Infamous1 Posted December 31, 2011 Author Share Posted December 31, 2011 Is "you" me? I have no "official" standard, I like to set a known boost level for a turbo then dial in timing. But that even changes depending on the situation. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted February 22, 2012 Share Posted February 22, 2012 Anybody want to take a look at my Learning view ? been ~ a month since my tune / ecu reset. bnr 18g with stage 2 mods, oem fuel. Link to comment Share on other sites More sharing options...
bmx045 Posted February 22, 2012 Share Posted February 22, 2012 eh, not bad, tiny knock here and there but mostly in the real low load ranges Link to comment Share on other sites More sharing options...
SeeeeeYa Posted February 22, 2012 Share Posted February 22, 2012 eh, not bad, tiny knock here and there but mostly in the real low load ranges I'd add, eliminate that 32-4400 max-load knock. You can never tolerate knock at max load. Reset and see if it shows up there again. If it does, correct it ASAP. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted February 22, 2012 Share Posted February 22, 2012 Thanks guys How long after the ecu reset should I report back ? Link to comment Share on other sites More sharing options...
SeeeeeYa Posted February 23, 2012 Share Posted February 23, 2012 Thanks guys How long after the ecu reset should I report back ? After 50-100 miles with some logging runs and "spirited" driving in it, checking daily for knock... if it takes that long. If you see any knock at max load at any RPM, at any time, take care of it. This isn't saying ignore knock at lower RPM and loads, especially if it keeps recurring in the same place. That should be addressed as well. But it is knock when the engine is at WOT and high RPMs that kills motors. Back the timing off where it knocks until there is none there. Never stop checking. Make it a habit. Conditions change, gasoline changes, flat land vs mountains, etc. Checking is easy, replacing engines is not. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted February 23, 2012 Share Posted February 23, 2012 Thank you. I log some runs here and there and post up a lv again after 50-100 miles. Mmm, If I do get knock again, how would you exactly fix that ? Link to comment Share on other sites More sharing options...
Infamous1 Posted February 28, 2012 Author Share Posted February 28, 2012 That is one knock count, I wouldn't put to much effort into that. It could easily been picked up on a bad shift. Like I tell customers often, do not get all caught up in logged data unless you want to get into tuning your own vehicle. Link to comment Share on other sites More sharing options...
Turkeylord Posted February 29, 2012 Share Posted February 29, 2012 I've been running my logs into the airboy spreadsheet, and now into the Virtual Dyno program... Is it pretty normal to see HP and TQ numbers getting lower as we go through the revision process? I can post the graph if needed... Link to comment Share on other sites More sharing options...
bmx045 Posted February 29, 2012 Share Posted February 29, 2012 if timing has to be retarded because of knock, yes Link to comment Share on other sites More sharing options...
ibr_adam09 Posted March 1, 2012 Share Posted March 1, 2012 So here's What my logs look like and my learning view. The lv looks cleaner than the one before with no 'knock' throughout the ranges. Most of the knock sums picked up in my log were under 3k rpm. So if you're bored, please take a look at it please and tell me your thoughts. EDIT: I can't upload my excel sheet. Any trick to convert to file to get it uploaded ? Link to comment Share on other sites More sharing options...
bmx045 Posted March 1, 2012 Share Posted March 1, 2012 looks fine Link to comment Share on other sites More sharing options...
urfsin Posted March 4, 2012 Share Posted March 4, 2012 I have a tuning question for you guys....or I should say DE-tuning question: With the gas prices @ $4.50 / gal for premium and soon to be $5 / gal I was wondering how hard it would be to make a 87 octane map. I was thinking of an "economy" map that cut out boost control (just running waste gate pressure) and timing to match. Is this a viable idea? I really don't know, but the gas prices are KILLING me. Slide It Sideways Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 4, 2012 Share Posted March 4, 2012 email Infamous... and see what he says. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
bmx045 Posted March 5, 2012 Share Posted March 5, 2012 I have a tuning question for you guys....or I should say DE-tuning question: With the gas prices @ $4.50 / gal for premium and soon to be $5 / gal I was wondering how hard it would be to make a 87 octane map. I was thinking of an "economy" map that cut out boost control (just running waste gate pressure) and timing to match. Is this a viable idea? I really don't know, but the gas prices are KILLING me. you bought the wrong car Link to comment Share on other sites More sharing options...
