and what was their response? I am not too happy with my 350. If the shaking goes away after 2k miles then fine, but I am nervous that it wont and I will need to start over. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 26, 2013 Moderators Share Posted September 26, 2013 Have people reported the shudder to CM and what was their response? Their response to me was that my swap to a SMFW is the cause... My own opinion is that you seem to have a choice between increased holding capacity from a much stouter pressure plate (resulting in a heavy clutch pedal) or from an increase in overall friction. The latter is the direction that CM seems to go since pedal feel is the same or lighter than stock. The downside to both choice is obvious--heavy clutch pedal or increased shudder from friction surfaces. Pick your poison, I guess. As the parts wear on the 350 at least they seem to be getting better. For something like an ACT clutch the pedal will be heavy forever and if you go with a LWFW you'll experience shudder / decel chatter as well. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
PhillyWilly Posted September 26, 2013 Share Posted September 26, 2013 Their response to me was that my swap to a SMFW is the cause... I wonder if their response to me would be the same since my car came with a SMFW? Link to comment Share on other sites More sharing options...
B00STER Posted September 26, 2013 Share Posted September 26, 2013 I love the heavy pedal feel on my ACT/SMFW combo I hate the "shudder" on it... Though, I have only noticed that it happens when there is a passenger in the car... Hmmmm Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted September 28, 2013 Share Posted September 28, 2013 ATTENTION EVERYONE WITH EXCESSIVE CHATTER, DRIVETRAIN SLOP, INABILITY TO CRUISE LOW RPMS, ETC. The group-N motor mounts completely eliminated all of these issues. it really is the magical solution to all of the issues, and nvh isn't too noticeable. I love everything about my 5mt setup now, and I highly suggest this mod to anyone past stage 1. I would put the car back up in the air and take the mounts out, just so I could do it over again. Thanks to Rick from Underdog! Link to comment Share on other sites More sharing options...
idiot4hire Posted September 28, 2013 Share Posted September 28, 2013 I think the group n is a great mod for any Subaru regardless is mods Link to comment Share on other sites More sharing options...
PhillyWilly Posted September 29, 2013 Share Posted September 29, 2013 Well I guess I am going to have to give the motor mounts a try. How long does the install take? Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted September 29, 2013 Share Posted September 29, 2013 couple of hours. it's really not bad, a little tight getting the rear studs off the OEM mounts. pretty straight forward though. Link to comment Share on other sites More sharing options...
