shtbxr22 Posted March 27, 2010 Author Share Posted March 27, 2010 I ran mine for more than a year, and the inserts never came apart. I'm pretty sure kartboy is the only one to carry the inserts. idk. Link to comment Share on other sites More sharing options...
CDN 2.5i Posted March 27, 2010 Share Posted March 27, 2010 Progressive makes a lower cost alternative for the RSB reinforcement brackets... not quite as pretty but just as effective IMO - last I heard they were backordered though. Link to comment Share on other sites More sharing options...
D_J Posted March 28, 2010 Share Posted March 28, 2010 I ran mine for more than a year, and the inserts never came apart. I'm pretty sure kartboy is the only one to carry the inserts. idk. Is this the one you bought? Sounds like the cheaper endlinks wear out quickly and the AVO's are probably too short for the Perrin bar anyways. http://www.fredbeansparts.com/servlet/the-3835/Kartboy-Subaru-Legacy-GT/Detail Link to comment Share on other sites More sharing options...
shtbxr22 Posted March 28, 2010 Author Share Posted March 28, 2010 yep. those be the ones. Link to comment Share on other sites More sharing options...
alexJay Posted April 2, 2010 Share Posted April 2, 2010 Reading through this thread it seems like the Tribeca front sway bar upgrade is specific for the 05 and newer 2.5i models. Do any of you guys know if this would be a viable upgrade on my 04 BH 2.5i legacy wagon? I just got a 22mm rear sway in and i need to balance it out with a beefier front bar. I noticed some back end wagging on the icy mountain roads that is a bit sketchy at times. The Tribeca bar seems like it would be perfect, not to mention cheap. Link to comment Share on other sites More sharing options...
shtbxr22 Posted April 2, 2010 Author Share Posted April 2, 2010 No idea. you may just be the pioneer. if it doesn't work, i'm sure someone would take it off your hands here. Link to comment Share on other sites More sharing options...
D_J Posted April 15, 2010 Share Posted April 15, 2010 The Tribeca sway bar and Forester endlinks fit perfect on my 2.5i Outback. However the rear Perrin bar barely fit without hitting the exhaust. Also I just realized that the Outback rear suspension is angled differently than the Legacy. The Kartboy endlinks did not fit. I had to bring it to the dealer and they traded me for some Whiteline endlinks. Otherwise it looks good to go. Used the Energy suspension heavy duty bushings and synthetic Mobil 1 grease. Will post some photos and more feedback later. Link to comment Share on other sites More sharing options...
tito_b0y Posted April 24, 2010 Share Posted April 24, 2010 Now, do most of you auto-x with the 2.5i? Anyone go from 19-22mm setups to this setup? Reason I'm asking is because I currently have the Rallitek 19mm RSB installed with stock endlinks on a daily driver with a bit of spirited driving, and I'm thinking of doing the 25mm f/r setup just to satisfy my "what if" curiosity of going as big as I can. 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
N.sane Posted April 25, 2010 Share Posted April 25, 2010 I dont Auto-X yet, but here's some general knowledge I've learned from XenonK, the track whore of LGT.com I think it's just better to spend that money (as opposed to bigger sways) on the shocks.. too much bar will cause the inside tire to lift up because the opposite side shock will be under full compression and the spring will also be not stiff enough to keep the bar affective.. if you go too big, it'll show and you'll probably end up giving up overall grip.. better start becoming the smoothest driver out there to make it work. Also, dont forget that you'll need stickier tires to keep up with bigger sways. Big sways + mediocre tires = slip n slide Link to comment Share on other sites More sharing options...
tito_b0y Posted April 25, 2010 Share Posted April 25, 2010 Yea, I read that too haha, but was he referring to auto-x, daily driving, or both? I don't think I drive spiritedly enough to put the opposite side shock under full compression. Then again, I may be wrong. I'm also running on ContinentalExtreme DWS all-seasons, which I know is mediocre. This is my suspension wish list: Tribeca 25mm FSB with Forester endlinksPerrin 25mm RSB with Kartboy endlinksAVO mount bracketsEnergy Suspension bushings Right now, springs+shocks/coilovers will have to wait until I get a summer job, or maybe even later. 2006 SWP 3.0R 5EAT VDC BBQ 2008 OBP 2.5i 4EAT BBQ [RIP] Link to comment Share on other sites More sharing options...