bmx045 Posted March 5, 2012 Share Posted March 5, 2012 I made my map to where anything under 3000 rpm its easy on gas. If you look at your current map it probably pretty close to doing the same thing. Anything over 3000 and its better perf again. So just keep your foot out of it. I'd love to hear more. Link to comment Share on other sites More sharing options...
urfsin Posted March 6, 2012 Share Posted March 6, 2012 you bought the wrong car Negative Ghostrider. On the flip side I bought the PERFECT car for my needs. I just want to save a few bucks at the pump when I am driving around town and not playing boy racer <--Maybe that's what you do? Besides, I have used my car plenty on track days, auto-x and rally-x to justify the power. My next event is the Lone Pine Time trial and I am sure to load my 91 octane map (or E85 if I can find some) at that point. Until then, I see no reason to have all the power and spend an extra $.30 - $.40 cents a gallon. Slide It Sideways Link to comment Share on other sites More sharing options...
MasAyinde Posted March 6, 2012 Share Posted March 6, 2012 I think he's saying that if it's such a big deal to you to pinch pennies and save 20 cents/gallon at the pump, then you shouldn't be driving a turbocharged car. Since you made the decision to buy a turbocharged car, kwitcherbitchin and suck it up. Link to comment Share on other sites More sharing options...
urfsin Posted March 6, 2012 Share Posted March 6, 2012 ^^ Listen, if I wanted any $hit out of you I would squeeze your head. You clearly don't know where I am coming from and don't know how to do it, so just STFU. Slide It Sideways Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted March 6, 2012 Mega Users Share Posted March 6, 2012 Link to comment Share on other sites More sharing options...
MasAyinde Posted March 6, 2012 Share Posted March 6, 2012 No, I know how to do it. I've been in Jersey and had the guy fill up with regular instead of 93 and had to create and load a map before I drove off. I didn't pay for the tank and I tracked knock. Drove safely on that tank, albeit with less power. I still have the map saved and I suppose I COULD send it to you. I'm sure it's not as good as something a tuner would make as it was created in 10 minutes by me, but it worked just fine for what I needed it for, and it was free. That gas station attendant is lucky I had my laptop in the car with me. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted March 6, 2012 Share Posted March 6, 2012 I just urinate into my tank.. Saves me $$$$ big time as I drink a lot. I find that I get more power if I've had a gatorade. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
urfsin Posted March 6, 2012 Share Posted March 6, 2012 Well, I just did the math based on how much I drive and it's only a potential savings of a few hundred a year. Not really peanuts, but not a whole lot of money either. I still may do it just to see how it goes. I wish I had E85 in my area, that way I could have the better power and cheaper fuel. The downside is the worse mileage of course. I wonder if anyone here has done a cost analysis of E85 price per gallon (savings) vs. the worse mileage than gasoline. Slide It Sideways Link to comment Share on other sites More sharing options...
MasAyinde Posted March 6, 2012 Share Posted March 6, 2012 http://lmgtfy.com/?q=e85+vs+gasoline+cost+savings Link to comment Share on other sites More sharing options...
urfsin Posted March 7, 2012 Share Posted March 7, 2012 http://lmgtfy.com/?q=e85+vs+gasoline+cost+savings That's a a funny link! Not quite what I was looking for, but close enough. It looks like the mileage loss with E85 varies quite a bit from platform to platform. It would be nice to see an LGT tuned for E85 with some long(ish) term data to back it up to see how bad the mileage really is vs. gasoline. Here is another tuning question for you "MOAR POWER!" fan boi's... Lean Cruise Mode Discuss. Slide It Sideways Link to comment Share on other sites More sharing options...
