2.5GT Turbo Oil Supply Banjo Bolt Filter Removal
I added this as a sticky with only the how to portion http://www.legacygt.com/forums/showthread.php?t=62371
After much discussion, it turns out that there are TWO filters inside of the banjo bolts that are at the entrance to the oil feed pipes - one on the driver's side that goes to the AVCS solenoid and one on the passenger's side that feeds the AVCS solenoid and the turbo oil feed.
Towards the end of this post http://www.legacygt.com/forums/showthread.php?t=58023&page=19 people discussed accessing this bolt for cleaning the filter and/or replacing it. Someone posted a great idea and I decided to consolidate the procedure in one post.
I removed the Bolt, removed the filter and put it all back together in about 30 minutes. Turns out that it is not hard to do at all. I didn't have time to try to tackle the driver's side bolt, but that one is of less concern.
Tools -
10mm wrench or 1/4" drive socket
14mm deep socket
14mm regular socket
Universal joint for the 14mm regular socket
17mm shorty wrench
Magnetic pick up (you are going to need it)
Make sure the engine is cold - you will be very intimate with portions of it.
Steps:
1. Remove the engine cover
2. Remove one of the heat shield bolts as shown in the picture
3. Remove the nut from the stud as shown in the picture
4. Remove the bolt from the bracket as shown in the picture. This is the hardest part because you can't get a good angle at it. Use the u-joint.
5. Remove the bracket itself
6. Remove the Banjo bolt. Use the 17mm shorty and take your time. Be careful with the washers and not that a few drops of oil WILL leak out onto the up-pipe.
7. Remove the filter. Be careful or you will break it.
8. Install the banjo bolt and washers. Do not overtighten.
9. Replace everything else.
Depending on your turbo and wastegate actuator the job might be easier or harder.
My filter had absolutely nothing in it (22k miles).
The car seems to drive much better, plus I am now richer AND better looking ;) In fact several ladies approached me right after I completed the job - interesting.....
The pictures are the best I could do. The are is very hard to see, let alone photograph.
I bet I could do another one in around 20m minutes; NC crew I WILL be charging for this - no freebies. :lol:
I hope this helps people.
I am trying to attempt this and I really wish we had more photos so I took the liberty of adding 2 more photos to the 1 photo that basically comprises this entire "how to".
This, I believe is the general area of where the banjo bolt is located.
http://i395.photobucket.com/albums/pp37/Polo08816/100_0234.jpg
This is where it gets confusing. Some of the components of rao's picture don't look identical to what I have here (2008 Legacy GT 5EAT).
http://i395.photobucket.com/albums/pp37/Polo08816/100_0235.jpg
I fail to see what exactly the banjo bolt is hiding under. I understand there's a bracket held by 3 bolts that rao wants you do remove. I just wasn't sure if I was doing everything correctly.
  • Replies 1.2k
  • Created
  • Last Reply
I too was wondering if there are any better picutres of how to remove the banjo bolt. Also, does anyone have pictures posted of how to do the one on the drivers side?
I agree. One picture does not do this thread justice. I was hoping someone would be able to provide better pictures on how to do this.
My ass that's a 30 minute job. I just changed mine and it took about 1.5 to 2 hours. First off, do yourself a favor and take off the heat shield. I spend a lot of time struggling to get the bolt back in until my neighbor (mechanic) said take that off dummy. Use the floss as quoted earlier to hold the copper washer in place against the block. 20 something ft-lbs is a lot of force if you are using a shorty wrench. You have to muscle on it (put a wrench on your torque wrench to calibrate you cannons).
Mine had some small flecks blocking less than 3% to 5% of the area. I have 38000 miles and follow the 7500 mile oil change using Mobil 1 synthetic.
Depends on year and model, I guess. I had my '05 5EAT wagon's banjo bolt out in like 20-30, and putting it back in took maybe 10. If I'd had a new bolt I was putting back in, I could have been done in 45 easily. Now that I know what I'm doing, it would be even less..
I haven't done this job yet but I've inspected it carefully....I think with the right tools it's a 30 minute job for a shade-tree mechanic's first time, and not getting into any stuck bolts or 30 minutes threading a washer back on :)
If you have the exact right tools (swivels, extensions, and stubby 17mm) its a half hour to an hour job. Even on your first time, as long as you've prepared for what to do. A lot of this also depends on the size of your hands and your dexterity. And yes, be careful not to drop the washer in back....do yourself a favor and thread it onto something the first time because you WILL drop it if you think you can just slide it behind the bolt as you put it back in. Then you will have to find it.....
  • 3 weeks later...
No, you need to clean the filter out. Wiping it flat across won't do it.
Try spraying carb cleaner or intake cleaner aerosol through it to get a little pressure behind it. Or, of course, just toss the filter out and re-install the banjo.
I don't understand why you would put a new filter back in? Your car's oil filter should be doing the job of filtering particles... sure this might catch some, but if it happens to clog it grenades your turbo and possibly your engine depending on which direction parts fly... why not just get rid of it? No other turbo cars have a filter like this that I know of...
Some aftermarket turbos come with a filter in the replacement feedline. I think the rational is to increase turbo life by removing the fine dirt. If the filter is serviced regularly enough, there really shouldn't be a problem with clogging. In the case of the stock filter, maybe Subaru was worried about some initial assembly crap taking out the turbo. They probably didn't count on sludge plugging up the mesh in the field though.
It really isn't that much trouble to swap out the bolt once you've done it once. You just need a stubby wrench and some flexibility. Getting the washers in is a little tricky, but really not that bad if you just put some grease on the inner one so it stick in place while you are reaching for the bolt.
The initial thought of extra filtering was good in theory, however long-term testing might not have found the potential issues, this turbo has made it almost 100,000 miles without one so far. It wasn't difficult at all to take out, I did the grease method like you did, but I have no desire to do it on a regular basis. I saw Forced Performance says to get rid of it if you buy one of their turbos, if they felt it was beneficial you would think they'd ask you to keep it as they don't want to warranty blown turbos.
Well I tried to do this today, and without have a 17mm shorty wrench, it is impossible, at least for my massive hands at least :mad:. My adivce would be to not attempt this without have that 17mm shorty.
All of the other bolts are pretty easy to get at with the tools that Rao listed. For whatever reason, I also needed to shoot the nut on the stub with some Rust-Solve to loosen it up as it was tight as f**k!! It was also fairly tricky to get out the bracket once I had all of the nuts and bolts off, but it still comes out.
I also looked at the drivers side bolt, and to my eye I cannot see how you would even to begin to take it out since as you back it out, you will come into contact with the back of the timing belt cover. If any one has any ideas or pictures of how they did it, I would love to see it.
And hence I am off to the store to aquire one so I may finish the job. :rolleyes:
Way back on post 158. just updated it to put back the pic.
http://legacygt.com/forums/showpost.php?p=1326330&postcount=158
I have 134k now, in 10k more I'll be doing it again. So I can compare the bolt filter between the frist 30k Mobil1\Fram & the last 43k, using Amsoil oil\filer & the last 70k using just Amsoil oil\filer every 15k.
Mike
Mileage:331487 Retired/Sold
