25gtrbo Posted February 10, 2009 Share Posted February 10, 2009 Suscribed Link to comment Share on other sites More sharing options...
alaskajoel Posted February 10, 2009 Share Posted February 10, 2009 Ahh... that must be it. I'm also not liking my winter fuel blend, BTW, because they put 15% more gas in my ethanol... my E85 is just E70 right now. If I was running straight e85 in the winter, my car would struggle to start. I don't like e70 either, but atleast the car starts up:lol: Link to comment Share on other sites More sharing options...
EquinnoxX Posted February 12, 2009 Share Posted February 12, 2009 Suscribed +1 (except w/o the typo ) Link to comment Share on other sites More sharing options...
Ryandigi Posted February 17, 2009 Share Posted February 17, 2009 If I was running straight e85 in the winter, my car would struggle to start. I don't like e70 either, but atleast the car starts up:lol: Hey Joel where do you fill up your leggy to get real 100% gas (when not getting the e85 from the sinclair south of BYU campus of course)? I usually use the chevron on 800 N and University....I should check to see which ones are gas gas and which ones are cocktails of ethanol. I should just get a bunch of methanol and ethanol from the chem stockroom and make my own cocktails FTW Testes...you are making me want a vf-52...need to blow my stocker! Link to comment Share on other sites More sharing options...
trademark Posted February 17, 2009 Share Posted February 17, 2009 subscribed! wtf vf-52 is 1K!! wat! Link to comment Share on other sites More sharing options...
testes1010 Posted February 18, 2009 Author Share Posted February 18, 2009 subscribed! wtf vf-52 is 1K!! wat! ..........and similar numbers to a used STi swap(tmic, turbo & intake manifold) using a brand new bolt on turbo with the stock LGT TMIC..... super sleeper STI killer.. Link to comment Share on other sites More sharing options...
trademark Posted February 19, 2009 Share Posted February 19, 2009 ..........and similar numbers to a used STi swap(tmic, turbo & intake manifold) using a brand new bolt on turbo with the stock LGT TMIC..... super sleeper STI killer.. Word.. Link to comment Share on other sites More sharing options...
alaskajoel Posted February 19, 2009 Share Posted February 19, 2009 Hey Joel where do you fill up your leggy to get real 100% gas (when not getting the e85 from the sinclair south of BYU campus of course)? I usually use the chevron on 800 N and University....I should check to see which ones are gas gas and which ones are cocktails of ethanol. I should just get a bunch of methanol and ethanol from the chem stockroom and make my own cocktails FTW Testes...you are making me want a vf-52...need to blow my stocker! The shell on center street and costco both offer real 91 (no ethanol) As for the VF-52, i'll need some even fatty-er injectors and a new pump to run e85 with this turbo. Need more monies! Link to comment Share on other sites More sharing options...
Rossm Posted February 25, 2009 Share Posted February 25, 2009 Can you just get a protune for e85 on our cars? I would think you would need to change some lines with it. What did you need to do to switch to e85? Link to comment Share on other sites More sharing options...
trademark Posted February 25, 2009 Share Posted February 25, 2009 Can you just get a protune for e85 on our cars? I would think you would need to change some lines with it. What did you need to do to switch to e85? this thread should help answer some of your questions.. http://legacygt.com/forums/showthread.php?t=90221&highlight=e85 Link to comment Share on other sites More sharing options...
Rimfaxe Posted February 27, 2009 Share Posted February 27, 2009 subscribe Link to comment Share on other sites More sharing options...
testes1010 Posted March 1, 2009 Author Share Posted March 1, 2009 Finally got around to installing the Tuning Alliance TMIC however I've not really had a chance to log anything. I need to square up the fitment a bit. Also 'fabbed' up a splitter of sorts to direct the air correctly into the new TMIC, the stock lower splitter will not work well with the Tuning Alliance setup. I used Air conditioning foam insulation(window air conditioner) and Permatex Adhesive to secure it to the factory upper splitter, the lower portion of the factory splitter was completely removed as well as the mid-divider in the upper portion of the scoop. Pics are below, right click > Open in new Window(must be too large for the forum image viewer): Link to comment Share on other sites More sharing options...
trademark Posted March 1, 2009 Share Posted March 1, 2009 wow looks efficient.. does that affect the underhood temps? I thought there was supposed to be flow over the turbo side of the motor too.. where there was a splitter.. you think the foam will be secure enough when you are going 70-80mph? would suck to have foam melted to the motor somewhere cause it came loose.. hehe. Link to comment Share on other sites More sharing options...
