jim1969 Posted January 13, 2009 Share Posted January 13, 2009 my injectors and pump will be going in the near future. Link to comment Share on other sites More sharing options...
testes1010 Posted January 13, 2009 Author Share Posted January 13, 2009 So are you going to be planning on getting injectors and a pump anytime soon? I'll probably pickup a walbro 255lph Fuel pump after payday & DW650cc injectors after tax return. Link to comment Share on other sites More sharing options...
Zed 2.0 Posted January 14, 2009 Share Posted January 14, 2009 Awesome. Thanks for sharing the info. Link to comment Share on other sites More sharing options...
rexster Posted January 14, 2009 Share Posted January 14, 2009 are you running the stock TMIC or the tuning alliance one? thanks for the info! Link to comment Share on other sites More sharing options...
testes1010 Posted January 14, 2009 Author Share Posted January 14, 2009 are you running the stock TMIC or the tuning alliance one? thanks for the info! Stock TMIC currently. Link to comment Share on other sites More sharing options...
snow05gtRI Posted January 14, 2009 Share Posted January 14, 2009 have you modified the stock TMIC at all? Link to comment Share on other sites More sharing options...
testes1010 Posted January 14, 2009 Author Share Posted January 14, 2009 have you modified the stock TMIC at all? Nope, I'm expecting the end tanks to fly off at any time. Log from today on the way to work running just under 18psi Time Load RPM IgnTim IDC% KC MRP MAFg 0 0.75 3887 44.5 16.42 8 -6.12 52.3 171 1.33 3936 30 28.32 8 0.02 102.67 343 1.79 3983 20.5 51.45 8 4.87 146.58 531 2.66 4106 18.5 77.7 8 12.61 213.03 703 3.29 4228 17.5 88.33 8 17.21 231.53 890 3.29 4306 17.5 86.18 8 17.76 235.41 1062 3.28 4424 17.5 86.19 8 17.83 243.16 1234 3.26 4556 18 88.11 8 17.79 248.9 1406 3.24 4705 18 88.97 8 17.78 253.85 1578 3.20 4846 18.5 90.22 8 17.7 257.95 1765 3.17 4936 19 90.6 8 17.45 260.73 1937 3.14 5101 19.5 92.63 8 17.22 264.47 2109 3.09 5223 19.5 92.65 8 16.89 266.82 2281 3.03 5283 19.5 92.63 8 16.62 266.83 2468 3.01 5379 20 93.74 8 16.24 268.26 2640 2.96 5490 20 93.41 8 15.85 269.7 2812 2.92 5634 20.5 95.57 8 15.47 271.62 2984 2.88 5703 21.5 95.52 8 15.19 272.57 3171 2.82 5817 22 94 8 14.86 274.5 3343 2.79 5903 22.5 95.62 8 14.62 274.5 3515 2.75 6031 23.5 95.36 8 14.46 274.03 3687 2.71 6133 24 95.59 8 14.32 274.52 3875 2.68 6212 24.5 96.78 8 14.17 274.53 4046 2.63 6272 25 96.98 8 14.07 276.01 4218 2.60 6396 25.5 96.9 8 14 276.51 4390 2.56 6428 26 96.16 8 14.03 276.02 4578 2.55 6537 27.5 96.18 8 13.92 275.06 4750 2.51 6651 28.5 96.48 8 13.93 276.54 4921 2.48 6736 29 96.28 8 13.93 275.56 5093 2.46 6770 29 95.47 8 13.92 273.15 5281 2.42 6835 29 95.53 8 13.94 275.09 5453 2.40 6912 29.5 95.1 8 13.99 278.05 Link to comment Share on other sites More sharing options...
ShadowImg Posted January 14, 2009 Share Posted January 14, 2009 ^ My stock TMIC has seen 24psi and the endtanks are still solidly attached, if that gives you any relief. Link to comment Share on other sites More sharing options...
testes1010 Posted January 14, 2009 Author Share Posted January 14, 2009 ^ My stock TMIC has seen 24psi and the endtanks are still solidly attached, if that gives you any relief. Definitely does. I dying to turn up the boost & find the 'limit' of the stock fuel system. Link to comment Share on other sites More sharing options...
Infamous1 Posted January 14, 2009 Share Posted January 14, 2009 Definitely does. I dying to turn up the boost & find the 'limit' of the stock fuel system. Your just about there already, the turbo obviously will taper on it own a bit but you will be mising out on about 2psi from 5K-6k rpms. You should be perfectly fine at upwards of 20psi at anything below 5k rpms. BTW I like how your timing increments up, very smooth! Link to comment Share on other sites More sharing options...
testes1010 Posted January 14, 2009 Author Share Posted January 14, 2009 Your just about there already, the turbo obviously will taper on it own a bit but you will be mising out on about 2psi from 5K-6k rpms. You should be perfectly fine at upwards of 20psi at anything below 5k rpms. BTW I like how your timing increments up, very smooth! Thats about what I've figured as well, 15-16psi or so will be the max of stock fuel system toward redline, I think I've got enough headroom at peak load for 21-22psi, we'll see. Thanks, I generally spend a lot of time on my timing maps trying to make them as smooth as possible. Link to comment Share on other sites More sharing options...
