GEE-OTTO Posted September 17, 2012 Share Posted September 17, 2012 Rear diff bushings would sure up the rear end under hard shifts. And the AVO brace set will help with tying the rear suspension bits together. Best bet (easiest) rear bar and links. Solid 20mm bar and links. Link to comment Share on other sites More sharing options...
pipi135 Posted September 17, 2012 Share Posted September 17, 2012 There wont really be a problem, you may just increase understeer if you're driving at the limit. I highly doubt your clunking problem is related to the bar itself though. sorry i should have been more specific. the bushings are worn out Link to comment Share on other sites More sharing options...
N.sane Posted September 17, 2012 Share Posted September 17, 2012 sorry i should have been more specific. the bushings are worn out Ooh, ok. That makes more sense Maybe get some Energy Suspension bushings. They come with beefier brackets too. Lube the bushings up real good and wrap some teflon tape around the sway bar to prevent squeaking. Link to comment Share on other sites More sharing options...
Manchito Posted September 20, 2012 Share Posted September 20, 2012 Standard = Installed, Italic = Not installed WHEELS & TIRES OEM Saab 9-2X Aero (made by Enkei with MAT) - 17x7, +55 Firestone Firehawk Wide Oval Indy 500 - 215/45/17 SUSPENSION RaceComp Engineering Tarmac 1 coilovers OEM Legacy Spec.B front strut top mounts STI Genome front strut bar STI Group N front arm rear bushings Whiteline front sway bar end links Whiteline front sway bar lateral locks OEM Tribeca 25mm front sway bar Kartboy rear sway bar end links AVO 20mm rear sway bar AVO rear sway bar mount reinforcement brackets AVO rear underbody braces BRAKES OEM Legacy GT calipers front & rear DBA 4000 Series slotted rotors front & rear Carbotech Bobcat 1521 brake pads front & rear POWERTRAIN GrimmSpeed lightweight crank pulley Group A throttle body spacer AVO mufflers AVO air filter STI Group N pitch stop mount RalliTEK transmission mount bushing INTERIOR OEM Legacy GT MOMO leather-wrapped steering wheel OEM Legacy GT leather-wrapped shift knob OEM Panasonic subwoofer EXTERIOR BlackTop Aero front lip spoiler LIGHTING Apexcone Raptor V2 55W 6000K HID low beams PIAA Ion Crystal 55W fog lights PIAA rear licence plate LEDs WINTER OEM 2007 Legacy 2.5i wheels; 17x7, +55 Hankook iPike W409; 225/45/17 Rally Armor urethane rally mud flaps really cool to see this . Im almost done with what i wanted to do , but for 1 year of ownership , i did a lot imo lets see , just for fun ... WHEELS & TIRES BBS STI 2004 Silver - 17x7.5, +55 Falken ZIEX ZE-912 225/55/17 Muteki M12 x 1.25 closed deep blk Rally Armor Mudflap Dark Grey OEM 2007 Legacy 2.5i wheels; 16x7, +55 Hercules Tire Avalanche 205/45/16 OEM Lug nut SUSPENSION RaceComp Engineering Tarmac 1 coilovers OEM Legacy Spec.B front strut top mounts GTSPEC Front strut bar GTSPEC Rear strut bar Forester 04 front sway bar end links OEM Tribeca 25mm front sway bar AVO rear sway bar end links Whiteline 20mm rear sway bar AVO rear sway bar mount reinforcement brackets AVO rear underbody braces POWERTRAIN & ENGINE BAY Kartboy 12mm XL Exhaust Hangers AVO cat-Back 3" AVO air filter Subtle Alternator & Radiator cover JDM Battery and Reservoir Covers Rallisport Headers Odyssey Battery 35-PC1400T Hella SuperTone Horn Kit BLK INTERIOR & ELECTRONICS Weathertech BLK Floorliner Front & Rear ETC DBW Throttle Controller RREV Sports Automatic Carbon Fiber Shifter Surround Viper 791xv Alarm/Start Viper Smart Start JVC KW-AVX740 2 x 12" MTX Subwoofer MTX 400W RMS AMP 4channel Stinger Power Capacitor GPS Cubby Mounts EXTERIOR Yakima Roof Rack Q TOWERS System 48" CrossBars + 44" Fairing + FrontLoader Debadged RREV PU Front Lip RREV FRP Front Grill TRF Rear Diffuser Replica STI Style Trunk spoiler LIGHTING XenonExpert Xtreme HID & Phillips bulb 4300k H7 Nokya 2500k H3 55 W Fog lights (NOK7515) Toshiba HIR 9011 High Beam R-REV Hyper LED Kit R-REV Reverse LED Cree Led Strip Red 2inch (Footwell) Whats left to do : LCA Control arms , couple of bushing and i might be done. Link to comment Share on other sites More sharing options...
