thestratomaster Posted April 6, 2011 Share Posted April 6, 2011 I think the OEM's should work out fine then in that case. Save a bit of money too. Definitely gonna do this with a rear bar though, would just be way to stiff up front otherwise. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 6, 2011 Share Posted April 6, 2011 I did this on the lift while changing out a leaking mid-pipe to manifold gasket def worth having the suspension grounded and room to work Link to comment Share on other sites More sharing options...
thestratomaster Posted June 6, 2011 Share Posted June 6, 2011 do these energy suspension bushings come with the mounts pictured those of you who ordered them? http://www.energysuspensionparts.com/proddetail.asp?prod=9.5129_Front Link to comment Share on other sites More sharing options...
CDN 2.5i Posted June 6, 2011 Share Posted June 6, 2011 Yes, they do. Also indicated on the product details: Includes 2 - Sway Bar Bushings (one for each side of the vehicle) 2 - Outer Brackets (one for each side of the vehicle) Link to comment Share on other sites More sharing options...
thestratomaster Posted June 6, 2011 Share Posted June 6, 2011 Yes, they do. Also indicated on the product details: Includes 2 - Sway Bar Bushings (one for each side of the vehicle) 2 - Outer Brackets (one for each side of the vehicle) didn't even see the tabs to switch to that on the page Thanks! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 6, 2011 Share Posted June 6, 2011 You can also use STi specific links as well since they are shared with the Forester I have stock FOrester link now but those things are beefy Link to comment Share on other sites More sharing options...
m_dogg Posted January 6, 2012 Share Posted January 6, 2012 Bump for an old thread - can anyone confirm these bushings/brackets work ok with the Tribeca bar? http://www.energysuspensionparts.com/proddetail.asp?prod=9.5129_Front Thanks! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 6, 2012 Share Posted January 6, 2012 I dont have any experience with that particular set of bushings but they are 25mm so they should fit around the bar. Make sure you grease them up well before you bolt it on. Poly bushing are the way to go for the longer haul Link to comment Share on other sites More sharing options...
N.sane Posted January 6, 2012 Share Posted January 6, 2012 Bump for an old thread - can anyone confirm these bushings/brackets work ok with the Tribeca bar? http://www.energysuspensionparts.com/proddetail.asp?prod=9.5129_Front Thanks! http://legacygt.com/forums/showpost.php?p=2600155&postcount=74 Link to comment Share on other sites More sharing options...
m_dogg Posted January 7, 2012 Share Posted January 7, 2012 ^Now I see that he painted the bar red That totally threw me off. Link to comment Share on other sites More sharing options...
Vinny78 Posted January 14, 2012 Share Posted January 14, 2012 im doing this within the next week, i have my tribeca sway bar and bushings already just need to order my rear perrin 25 mm. will the gt perrin rear bar work on an n/a car. also is 25 mm in front and rear to much or it should be fine? Link to comment Share on other sites More sharing options...
thestratomaster Posted January 14, 2012 Share Posted January 14, 2012 the rears are the same between gt's and 2.5i. the fronts are the ones that are different. 25 is gonna be stiff but will be fine depending on what you want out of your car Link to comment Share on other sites More sharing options...
Vinny78 Posted January 17, 2012 Share Posted January 17, 2012 just ordered my perrin 25 mm rear sway cant wait to get it!!! Link to comment Share on other sites More sharing options...
Vinny78 Posted January 17, 2012 Share Posted January 17, 2012 for the tribeca bushing in front you just shave the bottom a little ?? Link to comment Share on other sites More sharing options...
Vinny78 Posted January 17, 2012 Share Posted January 17, 2012 just got off phone with subimods, rear perrin 25 mm has been dicontinued =[ so i went with white line 20 mm rear instead=[ bummer Link to comment Share on other sites More sharing options...
Vinny78 Posted January 17, 2012 Share Posted January 17, 2012 also dont mean to be a pain but i work at subaru and got an old tribeca bar off a 2006 will that old style bar work with newer style bushings? Link to comment Share on other sites More sharing options...
thestratomaster Posted January 19, 2012 Share Posted January 19, 2012 just got off phone with subimods, rear perrin 25 mm has been dicontinued =[ so i went with white line 20 mm rear instead=[ bummer i have that rear bar. it's quite an improvement over stock. I think you'll be more than satisfied I recommend setting it to stiff Link to comment Share on other sites More sharing options...
Vinny78 Posted January 19, 2012 Share Posted January 19, 2012 ya i def noticed an improvement, im just waiting on my avo sway bar reinforcement, so i still gotta go a little easy around corners. The tribeca bar and forester end links worked out perfect and feel great. Link to comment Share on other sites More sharing options...
m_dogg Posted January 19, 2012 Share Posted January 19, 2012 just got off phone with subimods, rear perrin 25 mm has been dicontinued That blows....is there any other place where I could get one or am I too late for the good stuff Link to comment Share on other sites More sharing options...
Vinny78 Posted January 19, 2012 Share Posted January 19, 2012 i couldnt find a place=[ maybe if you search real hard, it sucks but owell. Link to comment Share on other sites More sharing options...
N.sane Posted January 19, 2012 Share Posted January 19, 2012 Cusco is "good stuff". Their 21mm solid rear sway bar is probably the stiffest one you can get for the rear nowadays. Link to comment Share on other sites More sharing options...
shtbxr22 Posted January 20, 2012 Author Share Posted January 20, 2012 I guess I got lucky. I got front and rear perrin 25's, and rear camber links. Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted January 27, 2012 Share Posted January 27, 2012 I had set my perrins to soft after being on stiff front and rear for almost a 2yrs. I don't miss feeling every little pebble and bump in the road. I would get upgraded front endlinks I broke a oem style one on the left passeneger side and had to order some RalliTEK HD front endlinks. Link to comment Share on other sites More sharing options...
ported Posted February 8, 2012 Share Posted February 8, 2012 Whiteline 22mm adj. front bar & 20mm adj. rear bar. Whiteline spherical adjustable endlinks front/rear King springs front/rear KYB Excel front/rear 2008 2.5i Outback Parts bought from: Dales Alignment in Langley BC (bars/links) Primitive Racing Oregon (springs/struts/shocks) Link to comment Share on other sites More sharing options...
toolbox1 Posted February 16, 2012 Share Posted February 16, 2012 Anyone running a 21 rsb with the 25 in the front? If so what are your impressions? Looking to possibly do this. Kenny Link to comment Share on other sites More sharing options...
