btlegacy Posted December 2, 2012 Author Share Posted December 2, 2012 We got the Miata started last night [ame=http://www.youtube.com/watch?v=ZLW_QzgEL80]LSx.LM4 V8 Miata First Start - YouTube[/ame] 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
btlegacy Posted December 3, 2012 Author Share Posted December 3, 2012 And another video of it running and me checking all the sensors. Now we are going to pull the harness to loom it up and organize it nicely 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
jsmith40a Posted December 3, 2012 Share Posted December 3, 2012 And another video of it running and me checking all the sensors. Now we are going to pull the harness to loom it up and organize it nicely Wiring looks fine, now back to work on the legacy:lol: Link to comment Share on other sites More sharing options...
V8Bait Posted December 3, 2012 Share Posted December 3, 2012 out of curiosity, what does it cost someone to put a v8 in a Miata? Roughly? What I mean is... someone drops off a Miata and says "put a v8 in this please". Of course the cost of the motor can vary based on what you use and where you get it. I only ask because its not like this is something most shops have a familiarity with. The current cost for this Miata is around $4200. Keep in mind there is no labor cost in there and we fabricated almost all of the custom parts. If you were to drop off the car at Flying Miata and have it built with similar parts and include everything that we have (Getrag LSD, Moser Axles, AC, PS, etc.) it would cost around $18-20k or $24-25k with a bigger motor A basic BossFrog conversion kit is $4250. This includes subframe, transmission mount, diff mount, axles, driveshaft, clutch master, headers, and rack mount. You would still have to add engine, transmission, diff, electronics, fuel system, etc on top of this cost plus labor I am currently Building a LS1/t-56 91' Miata and I will be around 10k in parts alone and I found my LS1/tranny from a rear ended Vette ($3500). However I am doing the V8 Roadster conversion which is a little more work/pricey than Boss Frog but I chose this kit since it sits close to the firewall and does not stick down as low as the boss frog kit.e I think once I am done I will be around 12-14k but this is including bigger brakes, suspension, ect. Your car looks great BTW, good luck with your build! Link to comment Share on other sites More sharing options...
frank_ster Posted December 3, 2012 Share Posted December 3, 2012 ^ ouch expensive ! i think i could make subaru turbo v6 conversion kits including headders trans adapter plate and accessorys mounting plate for about 2 K Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
btlegacy Posted December 3, 2012 Author Share Posted December 3, 2012 Wiring looks fine, now back to work on the legacy:lol: Soon Soon. We got the new subframe pieces tacked up last night and started on the jig for the steering rack. Hopefully that will be done by this weekend and we can drop the engine and trans in the car to make the transmission mounts 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted December 3, 2012 Share Posted December 3, 2012 ^ ouch expensive ! i think i could make subaru turbo v6 conversion kits including headders trans adapter plate and accessorys mounting plate for about 2 K I'll keep that inmind! Link to comment Share on other sites More sharing options...
