frank_ster Posted March 26, 2013 Share Posted March 26, 2013 ^ just a question .. wouldn't you prefer the same power but awd ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
SCHM1AN Posted March 26, 2013 Share Posted March 26, 2013 How much for your Buick 6-er setup? Link to comment Share on other sites More sharing options...
frank_ster Posted March 26, 2013 Share Posted March 26, 2013 well depends on what you want. adpater plate 350$ headders depending on model of buick 6 you want. megasquirt or fast or aem or whom ever ecu you want. and mt or at tranny Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
SCHM1AN Posted March 26, 2013 Share Posted March 26, 2013 What did your setup cost you? Power output? Mileage? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 26, 2013 I Donated Share Posted March 26, 2013 The wiring is the real problem. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted March 26, 2013 Share Posted March 26, 2013 ^This. How much for the plug-and-play harness? Link to comment Share on other sites More sharing options...
Leviman Posted March 27, 2013 Share Posted March 27, 2013 The wiring is the real problem. The wiring is really not bad at all. It's not hard to convert a factory harness down to just a constant+switched wiring setup. My brother has done three LS swaps using factory harnesses and he's working on a fourth (I'm helping a bit to) and it's really not that hard. You do have to have HP tuners though. This swap looks very well done though, btw! Can't wait to see the end burnout, er, I mean, result. Also, couldn't you use the factory subaru AC condenser? Link to comment Share on other sites More sharing options...
frank_ster Posted March 27, 2013 Share Posted March 27, 2013 i couldn't use the factory condenser because its too wide to fit between the head lights. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
btlegacy Posted March 27, 2013 Author Share Posted March 27, 2013 I am building this for fun for myself at this time but if there were demand we may build a few kits. We considered AWD for this project but it just wouldn't work to be packaged properly. We may revisit AWD Options in the future. As far as the wiring, it is not that bad. The most complicated part is going to be the instruments. I built the Miata harness from a combination of junkyard plugs and new pieces we had from a Chevy Van, a Pontiac GTO, and an Isuzu ascender. The engine portion of the Harness is fully standalone and could be dropped into another car if you really wanted to. For the Subaru, I am going to look to user the harness plgu in the bay to get wires inside that are needed. As far as the condenser and radiator, I am going to look into that once all the accesories are mounted up and may go to custom pieces if needed to make everything fit well. I have also decided on a rear differential setup and will be running a R200 from an Infiniti Q45 with LSD and 3.69 Ratio 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted March 27, 2013 Share Posted March 27, 2013 Thank you so much for all the pictures!!! [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
shtbxr22 Posted March 29, 2013 Share Posted March 29, 2013 I'm impressed! good job. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted March 29, 2013 Share Posted March 29, 2013 Let me know what you might want for that urethane block when you're done. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
BAC5.2 Posted March 29, 2013 Share Posted March 29, 2013 I am building this for fun for myself at this time but if there were demand we may build a few kits. We considered AWD for this project but it just wouldn't work to be packaged properly. We may revisit AWD Options in the future. As far as the wiring, it is not that bad. The most complicated part is going to be the instruments. I built the Miata harness from a combination of junkyard plugs and new pieces we had from a Chevy Van, a Pontiac GTO, and an Isuzu ascender. The engine portion of the Harness is fully standalone and could be dropped into another car if you really wanted to. For the Subaru, I am going to look to user the harness plgu in the bay to get wires inside that are needed. As far as the condenser and radiator, I am going to look into that once all the accesories are mounted up and may go to custom pieces if needed to make everything fit well. I have also decided on a rear differential setup and will be running a R200 from an Infiniti Q45 with LSD and 3.69 Ratio I spent a good deal of time mulling over retention of AWD with an LS swap a few years ago. In short, it can't really be done. Not without making design sacrifices I wasn't willing to make. If you really want to keep AWD, something like Frank's setup is a better starting point. Fortunately, depending on how you define that word, the rear suspension of the LGT is much better suited to fitting big tires. You'll need to do some body work, but fitting a 275 UHPS should be easy. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
btlegacy Posted April 1, 2013 Author Share Posted April 1, 2013 We made some progress on the rear differential yesterday. The unit that I am using is a R200 VLSD 3.69 Ratio from an Infiniti Q45. We measured and cut the mounts yesterday and tacked them in place. The diff sits very nicely in the car and the axles line up. We are now waiting on bushings and some other hardware to complete the setup. We will then add the bracing and weld it completely. This setup will run Infiini J30 axles and hubs and 300ZX Wheel Bearings. This will change the lug pattern to 5x114.3 as well. More details to follow once completed. http://imageshack.us/scaled/large/200/sideview2.jpg http://imageshack.us/scaled/large/708/sideviewz.jpg http://imageshack.us/scaled/large/546/side9.jpg http://imageshack.us/scaled/large/202/side8l.jpg http://imageshack.us/scaled/large/713/side6n.jpg http://imageshack.us/scaled/large/845/side5.jpg http://imageshack.us/scaled/large/5/side3.jpg http://imageshack.us/scaled/large/843/rearviews.jpg http://imageshack.us/scaled/large/203/rear10.jpg http://imageshack.us/scaled/large/837/rear8.jpg http://imageshack.us/scaled/large/13/rear7.jpg http://imageshack.us/scaled/large/820/rear6m.jpg http://imageshack.us/scaled/large/849/rear3.jpg http://imageshack.us/scaled/large/255/rear2t.jpg http://imageshack.us/scaled/large/825/axlesm.jpg http://imageshack.us/scaled/large/594/bottomx.jpg http://imageshack.us/scaled/large/7/frontyov.jpg http://imageshack.us/scaled/large/849/front2x.jpg http://imageshack.us/scaled/large/692/front4f.jpg 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
Haight 05LGT Posted April 1, 2013 Share Posted April 1, 2013 Beautiful work! I can't wait for a video! Link to comment Share on other sites More sharing options...
