2.5i Subaru 25mm Front sway bar.
  • Replies 285
  • Created
  • Last Reply
I had an hard time installing the front Sb ! Nothing complicated really, i wasn't totally aware of a couple of thing so it took me a lot of time to remove the old one lol
So , i did install both sway bar + the front coilovers .
Tomorrow , rear coilovers and im done. :lol:
Sent you PM with the torque specs. What rear sway bar are you using now?
I just didnt wanna go off topic too much; I sent him torque specs for the coilover install. But if you insist...
The 3 little nuts that hold the front top mounts in place do not need a lot of tightening, only 14.5 ft-lb. The studs are VERY easy to snap (I'd snapped them twice), so once it's snug, leave it. I'd suggest using the smallest ratchet you have and tightening it with your pinky and ring finger lol.
Conversely, the 2 bigass nuts/bolts on the bottom of the front strut are tightened to a whopping 112.1 ft-lb.
Rear top mount nuts are tightened to 22.4 ft-lb, and the bottom one is tightened to 46 ft-lb.
Specs are taken straight from the Subaru service manual.
So , i had a weird noise when hitting a pothole .... was thinking it was related to my coilovers since i installed them at the same time as my SB , but .....
im a ******* noob ....
the strange noise was in fact a endlink not tighted enough .
Everything is fine now . Im really happy with the setup !
  • 2 weeks later...
  • 2 weeks later...
N.Sane, could you please, list your parts?
Thanks!
Standard = Installed, Italic = Not installed
WHEELS & TIRES
OEM Saab 9-2X Aero (made by Enkei with MAT) - 17x7, +55
Firestone Firehawk Wide Oval Indy 500 - 215/45/17
SUSPENSION
RaceComp Engineering Tarmac 1 coilovers
OEM Legacy Spec.B front strut top mounts
STI Genome front strut bar
STI Group N front arm rear bushings
Whiteline front sway bar end links
Whiteline front sway bar lateral locks
OEM Tribeca 25mm front sway bar
Kartboy rear sway bar end links
AVO 20mm rear sway bar
AVO rear sway bar mount reinforcement brackets
AVO rear underbody braces
BRAKES
OEM Legacy GT calipers front & rear
DBA 4000 Series slotted rotors front & rear
Carbotech Bobcat 1521 brake pads front & rear
POWERTRAIN
GrimmSpeed lightweight crank pulley
Group A throttle body spacer
AVO mufflers
AVO air filter
STI Group N pitch stop mount
RalliTEK transmission mount bushing
INTERIOR
OEM Legacy GT MOMO leather-wrapped steering wheel
OEM Legacy GT leather-wrapped shift knob
OEM Panasonic subwoofer
EXTERIOR
BlackTop Aero front lip spoiler
LIGHTING
Apexcone Raptor V2 55W 6000K HID low beams
PIAA Ion Crystal 55W fog lights
PIAA rear licence plate LEDs
WINTER
OEM 2007 Legacy 2.5i wheels; 17x7, +55
Hankook iPike W409; 225/45/17
Rally Armor urethane rally mud flaps
WOW!
Quite an investment you have there!
Thanks for the list!
I just got parts from AVO.
Cab bushings, solid front links and front LCA bushings...Gotta start from the base.
All original bushings need replacement. No point to add other parts before the base is solid.
I will be starting installation tomorrow.
Hope it will go smoothly as i am kind of a newbie at car mechanics.
Pretty excited though :-)
WOW!
Quite an investment indeed. The modding has been ongoing for the last 4 years :spin:
I like the way you think; replacing worn items first. You should see a considerable improvement in the car's stability with the control arm bushings installed.
Let me know if you need/want the Subaru service manual since I have it in PDF.
WHEELS & TIRES
SUSPENSION
BRAKES
POWERTRAIN
AVO mufflers
AVO air filter
INTERIOR
EXTERIOR
LIGHTING
WINTER
Which end links did you use with your Tribeca bar?? (Which model were they meant for)
I'm going to be using the Whiteline end links I have right now. It should work for the Tribeca bar as well since it's listed for both the front of the Legacy and the rear of the Forester.
Yup good point and recognition on the parts. The stock FXT endlinks work well if you didn't already have those sexy Whitelines :lol:
http://legacygt.com/forums/attachment.php?attachmentid=128918&stc=1&d=1347845812
Picture of the goodies i have installed.
getting both control arms off and back on was a bit tedious, but the bushing part was a headache.
Finally went to a shop and paid 60$ to get original bushings off and the new LCA on.
The ride is firmer than with the soft original soft bushings, at low speeds, the feeling of small bumps is enhanced, at highway speeds, feels much more solid.
Rode about 150 miles today, very pleased with the results.
I need a wheel alignment but would rather make a few more changes before I spend the money.
Any suggestions for the rear bushings, cant seem to find much on AVO's site??
