HAMMER DOWN Posted July 18, 2013 Share Posted July 18, 2013 About as much, as I do my mileage :lol: Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
HellShadow70 Posted July 19, 2013 Share Posted July 19, 2013 About as much, as I do my mileage :lol:Â LOL:lol: Link to comment Share on other sites More sharing options...
Turkeylord Posted October 24, 2013 Share Posted October 24, 2013 Subscribing bump, lol. Â Will be starting mine in a couple weeks, I'm sure I'll be referring to this thread often! Thanks for documenting everything so well Byron. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 24, 2013 Author Share Posted October 24, 2013 Your welcome, for a update the engine runs great. 24,000 miles on it so far. The car is a blast to drive on the backroads. 1/2-3/4 throttle, in a gear, quick shifts and your doing 60mph in no time. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
caramall2 Posted October 29, 2013 Share Posted October 29, 2013 (edited) I just read this entire thread. Great info as others have said and glad it's driving well! Have thought about doing a rebuild myself but awful lot of time and possible issues :-0 More power to you and if I do, I'm keeping your notes handy! Max -- Wish someone had torn down your engine to see what was actually wrong. How much oil were you putting in per mileage? -- Did you do a leak down test on it before you took it out? Curious what results were if you did. (Sorry if I missed it.) Mike -- Have you seen a crack ringland that still gives good compression numbers? I've heard of this happing as the upper ring can hold pressure even if lower ringland cracked (?). -- Isn't a leak down test just as important? You can also listen to hear where the leak is coming from to better tell if valves (intake or exhaust), piston rings, etc), right? Also, sometimes compression numbers are ok but leak down not, right? -- If a tune isn't knocking, is it at least safe? (E.g. when everyone talks about unsafe tunes, is the issue almost always that it's knocking?) I know LittleBlue has his good sticky on monitoring knock sum, etc., to check. All that said, it seems best to: - check situation if losing oil, etc. -- check knock (see LittleBlue's sticky in tuning forum), -- get both a compression AND leak down test -- check injectors (you could have decent AFR but one injector be off possibly, right? You should probably see knock though, correct?) - rebuild -- Go with forged pistons -- Get a good tune and make sure to look for knock (I'd always do that even if someone tuned for me...just to be safe ;-) Edited October 29, 2013 by caramall2 Link to comment Share on other sites More sharing options...
Max Capacity Posted October 29, 2013 Author Share Posted October 29, 2013 I didn't do a leak down test. I was at about a qt of oil every 700 miles. I have a long term plan for the car, so I figured I do the engine on my terms, not wait till something happened. I'm at that stage in my life. It feels good to be here. 59 y/o now. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
LatentWagen Posted November 13, 2013 Share Posted November 13, 2013 I'm at that stage in my life. It feels good to be here. 59 y/o now. With that kind of mileage on a stock body, you should consider a tune. Apparently that's where it's at. Not sure where I heard that tho  Bump for this thread cause I'm sizing up my options. Coming up on 150k miles, still on the stock motor, turbo, and clutch. Since I'll probably need to replace all this stuff within the next 50k, I am thinking about just doing it ONCE with a full build... LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Max Capacity Posted November 13, 2013 Author Share Posted November 13, 2013 Some will say get a compression test done first. If the car is new to you that may be a good idea. If you've had the car for years, you should have a good feel for the health of the engine. If the motors solid, a tune is a good idea. Then save up your money and when it's time buy the parts and do it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
LatentWagen Posted November 13, 2013 Share Posted November 13, 2013 That's a good idea. Seems like it's better to know for sure. Â Car is currently running AP OTS stage 1. In my possession for ~15k miles now. It was having some light hesitation issues early on but replaced o2 sensors, and more recently got off the stock tune. Both improved the car, but it wasn't completely there until I did a fuel injector cleaning with Gumout or whatever. Since then the idle and increased "smooth" has been great. Still, I plan to replace the IM gaskets, clean or replace the OCVs and/or MAF, replace TMIC>BOV gasket, and tighten/replace misc vacuum hoses and clamps. Already have most of the OEM replacement gaskets, as well as a BP TMIC kit, thanks BMB. May as well do the compression check and change the plugs at the same time. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2013 Author Share Posted November 14, 2013 You may also want to try a can of Berryman B-12 injector cleaner. See the thread here about fuel additives. I put some in my wagon yesterday, $4.87 with tax, can't hurt. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
Drogos Posted November 14, 2013 Share Posted November 14, 2013 You may also want to try a can of Berryman B-12 injector cleaner. See the thread here about fuel additives. I put some in my wagon yesterday, $4.87 with tax, can't hurt. you sure it won't hurt anything? How does it affect octane rating ? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 14, 2013 Author Share Posted November 14, 2013 I guess you missed this thread, remember your only putting in about 1oz per gallon of gas. Plus some of the chemicals in the stuff adds/boost octane. I wouldn't use these things all the time, IMO once can't hurt. http://legacygt.com/forums/showthread.php/fuel-additives-do-youi-if-so-recommendationsi-215679.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
mitech Posted November 24, 2013 Share Posted November 24, 2013 pmed Link to comment Share on other sites More sharing options...