N.sane Posted September 20, 2012 Share Posted September 20, 2012 You did all that in 1 year?! I feel sorry for your wallet Link to comment Share on other sites More sharing options...
Manchito Posted September 20, 2012 Share Posted September 20, 2012 You did all that in 1 year?! I feel sorry for your wallet Do you understand why i bought a 2.5i Link to comment Share on other sites More sharing options...
subarulegay Posted September 20, 2012 Share Posted September 20, 2012 ok so just want to make sure, can we use any aftermarket legacy front end links or do i need to get any rear forester end links? Link to comment Share on other sites More sharing options...
N.sane Posted September 20, 2012 Share Posted September 20, 2012 rear Forester end links only replace the front end links if you're using the Tribeca front sway bar. If you're not using a Tribeca front sway bar, use Legacy specific front end links. HOWEVER, some solid end link designs will fit both the front of the Legacy and the rear of the Forester because you can change the orientation of the shape from a C-shape to an S-shape and vice versa. For example, Whiteline solid front end links for the Legacy are also listed for the rear of the Forester. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 21, 2012 Share Posted September 21, 2012 rear Forester end links only replace the front end links if you're using the Tribeca front sway bar. If you're not using a Tribeca front sway bar, use Legacy specific front end links. HOWEVER, some solid end link designs will fit both the front of the Legacy and the rear of the Forester because you can change the orientation of the shape from a C-shape to an S-shape and vice versa. For example, Whiteline solid front end links for the Legacy are also listed for the rear of the Forester. Well put Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 21, 2012 Share Posted September 21, 2012 http://legacygt.com/forums/attachment.php?attachmentid=128918&stc=1&d=1347845812 Picture of the goodies i have installed. getting both control arms off and back on was a bit tedious, but the bushing part was a headache. Finally went to a shop and paid 60$ to get original bushings off and the new LCA on. The ride is firmer than with the soft original soft bushings, at low speeds, the feeling of small bumps is enhanced, at highway speeds, feels much more solid. Rode about 150 miles today, very pleased with the results. I need a wheel alignment but would rather make a few more changes before I spend the money. Any suggestions for the rear bushings, cant seem to find much on AVO's site?? how do you orient the +.50 camber bushing properly ?? If that makes sense Link to comment Share on other sites More sharing options...
subarulegay Posted September 22, 2012 Share Posted September 22, 2012 last question i promise...which year forester is the rear end link from? Link to comment Share on other sites More sharing options...
Manchito Posted September 22, 2012 Share Posted September 22, 2012 last question i promise...which year forester is the rear end link from? Forester Rear end links: 20470SA011 i think those are from 2004! Link to comment Share on other sites More sharing options...
shark_22 Posted October 31, 2012 Share Posted October 31, 2012 I have hear the 25mm fsb of the tribeca is like a 23mm because the lengt/form, somebody can confirm that? Link to comment Share on other sites More sharing options...
shtbxr22 Posted October 31, 2012 Author Share Posted October 31, 2012 you mean the 25mm tribeca one is like a 23mm hollow one? mayhaps, but either way it is much better than the stock toothpick. Link to comment Share on other sites More sharing options...
shtbxr22 Posted October 31, 2012 Author Share Posted October 31, 2012 Forester Rear end links: 20470SA011 i think those are from 2004! i guess 2003-2008 Link to comment Share on other sites More sharing options...