Bolksey85 Posted March 1, 2009 Share Posted March 1, 2009 The size of that thing is beastly. 100% business. And FYI, the pics come up fine for me. No new window. Link to comment Share on other sites More sharing options...
EquinnoxX Posted March 2, 2009 Share Posted March 2, 2009 wow look at the size of that thing. It has complete disregard for anything else in the engine compartment lol. So much for a strut tower bar! Link to comment Share on other sites More sharing options...
testes1010 Posted March 2, 2009 Author Share Posted March 2, 2009 wow look at the size of that thing. thats what she said...... ( I know its played out but believe it or not thats the first time I've used the phrase) honestly the core is still small but much larger than the stocker. My Hyperflow WRX TMIC would eat this TMIC for lunch. Link to comment Share on other sites More sharing options...
testes1010 Posted March 2, 2009 Author Share Posted March 2, 2009 wow looks efficient.. does that affect the underhood temps? I thought there was supposed to be flow over the turbo side of the motor too.. where there was a splitter.. you think the foam will be secure enough when you are going 70-80mph? I never had a problem with air not going over the turbo on my wrx. The foam is definitely secure, after 15 minutes or so of curing I realized it was off a bit on one side and tried to move it, hmmm no. Link to comment Share on other sites More sharing options...
alaskajoel Posted March 3, 2009 Share Posted March 3, 2009 Have you had a chance to fight with the fitment any? Perhaps it's just me, but it looks crooked, and fit/finish is the primary reason i haven't bought one of these yet. Price is good, looks great, but if it's shabby fitment wise i'll buy an avo or perrin. Link to comment Share on other sites More sharing options...
testes1010 Posted March 3, 2009 Author Share Posted March 3, 2009 Have you had a chance to fight with the fitment any? Perhaps it's just me, but it looks crooked, and fit/finish is the primary reason i haven't bought one of these yet. Price is good, looks great, but if it's shabby fitment wise i'll buy an avo or perrin. I definitely need to straighten it a bit. The fitment is not as good as most WRX TMIC were on the WRX however the setup does give you some flexibility for installation I just need to level it up a bit. I had the in & out pipes completely refabbed by a buddy of mine, I was not happy with the weldment on the pipes or the IC bpv flange. Link to comment Share on other sites More sharing options...
johnnymack Posted March 5, 2009 Share Posted March 5, 2009 Jeremey! Whats up? I am looking @ a Legacy Spec B as we speak.... guess who's gonna tune it? To all those who don't know, Jeremey tuned my WRX and its running incredibly good. Link to comment Share on other sites More sharing options...
testes1010 Posted March 6, 2009 Author Share Posted March 6, 2009 Definitely cool, I'll have to pick up a 2.0 cable. I have yet to do so. Welcome to the LGT boards. Link to comment Share on other sites More sharing options...
Bolksey85 Posted March 7, 2009 Share Posted March 7, 2009 Any chance of getting a video posted here? I want to hear that '52 with that Magnaflow! Link to comment Share on other sites More sharing options...
testes1010 Posted March 7, 2009 Author Share Posted March 7, 2009 Any chance of getting a video posted here? I want to hear that '52 with that Magnaflow! I'll see what I can do. Link to comment Share on other sites More sharing options...
testes1010 Posted March 28, 2009 Author Share Posted March 28, 2009 Sorry for no updates, I've been working massive amount of hours at work(112hrs last week, 90-something the week before). Link to comment Share on other sites More sharing options...
Bolksey85 Posted March 29, 2009 Share Posted March 29, 2009 Dear Jesus, that's a buttload of work. How's that turbo been doing in the last weeks? Link to comment Share on other sites More sharing options...