btlegacy Posted December 3, 2012 Author Share Posted December 3, 2012 I am currently Building a LS1/t-56 91' Miata and I will be around 10k in parts alone and I found my LS1/tranny from a rear ended Vette ($3500). However I am doing the V8 Roadster conversion which is a little more work/pricey than Boss Frog but I chose this kit since it sits close to the firewall and does not stick down as low as the boss frog kit.e I think once I am done I will be around 12-14k but this is including bigger brakes, suspension, ect. Your car looks great BTW, good luck with your build! That is going to be a fun ride. We worked on this in pieces and did a lot of non conventional stuff including using the CTS-V which no one wants due to shifter placement and the guibo so our engine including cam, upgraded heads, hd chain and gear, and all new gaskets for the miata was around $850 and the transmission was $1300 The rear end was $220 and the custom axles $245 and we pulled alot of the stuff ourselves at local junkyards. 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
btlegacy Posted December 3, 2012 Author Share Posted December 3, 2012 ^ ouch expensive ! i think i could make subaru turbo v6 conversion kits including headders trans adapter plate and accessorys mounting plate for about 2 K Now that's a nice priced kit. I may have to buy a Legacy shell to go with the Bonneville 3.8L that I have sitting in the shop then We are also building another Miata that is going to be 1.8L Turbo and we have a FD RX7 transmission that we were looking into using. Would you be able to make an adapter plate for us and how much would that run? 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
frank_ster Posted December 4, 2012 Share Posted December 4, 2012 adapter plate can be 100$ - 500$ depending on the complexity. need to see what you need. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
btlegacy Posted December 5, 2012 Author Share Posted December 5, 2012 Thats pretty good. I will see if I can get you a drawing so you can see 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
btlegacy Posted December 9, 2012 Author Share Posted December 9, 2012 Made some progress on the subframe today http://imageshack.us/a/img14/9206/photo22kq.jpg 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
BAC5.2 Posted December 9, 2012 Share Posted December 9, 2012 You aren't moving the steering rack, are you? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
btlegacy Posted December 9, 2012 Author Share Posted December 9, 2012 The steering rack is going to be dropped 1/2 inch and compensated for with a bump steer kit 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
frank_ster Posted December 10, 2012 Share Posted December 10, 2012 just lower the a arms the same amount and your good Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted December 12, 2012 Share Posted December 12, 2012 just lower the a arms the same amount and your good That changes the camber curve, which may or may not be a problem. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
kaclaytor Posted December 19, 2012 Share Posted December 19, 2012 I am in the early stages of this swap myself, and by early stages I mean still parting out the lgt drivetrain to pay for it. lol But its nice to have your build thread to go off of and Im sure once i get deeper into it ill be pming you for help. Great progress so far and I cant wait to see your finished product! Link to comment Share on other sites More sharing options...
adreyna Posted January 31, 2013 Share Posted January 31, 2013 subscribed! Link to comment Share on other sites More sharing options...
05regalgtlauto Posted January 31, 2013 Share Posted January 31, 2013 subscribed, Granted I love the boxer. But why not! Link to comment Share on other sites More sharing options...
Haight 05LGT Posted January 31, 2013 Share Posted January 31, 2013 Updates? Link to comment Share on other sites More sharing options...
frank_ster Posted January 31, 2013 Share Posted January 31, 2013 is it done yet ? Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
adreyna Posted February 1, 2013 Share Posted February 1, 2013 ^this! Link to comment Share on other sites More sharing options...
btlegacy Posted February 12, 2013 Author Share Posted February 12, 2013 Sorry for the lack of updates guys. I have been moving into a new shop so a lot of tools and parts have been packaged up. We did manage to make a lot of progress on the subframe and steering rack mounts. Below you will see a picture of the rack mounted in the subframe with the steering rack moutn and brace seeting upside down on the mockup motor. You will also see the steering rack mount complete and painted and the subframe about 90% complete. We still have to add a few reinforcement pieces to the subframe this week and then it will be painted and in the car. http://imageshack.us/a/img835/6043/subframerack.jpg http://imageshack.us/a/img407/1936/rack1u.jpg http://imageshack.us/a/img823/4029/rackmount.jpg http://img341.imageshack.us/img341/5403/subframe.jpg 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
btlegacy Posted February 12, 2013 Author Share Posted February 12, 2013 Oh and we also made some progress on the miata as well: http://img171.imageshack.us/img171/7595/miatabay.jpg [ame=http://www.youtube.com/watch?v=NnihssS_rl4]LS1 Miata - First Drive - YouTube[/ame] [ame=http://www.youtube.com/watch?v=W6vMyFuxlOY]LS1 Miata - Magnaflow Muffler - YouTube[/ame] 2005 Legacy GT 5MT Buy my stuff Here So I can build my 6.0L V8 Legacy GT Here Link to comment Share on other sites More sharing options...
orndog Posted February 12, 2013 Share Posted February 12, 2013 Sweet jebus, subscribed Link to comment Share on other sites More sharing options...
