Niko0422 Posted March 27, 2019 Share Posted March 27, 2019 I believe this is the part 35119AA010 Link to comment Share on other sites More sharing options...
Leggygirl Posted March 28, 2019 Share Posted March 28, 2019 I installed the Subaru pin for the bushing and now there’s no more axial play, but first gear still gives me some trouble sometimes. At times it goes in quick others I have to back it up and then put it back in gear. I also have the Perrin shift stopper , not sure if it has to be adjust again since the length of the throws has been shorten or maybe is that normal? Link to comment Share on other sites More sharing options...
ibr_adam09 Posted March 28, 2019 Share Posted March 28, 2019 Sometimes I have to re-pop it into gear for reverse, but I have a Boomba short shift lever, Boomba shift adapter, and Perrin shift stop. I think you might need to readjust your stop? if its too close to first gear, getting it in will be a tight squeeze. Loosen the stop, put the car in first gear, use something thin like a credit card between the stop and first gear, then tighten everything down. That thin gap should give enough room. Link to comment Share on other sites More sharing options...