Merc6 Posted June 5, 2014 Share Posted June 5, 2014 I Read the thread but in case I messed it, did you also replace the pcv assembly? Now I'm sitting here with an 08 BBBB block afraid of #4 putting me back where I started off a few years back slowly piecing the car together again.  http://i90.photobucket.com/albums/k280/merc6/LGT/th_02051931.jpg http://i90.photobucket.com/albums/k280/merc6/LGT/th_0ef6c535.jpg 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted June 5, 2014 Author Share Posted June 5, 2014 No, I did the standard test for it. If it rattles when you shake it, its good. Mine rattled easily with very little shaking. If I did it again...for piece of mind, for the few dollars it cost, I'd replace it. Think about tot overall cost of the project...the PCV is cheap. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
compsurge Posted June 5, 2014 Share Posted June 5, 2014 I Read the thread but in case I messed it, did you also replace the pcv assembly? Now I'm sitting here with an 08 BBBB block afraid of #4 putting me back where I started off a few years back slowly piecing the car together again.  http://i90.photobucket.com/albums/k280/merc6/LGT/th_02051931.jpg http://i90.photobucket.com/albums/k280/merc6/LGT/th_0ef6c535.jpg Get it back on the road! Are you insinuating it being BBBB is bad? Link to comment Share on other sites More sharing options...
Merc6 Posted June 5, 2014 Share Posted June 5, 2014 Get it back on the road! Are you insinuating it being BBBB is bad? no, that 08 apparently is. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
compsurge Posted June 5, 2014 Share Posted June 5, 2014 Oh yeah. Well, is it new or from a wrecked '08? Link to comment Share on other sites More sharing options...
Merc6 Posted August 20, 2014 Share Posted August 20, 2014 Oh yeah. Well, is it new or from a wrecked '08? New, sitting in a dealership unsold forever. It was about to be shipped off but I showed up a day before. My bad for super late reply, I'm modding 2 other car forums. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted August 20, 2014 Author Share Posted August 20, 2014 Hey stop hi jacking my thread...LOL  FWIW, I have over 40,000 miles on the ej257. Car runs great, has the noises of a 10 y/o 195,000 mile car. Still driving it everyday.  Last Saturday on the way to HD to return a rental item to HD, I'm in the left lane on the highway, I notice this truck driver looking in his mirror at me, he looks about 3 times and smiles when he notices that I've seen him. He hooks his horn 3 times. I guess he liked the wagon. Last night at the local garage while I was waiting to talk to the owner, I truck drives in, one of the employee's walks out to talk to him. I see them looking at the wagon, I walk over and I hear the young kid say, " that's the Obsidian Black Pearl". The guy say's,"that paint is gorgous". The sun was on it and the blue and silver was really visible. I said thanks. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
Merc6 Posted August 20, 2014 Share Posted August 20, 2014 That's good to hear, most likely this car won't become My DD again so it should stay fixed longer. I miss people staring at my car and giving me props on how it sounded. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Merc6 Posted September 2, 2014 Share Posted September 2, 2014 For the half moons, is #4 what I am trying to buy separate of the gasket kit? Â http://opposedforces.com/parts/legacy/us_b13/type_6/engine/cylinder_head/illustration_2/ 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted September 2, 2014 Author Share Posted September 2, 2014 https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=half%20moon%20gasket%20subaru or just tell the guy at the parts counter at the dealer what you need, they can look it up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted October 7, 2014 Share Posted October 7, 2014 You used ej257 and d25 heads, did you use stock head gaseket or get something bigger to correct the compression? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 7, 2014 Author Share Posted October 7, 2014 I was told to get the engine gasket set for my year car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
