btlegacy Posted November 2, 2012 Author Share Posted November 2, 2012 I took the bellhousing off the transmission and mounted it on the mockup motor. I also placed some shims on the subframe to lower it about 3/4". I had to make about a 3/8in dent on the drivers side of the tunnel so the bellhousing would clear. I then put the motor on jackstands and aligned it into place. The steering rack now has much more clearance and went from being about 3" below the subframe to about 1" below the subframe. The motor still has a little room to be raised so I may only have to drop the rack about 1/2" which I can make up for with a bumpsteer kit The intake sticks out only slightly and I am able to close the hood but it very tight but I should be able to slightly modify that portion of the hood to clear http://imageshack.us/a/img259/8528/spacebell.jpg http://imageshack.us/a/img713/9781/intakel.jpg 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
OutbackXT05 Posted November 6, 2012 Share Posted November 6, 2012 Definently a sick project. Moving along nicely. Link to comment Share on other sites More sharing options...
outrunm Posted November 6, 2012 Share Posted November 6, 2012 Sub Link to comment Share on other sites More sharing options...
btlegacy Posted November 9, 2012 Author Share Posted November 9, 2012 Aluminum sheet for the spacers and rectangle bar the subframe came in so we hope to fabricate a good amount of that over the weekend otherwise we worked on the wiring harness for the Miata this week. 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
mass-hole Posted November 9, 2012 Share Posted November 9, 2012 Aside from spacing issues, does anyone make a kit to mate the subaru trans to an LSx series motor? I would die and go to heaven. Link to comment Share on other sites More sharing options...
700watts Posted November 9, 2012 Share Posted November 9, 2012 better late than never....scribed Link to comment Share on other sites More sharing options...
frank_ster Posted November 9, 2012 Share Posted November 9, 2012 Aside from spacing issues, does anyone make a kit to mate the subaru trans to an LSx series motor? I would die and go to heaven. well i can but the problem is the engine has to sit to far forward ( into the bumper beam) for the subaru awd transmission to work. this is why i used a gm v6 turbo engine witch pretty much fits in the stock workings. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 12, 2012 Share Posted November 12, 2012 Aside from spacing issues, does anyone make a kit to mate the subaru trans to an LSx series motor? I would die and go to heaven. There have been a couple adapter plates for this floating around NASIOC in the past, and I saw it for sale on one site (made to order). Fitment would indeed be a nightmare, but it is a swap I have researched (with much help from Frank_ster who was helpful, and the attempted help of many others who were not) to the Nth degree. I would be happy to go over anything with you, just shoot me a message. I still have a lot of the measurements written down somewhere. The engine itself is only 22.5" long. The problem is the height of it (see intake manifold pics above), the accessories (there are much flatter alternatives, see RS4 LSx swap) and thus also the positioning of the drivetrain, which would be best to move around (read the nightmare part of the swap). [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 12, 2012 Share Posted November 12, 2012 Friendly pic request, as many of the engine in the bay from different angles as you are willing, would very much appreciate it [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
btlegacy Posted November 12, 2012 Author Share Posted November 12, 2012 We made some progress in the last few days. The Miata is on the ground with the Engine, trans and rear end mounted. We have started wiring it up. On the Subaru, we cut out 3/4" subframe spacers from aluminum and got the subframe in position. Then we trimmed the subframe so we had enough clearance to be able to weld rectangle bar and steel plate in to reinforce. We were able to get the engine level and positioned and started welding from the engine mounts towards the frame rails. The plan is to use the rectangle bar to get from the mounts to the frame. then weld the bar to the subframe and then we are going to user 1 1/2" square bar to make a box around the oil pan and connect it to the radiator support at the front. I will post some pics shortly of where we are so far 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
btlegacy Posted November 12, 2012 Author Share Posted November 12, 2012 Pic of the subframe spacer http://imageshack.us/a/img43/6681/imag1499.jpg http://imageshack.us/a/img826/3609/imag1500.jpg Pic of new, much improved steering rack clearance http://imageshack.us/a/img826/1720/imag1510m.jpg Starting to build the new subframe http://imageshack.us/a/img713/6328/imag1503a.jpg http://imageshack.us/a/img546/3109/imag1511k.jpg http://imageshack.us/a/img96/9825/imag1512.jpg http://imageshack.us/a/img545/9029/imag1506x.jpg http://imageshack.us/a/img152/7916/imag1504z.jpg 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
