Prime Power Posted July 15, 2010 Share Posted July 15, 2010 I finally took this thing out. Almost nothing on it but that is due to my bypass filter. 60k miles on the car. Link to comment Share on other sites More sharing options...
Vertigo Posted August 25, 2010 Share Posted August 25, 2010 For the record, I inspected my filter at about 50K miles and found absolutely nothing in it. I've always run AMSOIL synthetic 5W-30, changed every 5-6K miles. Also for the record, this was a huge pain in the ass. I had to use a 4-foot breaker bar to get the bracket bolts off. Also dropped the copper washer that goes between the feed line and the block -- had to drop the plastic undertray to get it. Link to comment Share on other sites More sharing options...
jackfortune Posted August 25, 2010 Share Posted August 25, 2010 Yes, breaker bar and PB Blast needed for THAT bolt. Shop hint: use a loop of dental floss or thread through the copper washer to keep it from falling down into the depths. Tie the other end of the loop to your gloved finger on your right hand. Suspend the copper washer into the cavity, and then start the banjo bolt through with your left hand. When the banjo bolt is past the copper washer and the threads have started to take, break the loop and pull the thread or floss through. Saves much aggravation and #%&&!@. Somewhere on here there is an excellent pictorial of "how to do". Saved me lots of time and frustration. Link to comment Share on other sites More sharing options...
Black_Rain Posted August 25, 2010 Share Posted August 25, 2010 Ok wow...I've read this whole thread... Incredible data... Good work for those that contributed pics and experience. Anyway, I'll be doing this with my up-pipe install, but has anyone tried to do this while UNDER the car? Is it any easier? Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted August 26, 2010 Share Posted August 26, 2010 With the up pipe out a blind gorilla (with swollen thumbs even) should be able to do this in about 2 minutes...lol Link to comment Share on other sites More sharing options...
Prime Power Posted August 26, 2010 Share Posted August 26, 2010 Just removed mine. What a friggin pain. Link to comment Share on other sites More sharing options...
Vertigo Posted September 1, 2010 Share Posted September 1, 2010 Shop hint: use a loop of dental floss or thread through the copper washer to keep it from falling down into the depths. Indeed, I did use this method for reinstalling the washer, and it worked well. I actually dropped the washer (between the fitting and the block) when I removed the banjo bolt. Anybody got any suggestions on how to keep it from falling out when you remove the bolt? I wasn't able to get my hand in there to catch it. Link to comment Share on other sites More sharing options...
bugblatterbeast Posted September 1, 2010 Share Posted September 1, 2010 why would you worry about the old washers dropping to the ground? they should be replaced with new ones when the bolt is put in. the copper washers are designed to crush while sealing. they are not the same when old unless you go through the trouble of anealing them. even then, why risk a leak over $0.50 after going through the trouble of swapping out the bolt. Link to comment Share on other sites More sharing options...
Vertigo Posted September 1, 2010 Share Posted September 1, 2010 why would you worry about the old washers dropping to the ground? they should be replaced with new ones when the bolt is put in. True, but if they are in good condition (i.e. still have a smooth, flat surface) then they can be re-used. I spent a few years designing and troubleshooting hydraulic systems, so I know what to look for. In any case, even if I didn't reuse the washer, I don't like the idea of loose parts in unknown locations in my engine compartment. I would be worried about it finding its way somewhere it can cause trouble, and the only way to be sure of that is to get the part out of there. Link to comment Share on other sites More sharing options...
jackfortune Posted September 2, 2010 Share Posted September 2, 2010 Ok....I understand your question now! I used blue paper shop towels stuffed down under the banjo bolt area to fill any cavity small parts might fall into....and to keep the large amount of PB Blast I used on the bracket bolt from dripping down onto headers or other parts that would heat up and cause smoking....etc. When I removed the bracket I left the shop towels packed into that cavity. When I extracted the banjo bolt I simply let the washer drop down onto the paper shop towels and it was easy to get it out from there....best regards.... Link to comment Share on other sites More sharing options...
howard5091 Posted September 16, 2010 Share Posted September 16, 2010 Can anyone confirm if the Turbocharger oil feed banjo bolt has the infamous screen in it on an 07 LGT? I dont want to tear it apart for no reason . Thank you in advance! Brandon Link to comment Share on other sites More sharing options...