Bolksey85 Posted January 15, 2009 Share Posted January 15, 2009 Testes, you're about to be on my ignore list here so I can't see what kind of power you end up making next.:lol: Link to comment Share on other sites More sharing options...
testes1010 Posted January 17, 2009 Author Share Posted January 17, 2009 Logs of the 2 runs: http://www.box.net/shared/k6902lnjci http://www.box.net/shared/hg50qpli46 VF52 still using the same STG1 map I have posted tuned @ 19psi peak: http://www.wrxfanatics.com/uploads/monthly_01_2009/post-367-1232157604.gif VF52 @19psi vs. 100% oem stock: http://www.wrxfanatics.com/uploads/monthly_01_2009/post-367-1232157614.gif http://www.wrxfanatics.com/uploads/monthly_01_2009/post-367-1232158798.gif Using Airboy's sheet, 50-80mph =3.08 60-80mph = 2.10 http://img232.imageshack.us/img232/6053/vf5219psiairboyns9.gif Its amazing what a little boost will do...:lol: Link to comment Share on other sites More sharing options...
ShadowImg Posted January 17, 2009 Share Posted January 17, 2009 God that's beautiful. it really makes you wonder why Subaru was using the VF40/VF46 at all. I don't really see a single point in any of this data which would indicate the VF52 having any compromise against them. Maybe 1st and 2nd gear show some difference, but it can't be much. Link to comment Share on other sites More sharing options...
05Boost Posted January 17, 2009 Share Posted January 17, 2009 Damn how are you doing it. Still under 100IDC. I'll have my cable this week I want to run your maps maybe alittle bit of a detuned one. What was the temp? Link to comment Share on other sites More sharing options...
testes1010 Posted January 17, 2009 Author Share Posted January 17, 2009 What was the temp? The temp was a bitter 17*F which caused the bit of Temperature induced KC at the very very topend of the second log. Link to comment Share on other sites More sharing options...
Spec B Posted January 17, 2009 Share Posted January 17, 2009 Great job man...that is serious TQ right there. Amazing to think that you are still on the stock TMIC and injectors. Link to comment Share on other sites More sharing options...
05Boost Posted January 17, 2009 Share Posted January 17, 2009 what do you think the % difference is of this and a dyno is? Like does this read higher then a dyno? Link to comment Share on other sites More sharing options...
testes1010 Posted January 17, 2009 Author Share Posted January 17, 2009 what do you think the % difference is of this and a dyno is? Like does this read higher then a dyno? MHO is that the DatalogLab software(and Airboy's Spreedsheet) reads slightly less(1-2% difference) than 'average' reading Dynojets like P&L's or AMS's. I had a stock LGT 5mt graph saved from P&L's DynoJet but I can't seem to find it, it was along the lines of ~220whp/250wtq whereas my DLL software did ~215whp/245wtq stock LGT @ AMS: http://legacygt.com/forums/attachment.php?attachmentid=55212&d=1216575938 Link to comment Share on other sites More sharing options...
05Boost Posted January 17, 2009 Share Posted January 17, 2009 ahh awesome. For some reason I though i had read somewhere that the stock dynos were lower then your stock spreedsheet. Im so jealous right now. I want a retune. Once that cable gets here ill take some more datalogs. Link to comment Share on other sites More sharing options...
testes1010 Posted January 17, 2009 Author Share Posted January 17, 2009 For some reason I though i had read somewhere that the stock dynos were lower then your stock spreedsheet. Some dynos do read lower, some read higher. Link to comment Share on other sites More sharing options...
05Boost Posted January 17, 2009 Share Posted January 17, 2009 well i mean like alot lower. i might just be thinking of another car though haha. Link to comment Share on other sites More sharing options...
Infamous1 Posted January 18, 2009 Share Posted January 18, 2009 what do you think the % difference is of this and a dyno is? Like does this read higher then a dyno? I plotted your log you sent me using airboy's spreadsheet. It reads about 5-9% lower than a dynoet from what I have seen. Link to comment Share on other sites More sharing options...
05Boost Posted January 18, 2009 Share Posted January 18, 2009 yea i remember that didnt know if there was a difference in the one you used and then one he used. Im just really jealous of his tune haha. Link to comment Share on other sites More sharing options...
Drew888 Posted January 22, 2009 Share Posted January 22, 2009 Question for the 'tuners' out there. IYO, what is the whp/wtq range expected from a protune running VF52, Perrin TMIC, 740's, Walbro pump, Grimspeed headers, and full 3" TBE. I think some are getting #'s similar to Testes but they "do" have injectors/pump/upgraded TMIC. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
