cww516 Posted May 8, 2015 Share Posted May 8, 2015 I'm fighting the same battle, but I have a $70 rebate card sitting in front of me, too. Basically makes it a $30 part, right? Link to comment Share on other sites More sharing options...
Swannee225 Posted May 8, 2015 Share Posted May 8, 2015 Makes sense to me lol go for it! Link to comment Share on other sites More sharing options...
jackal8788 Posted May 8, 2015 Share Posted May 8, 2015 those pictures you took for some reason reminded me of swimming in cold water...... VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
acumenhokie Posted May 9, 2015 Share Posted May 9, 2015 My adapter arrived today. Nice chunk of metal. Link to comment Share on other sites More sharing options...
jackal8788 Posted May 9, 2015 Share Posted May 9, 2015 Ordered mine today. I'm trying to decide if I want to pair it with the boomba shifter? I really love the setup I've got now. The Boomba shifter will really only reduce the overall height of the shift stick bit when you pair it with the new bracket, the overall effect is very nice. The bracket helps the throw distance and the Boomba stick helps the height of the shifter. VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted May 9, 2015 Share Posted May 9, 2015 Another Item to add to my growing list. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
nossy Posted May 9, 2015 Share Posted May 9, 2015 I really love the setup I've got now. The Boomba shifter will really only reduce the overall height of the shift stick bit when you pair it with the new bracket, the overall effect is very nice. The bracket helps the throw distance and the Boomba stick helps the height of the shifter. The lower height should also result in a shorter throw, provided the pivot point is in the same place relative to the stock shifter. Link to comment Share on other sites More sharing options...
jackal8788 Posted May 9, 2015 Share Posted May 9, 2015 The lower height should also result in a shorter throw, provided the pivot point is in the same place relative to the stock shifter. True. Unfortunately, the lever arm on the bottom side of the pivot point is also shorter, negating the benefit of the reduced upper length. VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
Bunky23 Posted May 9, 2015 Share Posted May 9, 2015 Ordered mine! Link to comment Share on other sites More sharing options...
pfoyle Posted May 9, 2015 Share Posted May 9, 2015 Attempted the install today... anyone have trouble with the 3 bolts on the back of the trans??? One is easy to get to (side), one is a bit tougher but do-able (lower rear), but the upper rear one is way the F up there! With the other 2 off was able to bend the shield out of the way, but after messing around with the roll pin (I think I need a longer punch) for about 30min my neighbor (who I was blocking in the driveway) had to get out. No choice but to put it all back together and try another day. So frustrating! Can't stand being bested by inanimate objects! There's no trick to the roll pin, right? Just get the punch on it and bang it with a hammer? Felt like I got some good whacks on it, but it never budged... Can I PB blast it? (there's quite a bit of salt/rust around it, which could be problematic) Grrr.... Link to comment Share on other sites More sharing options...
Zee199969 Posted May 9, 2015 Share Posted May 9, 2015 Cursing, followed by prayers to your chosen deity, followed by more cursing seemed to help me with the roll pin. I do think a long punch would've helped me greatly. My car did not have the shield that needs to be bent out of the way though. Anyone else have a similar situation? My "Build" Link to comment Share on other sites More sharing options...
Unsp0kn Posted May 9, 2015 Share Posted May 9, 2015 Mine had no shield either. Get a punch that is at least 9" long, I used a 9" drift punch and then a shorter one to finish tapping the pin out. Link to comment Share on other sites More sharing options...
cww516 Posted May 9, 2015 Share Posted May 9, 2015 Couldn't hurt to throw a little PB Blaster up there beforehand, let it penetrate around the roll pin a little. I have to imagine mine's going to be about the same way when I get to it. Link to comment Share on other sites More sharing options...