holyjoetart Posted September 16, 2010 Share Posted September 16, 2010 The '07 does. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted September 16, 2010 Mega Users Share Posted September 16, 2010 http://www.subarupartsdepartment.com/schematics/7/7523261.gif Is the banjo bolt number 10 here? My dealership is not sure which part it is and don't have any of the parts in stock that they think may be it. If I'm going to order these online, I want to make sure I have the right ones, since I'm going to order several of them. #10 is called pipe union. Link to comment Share on other sites More sharing options...
dudeondacouch Posted September 16, 2010 Share Posted September 16, 2010 if your dealership staff can't figure out what the part # is, i don't recommend ordering anything from there. Link to comment Share on other sites More sharing options...
dudeondacouch Posted September 16, 2010 Share Posted September 16, 2010 especially since it took me all of 5 seconds to find it here. http://legacygt.com/forums/showpost.php?p=842649&postcount=2 Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted September 16, 2010 Mega Users Share Posted September 16, 2010 if your dealership staff can't figure out what the part # is, i don't recommend ordering anything from there. That's the point. I'm ordering it online because the dealership had a WTF? face when I asked for a banjo bolt. I had to explain it and still got a confused look. There aren't any part numbers on the site I'm looking at, just names and the diagram. They call it a union. I saw that part number in the thread, but I just want to make sure that I'm getting the right part for my car. Like I said, I'm going to order several of them online and I am concerned about it since I just used seafoam in the crank case. That means I've loosened up all the deposits in the engine giving me more chance of clogging my filter. I'd prefer to not have to return parts because that is more time. I'm having a hard time keeping off of the turbo. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 16, 2010 Share Posted September 16, 2010 You should not need to replace the banjo bolt. Only the crush washers if needed. You can buy crush washers at any auto parts store. They are commonly used on brake calipers. I have a small jar full of different sizes in my tool box. Don't make this more dificult then it is. Hey at 131,000 miles mine have never been removed. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Subadozer Posted September 17, 2010 Share Posted September 17, 2010 especially since it took me all of 5 seconds to find it here. http://legacygt.com/forums/showpost.php?p=842649&postcount=2 Banjo Bolt (Called a union screw by SOA): 15194AA110 Washer (Called a gasket by SOA): 803910050 Is it a different bolt & washer depending on year? I bought the parts but haven't been able to carve out the time to do the change so am looking at the package as I type. The Union Screw with filter is 14445AA090. The washer came without a package but the part number I used is 803912040. I got mine from a dealer but as I recall I asked by part number rather than asking for a union screw for an '05 OBXT. Link to comment Share on other sites More sharing options...
CB-M3 Posted September 30, 2010 Share Posted September 30, 2010 I just bought an 2005 GT yesterday. Now I'm paranoid so I'll prob be doing this check on the banjo bolt pretty soon. I have 79k miles on it. Link to comment Share on other sites More sharing options...
Subadozer Posted October 1, 2010 Share Posted October 1, 2010 I just bought an 2005 GT yesterday. Now I'm paranoid so I'll prob be doing this check on the banjo bolt pretty soon. I have 79k miles on it. Did you get a Carfax report and if so how complete was it? Mine was extensive for the first 64,000 miles and then with the second owner almost nothing. This gives me 30,000 miles of unknown maintenance, which is what concerns me. Unfortunately my bolt and washer is still sitting in my tool box waiting for me to carve out the time between dealing with housing and job issues. I've got about 1500 miles left on my aftermarket warranty and my third oil change due soon . You should be OK as long as the previous owner(s) were good with 3-4k oil change intervals (OCI). Still no reason not to be safe and pull the bolt to at least check the filter. Link to comment Share on other sites More sharing options...
