testes1010 Posted December 14, 2008 Author Share Posted December 14, 2008 oh yea, thats the one that was sitting in my garage for over a year. It was Logan's old Uppipe, then before that it was mine before I went EWG on the WRX. Link to comment Share on other sites More sharing options...
testes1010 Posted December 14, 2008 Author Share Posted December 14, 2008 Harbor Freight has/had some nice stainless "zip ties" I got in case any on my APS need reinforcement. BTW, you know your stuff. I paid $300 for the special APS wrap kit for my headers, what you're doing will work just as well, if not better. My only comment would have to do with water drainage, but I'm sure you've thought of that. Yup, I've seen the ties you are referring to at Harbor Freight, I ended up picking a handful of ss worm clamps from Rural King to secure the Al pans. I've considered the water drainage issue, I figured the water will quickly turn to steam once it hits the pipe, but thats definitely something I'll be watching for. Link to comment Share on other sites More sharing options...
Bolksey85 Posted December 14, 2008 Share Posted December 14, 2008 I generally use BP/Amoco non-E10 93 or Sunoco non-E10 93. No octane booster, most of its garbage anyways. Now is there a way to determine if there is or is not any Ethanol in a given batch of gas on the pump? I have a BP/Amoco right down the road from me and an Exxon the other direction. Neither has done me wrong except for 1 bad tank in the last 7 years. Link to comment Share on other sites More sharing options...
testes1010 Posted December 14, 2008 Author Share Posted December 14, 2008 Now is there a way to determine if there is or is not any Ethanol in a given batch of gas on the pump? I have a BP/Amoco right down the road from me and an Exxon the other direction. Neither has done me wrong except for 1 bad tank in the last 7 years. Most pumps have to say if they contain ethanol. The E10 ones will say they can contain up to 10% ethanol whereas the ones that contain no ethanol doesn't say anything about ethanol in the mix. Link to comment Share on other sites More sharing options...
FASTONE Posted December 18, 2008 Share Posted December 18, 2008 how much benifit do you get by wrap+spray+foil vs just the thermal wrap, the reason that im asking is beacuse i am putting the Cobb dp this weekend and just want to know. Thank you Link to comment Share on other sites More sharing options...
testes1010 Posted December 19, 2008 Author Share Posted December 19, 2008 how much benifit do you get by wrap+spray+foil vs just the thermal wrap.... I think it would be hard to measure. The main goal is to reduce underhood temps w/ the wrap&foil. Link to comment Share on other sites More sharing options...
FASTONE Posted December 20, 2008 Share Posted December 20, 2008 Testes can i use the map that you iploaded om romrader.com if i have dp/up both catless, perrin drop in and GFB BOV. Thanks Link to comment Share on other sites More sharing options...
testes1010 Posted December 20, 2008 Author Share Posted December 20, 2008 Testes can i use the map that you iploaded om romrader.com if i have dp/up both catless, perrin drop in and GFB BOV. Thanks You'd need disable P0420(unless you've got the mech fix), and make sure to get some good logs(regardless of STG1 or STG2)...post them up if you get a chance. Link to comment Share on other sites More sharing options...
FASTONE Posted December 21, 2008 Share Posted December 21, 2008 ok, ill post em as soon as i got chance Link to comment Share on other sites More sharing options...
testes1010 Posted December 28, 2008 Author Share Posted December 28, 2008 http://www.wrxfanatics.com/uploads/monthly_12_2008/post-367-1228667627.jpg Bolted on all the above exhaust parts and took it for a spin(no ECU map changes, none this is still the same STG1 map I've posted on Romraider), nice gains in the torque & quite a bit in the upper end. By the end of the week I should have a STG2 map ironed out. There was a bit of KC in the midrange that wasn't there before so I'm sure that hurt the numbers a bit. STG2 Mods w/ STG1 Map w/ Magnaflow CBE vs. STG1 Map w/ Magnaflow CBE(+17whp/+11wtq peak, although there's ~25whp/~20wtq gain at redline): http://www.wrxfanatics.com/uploads/monthly_12_2008/post-367-1230481515.gif STG2 Mods w/ STG1 Map w/ Magnaflow CBE vs. 100% stock(+51whp/+57wtq max): http://www.wrxfanatics.com/uploads/monthly_12_2008/post-367-1230482766.gif Link to comment Share on other sites More sharing options...