D_J Posted April 26, 2010 Share Posted April 26, 2010 My Nokian WR-G2's are about as sticky as a tire gets. Not a performance tire but still seems like a good fit for these bars. I can tell the tires need to be strong to handle the stiff 25mm bars. This has dramatically improved the handling, reduced the wicked Outback body roll and even helps going over speed bumps. Link to comment Share on other sites More sharing options...
Subie2.5i Posted April 26, 2010 Share Posted April 26, 2010 I autox my 2.5i and my set up is perrin 22f/25r sways, strut tower bars, bc coilovers. Next is better tires and endlinks. Link to comment Share on other sites More sharing options...
shtbxr22 Posted August 4, 2010 Author Share Posted August 4, 2010 anyone else? Link to comment Share on other sites More sharing options...
soloz2 Posted November 6, 2010 Share Posted November 6, 2010 I'm thinking the 25mm front TriBeCa swaybar paired with one of the new Hancock 22mm rear bars might be a perfect setup and a bit more neutral than stock. Does this sound right? Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
N.sane Posted November 6, 2010 Share Posted November 6, 2010 That should be fine. A lot of LGT's run 25F/22R Perrin bars Link to comment Share on other sites More sharing options...
shtbxr22 Posted November 6, 2010 Author Share Posted November 6, 2010 25/25 here. I prefer the ass out more. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted February 10, 2011 Share Posted February 10, 2011 Hey I got this setup for $134 SHIPPED. Link to comment Share on other sites More sharing options...
shtbxr22 Posted February 10, 2011 Author Share Posted February 10, 2011 smoking deal! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted February 10, 2011 Share Posted February 10, 2011 My only question is how difficult was it for you snake the bar through the suspension and lower engine cradle ? Link to comment Share on other sites More sharing options...
cybonic Posted February 10, 2011 Share Posted February 10, 2011 spirited driving on a S curve road. rear will slide progressively on s1 evo tyres. just need to catch it. good compliments from my peers who have driven my car. Sus setup: Aragosta Coils 9K/8K Springrate, Front & Rear Carbing Strut Bars, Cusco 23mm/21mm Sway Bars with AVO Mount & Kartboy Endlinks, Corazon Rear 2point brace Link to comment Share on other sites More sharing options...
shtbxr22 Posted February 10, 2011 Author Share Posted February 10, 2011 My only question is how difficult was it for you snake the bar through the suspension and lower engine cradle ? Install was very easy. having a lift might help though. Link to comment Share on other sites More sharing options...
thestratomaster Posted April 5, 2011 Share Posted April 5, 2011 How come you have to run the rear forester links? Is the bar further away from the mounting point than the stock bar? Link to comment Share on other sites More sharing options...
shtbxr22 Posted April 5, 2011 Author Share Posted April 5, 2011 the bar is wider, and the S shaped links won't work. the forester ones are C shaped. Link to comment Share on other sites More sharing options...
thestratomaster Posted April 5, 2011 Share Posted April 5, 2011 will any link made for the forester work then? As long as they are rear's Link to comment Share on other sites More sharing options...
shtbxr22 Posted April 6, 2011 Author Share Posted April 6, 2011 That should be a safe bet. Although, the rear forester links are some of the most stout ones i've ever seen on a subaru next to the tribeca ones. IIRC, the rear forester, and F/R Tribeca ones are the only all metal ones i've seen. Link to comment Share on other sites More sharing options...