CB-M3 Posted October 1, 2010 Share Posted October 1, 2010 Did you get a Carfax report and if so how complete was it? Mine was extensive for the first 64,000 miles and then with the second owner almost nothing. This gives me 30,000 miles of unknown maintenance, which is what concerns me. Unfortunately my bolt and washer is still sitting in my tool box waiting for me to carve out the time between dealing with housing and job issues. I've got about 1500 miles left on my aftermarket warranty and my third oil change due soon . You should be OK as long as the previous owner(s) were good with 3-4k oil change intervals (OCI). Still no reason not to be safe and pull the bolt to at least check the filter. The car had 2 owners. The 1st owner was lease and had service performed at the dealers which showed up on the carfax. The 2nd owner who I bought it off did the maintenence at his father's shop so it wasn't recorded. He told me he did oil change every 3000 miles with Mobil 1. Last service interval was at 50k so I will be doing the tranny and diff fluids. Now for questions on the bolt. I've read through the thread so I know where to look but do I have to check both bolts driver and passenger side? Do people just remove it entirely or replace it with a new one? If I find the screen to be dirty or clogged does that mean my turbo is going to go bad? In that case I would check for shaft play. Link to comment Share on other sites More sharing options...
jackfortune Posted October 2, 2010 Share Posted October 2, 2010 CB-M3: I will give you a brief case history. I purchased an 06 Legacy GT LTD (148k miles) in Florida. Verified its service history with Jacksonville Subaru. Original VF40 turbo. Turbo side banjo bolt/filter never inspected. One owner. Professional. Interstate commuter. 140k miles per day. Changed his oil religiously with Mobil 1 5W/30. Followed all of Subaru's turbo recommendations (warmup, warmdown, oil change every 3750 miles, Subaru filter). When I got back to Maine I pulled the original banjo bolt that feeds the turbo/passenger side AVCS. Filter in the banjo bolt looked good . No sludge. A few observable metal particles trapped on the feed side of the filter screen. Therefore I did not pull the driver's side banjo bolt (behind the timing cover) that feeds the driver side AVCS. The moral of this story is that if the vehicle has had oil changes every 3750 miles with good synthetic oil and filter, its banjo bolt is likely to be clean (and the turbo still healthy). However, just one long OCI due to ignorance or forgetfulness....and goodbye turbo. I strongly recommend retaining the original design banjo bolt/filter screen due to the observable metal particles I saw trapped inside the filter screen. I would not have wanted those particles to have flowed into the VF40 journal bearing area. I replaced the orignal banjo bolt/screen with a new part. I strongly recommend to anyone purchasing a Subaru with a turbo that they insist on a verifiable complete service history (specifically OCI's, oil and filter quality). Then immediately pull the banjo bolt/filter for inspection. Replace the bolt/filter with an original part. Yes, I have read all the posts about pulling the filter screens. Don't do it. Following Subaru's turbo recommendations to the letter will not prevent small metal particles from flowing through the VF40 turbo if the filter screen is absent from the banjo bolt. The flaky VF40 needs baby oil. But as you can see from this real world account, if it receives baby oil it can have a long service life....And if you live in a cooler climate definitely go to 0W/30 synthetic, or preferably the 0W/40 synthetic recently come to market. Don't forget to upgrade the oil pickup if the vehicle has over 30k miles...Best regards from Maine. Link to comment Share on other sites More sharing options...
Subadozer Posted October 2, 2010 Share Posted October 2, 2010 Do people just remove it entirely or replace it with a new one? I've read so much about this in a number of threads, and it was a while ago so don't recall specific references, but as with many things there seems to be 2 schools of thought on this. I'm with jackfortune on this one. Many people who have examined the filter screen have mentioned 'a few metal particles.' Given this and that the critical element seems to be the OCI, added to the fact that Subaru engineers had a reason for the filter, I will retain it. I bought a new one just to be sure I had a replacement because when I get the thing all apart I have no way to run for parts. Link to comment Share on other sites More sharing options...
alphatarget1 Posted October 10, 2010 Share Posted October 10, 2010 So I tried to do this and it was epic fail. Broke a bolt for the heat shield bracket and bent some lines. I did get the banjo bolt out and there was nothing on the screen at 88k miles. Do you guys know where to find a stock wastegate actuator for a 05? Link to comment Share on other sites More sharing options...
CB-M3 Posted October 12, 2010 Share Posted October 12, 2010 So I tried to do this and it was epic fail. Broke a bolt for the heat shield bracket and bent some lines. I did get the banjo bolt out and there was nothing on the screen at 88k miles. Do you guys know where to find a stock wastegate actuator for a 05? are you leaving the banjo bolt out or keeping it in? I've read through this thread and half the people say keep it in and others say remove it. Will removing it cause any debris or metal to get into the turbo? Link to comment Share on other sites More sharing options...