LittleBlueGT Posted December 29, 2008 Share Posted December 29, 2008 I can't wait until you tune a Gt35. Good info, nice graphs, definitely sharing the knowledge. I applaud you. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Spec B Posted December 29, 2008 Share Posted December 29, 2008 Great info, I am looking forward to see what it puts down tuned. Link to comment Share on other sites More sharing options...
testes1010 Posted December 31, 2008 Author Share Posted December 31, 2008 Great info, I am looking forward to see what it puts down tuned. It may not happen, plumes of smoke from the tailpipe hint of a blown VF40 @ 60,666miles(how fitting)......I'll pull the DP in the next day or two for inspection. Brightside, looks like an upgrade is just as cheap as a used VF40. Link to comment Share on other sites More sharing options...
Spec B Posted December 31, 2008 Share Posted December 31, 2008 Damn... Sorry to hear, keep us posted and good luck. Link to comment Share on other sites More sharing options...
tommypenguin Posted December 31, 2008 Share Posted December 31, 2008 If you need a vf40 to get you by I have one with no shaft play with 50k on it I would sell you for dirt cheap, especially after your sharing the knowledge in this thread. But judging by your previous mods I wouldn't expect you to be looking at another stocker. Either way, good luck and keep the info coming. Link to comment Share on other sites More sharing options...
testes1010 Posted January 1, 2009 Author Share Posted January 1, 2009 If you need a vf40 to get you by I have one with no shaft play with 50k on it I would sell you for dirt cheap, especially after your sharing the knowledge in this thread. But judging by your previous mods I wouldn't expect you to be looking at another stocker. Either way, good luck and keep the info coming. Thanks for the offer, I may actually be interested depending on what I find out once the DPs off the car. Link to comment Share on other sites More sharing options...
testes1010 Posted January 4, 2009 Author Share Posted January 4, 2009 As I pulling it up on ramp to remove the DP, the notorious turbo chirp, as in, compressor or turbine scraping the housing was heard. However once removed there was no damage to either comp or turbine(yet) but major shaftplay side to side & up & down. Glad the smoke was a taddle tail to the trouble, could have been alot worse. Still trying to decide on what path to take, upgrade or just pickup a low mileage stocker. Link to comment Share on other sites More sharing options...
05Boost Posted January 4, 2009 Share Posted January 4, 2009 i think you should upgrade to the vf52. Im loving mine and would like to see what you would be able to do tuning wise with one. I put down 310hp 317tq on a dynojet. Stock fueling. Link to comment Share on other sites More sharing options...
testes1010 Posted January 5, 2009 Author Share Posted January 5, 2009 i think you should upgrade to the vf52. Just picked up the last one from 5star/KOP should be here Friday. Link to comment Share on other sites More sharing options...
Spec B Posted January 5, 2009 Share Posted January 5, 2009 Ohhh yeah! Great choice.. Link to comment Share on other sites More sharing options...
snow05gtRI Posted January 5, 2009 Share Posted January 5, 2009 nice, i'm very interested to see what you can do with that vf52. so black smoke is an indication of the turbo going? someone told me once that I had black smoke coming out of my tailpipes when i first turned the engine on after sitting overnight during a snow storm (cleared room for the tail pipes to breath, though) but I havent seen any myself or had anyone else say anything. guess i should look into it... Link to comment Share on other sites More sharing options...
testes1010 Posted January 5, 2009 Author Share Posted January 5, 2009 so black smoke is an indication of the turbo going? black smoke oil, blue smoke fuel, white smoke coolant/water. Mine has some blue smoke mostly at idle. Link to comment Share on other sites More sharing options...
tommypenguin Posted January 5, 2009 Share Posted January 5, 2009 black smoke oil, blue smoke fuel, white smoke coolant/water. Mine has some blue smoke mostly at idle. IIRC: black smoke = fuel blue smoke = oil White = coolant Link to comment Share on other sites More sharing options...
testes1010 Posted January 5, 2009 Author Share Posted January 5, 2009 black smoke = fuel blue smoke = oil White = coolant you are correct.... I can't multitask well, I was on the phone when I posting that..... Link to comment Share on other sites More sharing options...
enthusiast Posted January 5, 2009 Share Posted January 5, 2009 IIRC: black smoke = fuel blue smoke = oil White = coolant You are obviously the expert with some of the most recent experience. My mod list Link to comment Share on other sites More sharing options...