nossy Posted May 9, 2015 Share Posted May 9, 2015 True. Unfortunately, the lever arm on the bottom side of the pivot point is also shorter, negating the benefit of the reduced upper length. Well, that's just silly. Attempted the install today... anyone have trouble with the 3 bolts on the back of the trans??? One is easy to get to (side), one is a bit tougher but do-able (lower rear), but the upper rear one is way the F up there! With the other 2 off was able to bend the shield out of the way, but after messing around with the roll pin (I think I need a longer punch) for about 30min my neighbor (who I was blocking in the driveway) had to get out. No choice but to put it all back together and try another day. So frustrating! Can't stand being bested by inanimate objects! There's no trick to the roll pin, right? Just get the punch on it and bang it with a hammer? Felt like I got some good whacks on it, but it never budged... Can I PB blast it? (there's quite a bit of salt/rust around it, which could be problematic) Grrr.... I had a 6" long punch and then on top of that found a deep socket that the end of the punch fit into snugly (in my case it was an 11mm), I then put the punch in the socket and attached it to a few different sizes of socket extensions depending on the angle I was trying to achieve, and then hit the end of the extension with the hammer. My overall length was between 10-15" depending on if I was removing or installing the pin, the socket and extensions really helped with getting a better angle. I also loosened the trans subframe on the passenger side (I was going to loosen the whole thing but broke one of my snapon impact sockets trying to loosen the left side it was so tight, and I didn't feel like busting out the breaker bar). Link to comment Share on other sites More sharing options...
jackal8788 Posted May 10, 2015 Share Posted May 10, 2015 Well, that's just silly. Agreed. There must be a reason for it, but I really wish they had maintained the stick length below the pivot point. VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
n79 Posted May 15, 2015 Share Posted May 15, 2015 Installed in my '11 outback today, I didn't have a heat shield on mine. Where I had previously installed the perrin bushing, installing it on this adapter its loose? I had only had the one washer on the bushing before I think I need the other washer/black spacer. Shifts are definitely shorter but notchy and a lot more in gear slop than before but I think that's because of the bushing. Need to get that fixed and lube it up. Link to comment Share on other sites More sharing options...
brandon.mol Posted May 16, 2015 Share Posted May 16, 2015 Installed today. Driving impressions: MUCH shorter throws, to the point where the two-stage gear engagement is imperceptible and it made me a bit anxious at first like as if I engaged the synchros and not meshed the gears and letting out the clutch would result in terrible grinding... But no... Engaged perfectly. The up side...much shorter throws and much less throttle feedback in the shifter from the transmission movement, probably just because of the leverage change. Better than I was expecting. The downside... With much shorter throws comes amplified 'gravel feel'. The gearbox feels even less-smooth/more-chunky now since it takes more force to mesh the gears. Also, there is significantly more clunky shifter noise in the cabin during gear changes. Its definitely good... But will take some getting used to, and I am not so sure it will result in quicker shifts in practice. Link to comment Share on other sites More sharing options...
FLlegacy Posted May 17, 2015 Share Posted May 17, 2015 You now need a significantly heavier shift knob. Link to comment Share on other sites More sharing options...
Zee199969 Posted May 17, 2015 Share Posted May 17, 2015 I've got the Raceseng Topologi knob that I bought from jackal, 475g of shifting bliss My "Build" Link to comment Share on other sites More sharing options...
GTEASER Posted May 17, 2015 Author Share Posted May 17, 2015 Just installed. Not sure I like it. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
brandon.mol Posted May 17, 2015 Share Posted May 17, 2015 So its not just me.... I feel like it has made shifting be more laborious, not less. Second gear in particular is a bit hard to engage. The synchros in these trannies suck as is is, but this seems to make matters worse. I'm on the fence. I'll leave it on for a while and digest it some more. Link to comment Share on other sites More sharing options...
s2baru Posted May 17, 2015 Share Posted May 17, 2015 For my experience in every manual car I've driven. A weighted shift knob helps with my driving style. Maybe give that a try as well. Link to comment Share on other sites More sharing options...
GTEASER Posted May 18, 2015 Author Share Posted May 18, 2015 Yeah, lets spend more money!!! Im gonna leave mine on too and drive the car ti work a few times this week. If I decide I dont like it, its coming off next weekend before my track day. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Ellesedil Posted May 18, 2015 Share Posted May 18, 2015 Yeah, lets spend more money!!! Isn't that always the solution? Something not quick working out right? Throw more money at it. Link to comment Share on other sites More sharing options...
FLlegacy Posted May 18, 2015 Share Posted May 18, 2015 So its not just me.... I feel like it has made shifting be more laborious, not less. Second gear in particular is a bit hard to engage. The synchros in these trannies suck as is is, but this seems to make matters worse. I'm on the fence. I'll leave it on for a while and digest it some more. Lol so it's not just me that feels 1 to 2 shift can be rough at times. Link to comment Share on other sites More sharing options...