mustangendsley Posted April 1, 2013 Share Posted April 1, 2013 i would be very leary of hitting anything on that. It looks like it sits lower than the stock position of the rear diff? Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted April 1, 2013 Share Posted April 1, 2013 Truly becoming a frankencar Link to comment Share on other sites More sharing options...
btlegacy Posted April 2, 2013 Author Share Posted April 2, 2013 It only sits about half an inch lower than the R160 and the suspension arms are still lower than it is so no worries there 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
frank_ster Posted April 2, 2013 Share Posted April 2, 2013 Truly becoming a frankencar hey woah there ! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 2, 2013 Share Posted April 2, 2013 300ZX Wheel Bearings. This will change the lug pattern to 5x114.3 as well. Definitely more info on this, please! [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
frank_ster Posted April 2, 2013 Share Posted April 2, 2013 yea always depends on how you can mix and match splines and such. but i would think the 160 would last for at least a little while , well as long as you dont put slicks on it . Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 2, 2013 Share Posted April 2, 2013 yea always depends on how you can mix and match splines and such. but i would think the 160 would last for at least a little while , well as long as you dont put slicks on it . It doesn't. I ran RWD in my first gen for a while. I broke two 160's and the guy I sold the car to broke 5 or 6. An R180 can. I'd be curious if it were possible to run 300Z or J30 outer cups on 5MT axles. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
frank_ster Posted April 2, 2013 Share Posted April 2, 2013 ^ what broke exactly ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
btlegacy Posted April 2, 2013 Author Share Posted April 2, 2013 Definitely more info on this, please! The LGT has a similar rear bearing module as many Nissan's and Infiniti's. I have found that the following vehicles have the same bearing module bolt pattern: Z32 300ZX N/A (Bearing ID: 42.9mm Inner Mount Pilot: 83.6mm) Z32 300ZX TT (Bearing ID: 46mm Inner Mount Pilot: 83.9mm) 90-96 Q45 (Bearing ID: 46mm Inner Mount Pilot: 83.9mm) All of these will bolt up to the Legacy but all of them have axles that are far too long so I found the Infiniti J30 which has the same 42.9mm Hub OD as the 300ZX N/A and can be pressed into the 300ZX N/A Bearing. The reason I picked the J30 is because its rear track width is 58.9 and the LGT is 58.5 so that is basically only a difference of 0.2in in axle lengths on each side. The Nissan's have 3 styles of stub axle flanges (5 Bolt, 6 Bolt, and 3x2 Bolt). The differential I chose to use was from the 97-01 Q45. I made this decision as all of the Q45's came with vLSD and they are plentiful around here. It is also in the ratio (3.69) that I was looking for to match my CTS-V 6-Speed Transmission. This diff comes with 5 bolt axles so my choices for axles included the Q45 which is much wider than the LGT, 300ZX N/A (Also too wide) and the 93-94 J30. So to put some cliff's notes here, this is the combo we have now. We are only waiting for the bearing modules to come in to verify all of the fitment. 97-01 USED Q45 Rear vLSD Differential - $125 93-94 USED J30 Axles - 2 x $35 = $70 93-94 USED J30 Hubs - 2 x $30 = $60 90-93 NEW 300ZX N/A Bearing Modules - 2 x $55 = $110 Total so far, not including our metal and fabrication cost = $365 I also went ahead and order better polyurethane bushings for diff so that will add a little extra cost and the junk yard gave me the whole J30 spindles so I will sell those and my stock stuff to make back some of the money. 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
btlegacy Posted April 2, 2013 Author Share Posted April 2, 2013 It will have at least drag radials on it once it is ready to be taken out to the strip so I would like to have some reliability there Definitely more info on this, please! yea always depends on how you can mix and match splines and such. but i would think the 160 would last for at least a little while , well as long as you dont put slicks on it . 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