BeKnwn Posted November 1, 2012 Share Posted November 1, 2012 I'm actually about to sell mine during the summer its amazing but now its winter and raining all the time I feel my front end giving out just from simple 25mph turns lol I don't like that idea so imma just down to the 20mm whiteline for 3rd gens and keep my rear at 22mm Link to comment Share on other sites More sharing options...
m_dogg Posted November 7, 2012 Share Posted November 7, 2012 Picked up Whiteline 20mm adjustable rear bar, description says the bushings are included, I'm assuming no brackets? Do I need 20mm specific brackets or will the stockers work? Link to comment Share on other sites More sharing options...
N.sane Posted November 7, 2012 Share Posted November 7, 2012 It was a hit or miss for me. When I upgraded from OEM JDM 20mm to AVO 20mm, the AVO bushings were too thick, so I re-used the RalliTEK bushings that came with the OEM JDM bar. Link to comment Share on other sites More sharing options...
Manchito Posted November 7, 2012 Share Posted November 7, 2012 Picked up Whiteline 20mm adjustable rear bar, description says the bushings are included, I'm assuming no brackets? Do I need 20mm specific brackets or will the stockers work? Got the same thing installed , and i did use the stock brackets with no issues . The front 25mm with he tribeca bushing + the stock bracket is where i had to swear for an hour straight Link to comment Share on other sites More sharing options...
N.sane Posted November 7, 2012 Share Posted November 7, 2012 I'm glad I purchased Energy Suspension bushings for the front then. They come with new brackets Link to comment Share on other sites More sharing options...
m_dogg Posted November 8, 2012 Share Posted November 8, 2012 Ended up getting energy suspension bushing/bracket 25mm & 20mm. Need to spray all these bolts with liquid wrench or something so the install won't be a beach on Saturday My Tribeca bar and end links should arrive tomorrow. Can't wait! Link to comment Share on other sites More sharing options...
m_dogg Posted November 10, 2012 Share Posted November 10, 2012 Well, tomorrow http://i182.photobucket.com/albums/x236/skurwiel666/CIMG0099.jpg http://i182.photobucket.com/albums/x236/skurwiel666/CIMG0097.jpg Link to comment Share on other sites More sharing options...
CDN 2.5i Posted November 10, 2012 Share Posted November 10, 2012 If you can, install them one after another, but driving in between so you can get a feel for what each did. Both will yield significant improvements - nice to gauge how much each did individually... Link to comment Share on other sites More sharing options...
m_dogg Posted November 12, 2012 Share Posted November 12, 2012 If you can, install them one after another, but driving in between so you can get a feel for what each did. Both will yield significant improvements - nice to gauge how much each did individually...That's what I did. I should install the front tomorrow. Very happy with how the car responds to aggressive cornering, it was money well spent. Drove on the freeway with 40mph wind gusts this afternoon, feels like it gained some stability. Patient is ready http://i182.photobucket.com/albums/x236/skurwiel666/CIMG0175.jpg This made the job easier. http://i182.photobucket.com/albums/x236/skurwiel666/CIMG0164.jpg Out with the old. http://i182.photobucket.com/albums/x236/skurwiel666/CIMG0162.jpg Reinforcement brackets on. http://i182.photobucket.com/albums/x236/skurwiel666/CIMG0166.jpg I was worried about having aligning issues with Kartboys endlinks but it didn't turnout that bad. http://i182.photobucket.com/albums/x236/skurwiel666/CIMG0171-1.jpg http://i182.photobucket.com/albums/x236/skurwiel666/CIMG0170.jpg http://i182.photobucket.com/albums/x236/skurwiel666/CIMG0172-1.jpg I couldn't believe how quiet this car is with no mufflers http://s182.beta.photobucket.com/user/skurwiel666/media/CIMG0169.mp4.html Link to comment Share on other sites More sharing options...
m_dogg Posted November 14, 2012 Share Posted November 14, 2012 Wraping up with front bar....damn endlinks...had to cut em with a dremel. Beer break Link to comment Share on other sites More sharing options...