fredrik94087 Posted November 13, 2012 Share Posted November 13, 2012 Very adventurous. Food for thought: Is the body strong enough for all that torque, or will it twist up like a pretzel? "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
BAC5.2 Posted November 13, 2012 Share Posted November 13, 2012 The body can handle it. Don't forget to lower the rear LCA mount. Do you have any plans to optimize front suspension geometry for RWD? It's not an easy task if you want to do it right, but it would pay off. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
btlegacy Posted November 13, 2012 Author Share Posted November 13, 2012 Very adventurous. Food for thought: Is the body strong enough for all that torque, or will it twist up like a pretzel? The body is plenty strong and as far as the engine mounting, that tubing will be connected from frame rail to frame rail and then to the factory subframe as well as to the front radiator support so it will hold up well 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
btlegacy Posted November 13, 2012 Author Share Posted November 13, 2012 The body can handle it. Don't forget to lower the rear LCA mount. Do you have any plans to optimize front suspension geometry for RWD? It's not an easy task if you want to do it right, but it would pay off. Hehe good reminder, I have been trying to find Outback parts to modify some of the piece as that is the height that the subframe sits now but I may end up having to but new. For now, my goal is to get it running so I can fine tune it and not have any dangerous bump steer. After that point, I am going to re-do the whole suspension and try to make it optimal for the RWD setup 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
btlegacy Posted November 18, 2012 Author Share Posted November 18, 2012 Did some more work on the subframe today. Will probably pull it out after thanksgiving to finish reinforcing it and paint it. We also threw in the stock radiator and fans and mocked up the water pump and the pictures below show that there is plenty of space in front of the motor http://imageshack.us/a/img811/1161/wp6i.jpg http://imageshack.us/a/img844/5434/wp5b.jpg http://imageshack.us/a/img547/2338/wp4.jpg http://imageshack.us/a/img203/3009/wp3x.jpg http://imageshack.us/a/img526/539/wp2c.jpg http://imageshack.us/a/img812/6080/wp1c.jpg 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
2000_LegacyOutback Posted November 23, 2012 Share Posted November 23, 2012 subbed for more crazyness Link to comment Share on other sites More sharing options...
frank_ster Posted November 23, 2012 Share Posted November 23, 2012 working with gloves .. cant stand it .. might as well be wearing shoes on your hands Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted November 23, 2012 Share Posted November 23, 2012 Trojan brand Mechanics gloves, so thick You can't feel a thing. Link to comment Share on other sites More sharing options...
frank_ster Posted November 23, 2012 Share Posted November 23, 2012 us germans have it right when we call gloves handshoes Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
PeterJMC Posted November 23, 2012 Share Posted November 23, 2012 Awesome project. Someone help me swap an 6.0 into my Prius. Link to comment Share on other sites More sharing options...
Daniels Posted November 23, 2012 Share Posted November 23, 2012 I have heard about flyin miata doing those 450hp v8 swaps, this is too cool. Link to comment Share on other sites More sharing options...
btlegacy Posted November 26, 2012 Author Share Posted November 26, 2012 The gloves make life alot easier especially when dealing with dirty oily parts 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
btlegacy Posted November 26, 2012 Author Share Posted November 26, 2012 We made a lot of progress on the Miata. The engine is in the car and we are finishing up the accessories. The harness is 80% complete and we hope to finish it up by the weekend and get it started. We are going to complete the Subframe for the Legacy this week and start on the transmission mounting. Here are a few pics of the Miata http://imageshack.us/a/img407/6404/accessoriesn.jpg http://imageshack.us/a/img715/3053/motorinfinal.jpg http://imageshack.us/a/img836/7927/frontlowview.jpg http://imageshack.us/a/img545/4924/onwheels.jpg http://imageshack.us/a/img341/1968/ypipeincar.jpg 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted November 26, 2012 Share Posted November 26, 2012 After seeing the first few posts I wasnt sure how this was gunna go. Awesome job man, looks good, the engine in miata a "mock" one? sits pretty high in front for v8ness under the hood Link to comment Share on other sites More sharing options...
