rao Posted May 14, 2007 Share Posted May 14, 2007 I added this as a sticky with only the how to portion http://www.legacygt.com/forums/showthread.php?t=62371 After much discussion, it turns out that there are TWO filters inside of the banjo bolts that are at the entrance to the oil feed pipes - one on the driver's side that goes to the AVCS solenoid and one on the passenger's side that feeds the AVCS solenoid and the turbo oil feed. Towards the end of this post http://www.legacygt.com/forums/showthread.php?t=58023&page=19 people discussed accessing this bolt for cleaning the filter and/or replacing it. Someone posted a great idea and I decided to consolidate the procedure in one post. I removed the Bolt, removed the filter and put it all back together in about 30 minutes. Turns out that it is not hard to do at all. I didn't have time to try to tackle the driver's side bolt, but that one is of less concern. Tools - 10mm wrench or 1/4" drive socket 14mm deep socket 14mm regular socket Universal joint for the 14mm regular socket 17mm shorty wrench Magnetic pick up (you are going to need it) Make sure the engine is cold - you will be very intimate with portions of it. Steps: 1. Remove the engine cover 2. Remove one of the heat shield bolts as shown in the picture 3. Remove the nut from the stud as shown in the picture 4. Remove the bolt from the bracket as shown in the picture. This is the hardest part because you can't get a good angle at it. Use the u-joint. 5. Remove the bracket itself 6. Remove the Banjo bolt. Use the 17mm shorty and take your time. Be careful with the washers and not that a few drops of oil WILL leak out onto the up-pipe. 7. Remove the filter. Be careful or you will break it. 8. Install the banjo bolt and washers. Do not overtighten. 9. Replace everything else. Depending on your turbo and wastegate actuator the job might be easier or harder. My filter had absolutely nothing in it (22k miles). The car seems to drive much better, plus I am now richer AND better looking In fact several ladies approached me right after I completed the job - interesting..... The pictures are the best I could do. The are is very hard to see, let alone photograph. I bet I could do another one in around 20m minutes; NC crew I WILL be charging for this - no freebies. I hope this helps people. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
fatbastard Posted May 14, 2007 Share Posted May 14, 2007 Nice...I may have to take a look at this, anything that can make the car run better and help with the ladies is alright by me. Really though, is there any consensus as to why these would get plugged to begin with? If yours was clean after 22k it makes you wonder. All these blown engines are starting to make me rethink the mod path...would just like to get a little warm and fuzzy back. Link to comment Share on other sites More sharing options...
DeepFreeze2 Posted May 14, 2007 Share Posted May 14, 2007 Do you accept debit cards, Rob? YA RLY!!! Home of +2500 useless posts!!!! Link to comment Share on other sites More sharing options...
rao Posted May 14, 2007 Author Share Posted May 14, 2007 Do you accept debit cards, Rob? If you have a debit card you should be able to come up with cash As to why or if the filters get clogged up - got me. My car hasn't been stock for most of those miles. I change the oil every 3 months with whatever 5w30 is on sale (i did use synthetic for a few changes but stopped). Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
laneygirlid Posted May 14, 2007 Share Posted May 14, 2007 I am a new 2007 Legacy GT owner and am not very mechanically savvy, but am wondering what necessitated this type of repair? Were you replacing some type of turbo filter? Thanks. Link to comment Share on other sites More sharing options...
G.T.Subie Posted May 14, 2007 Share Posted May 14, 2007 :subscribe: Denial is your best friend Link to comment Share on other sites More sharing options...
whitetiger Posted May 14, 2007 Share Posted May 14, 2007 you say that there was nothing in the bolt/filter but after you replaced it, you felt a difference? that dosent make much sense. Link to comment Share on other sites More sharing options...
G.T.Subie Posted May 14, 2007 Share Posted May 14, 2007 If you have a debit card you should be able to come up with cash As to why or if the filters get clogged up - got me. My car hasn't been stock for most of those miles. I change the oil every 3 months with whatever 5w30 is on sale (i did use synthetic for a few changes but stopped). I thought that it wasn't a good idea to go back once you go to SYNTHETIC. Denial is your best friend Link to comment Share on other sites More sharing options...
rao Posted May 14, 2007 Author Share Posted May 14, 2007 I thought that it wasn't a good idea to go back once you go to SYNTHETIC. Please MY CAR IS DOOMED Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rao Posted May 14, 2007 Author Share Posted May 14, 2007 you say that there was nothing in the bolt/filter but after you replaced it, you felt a difference? that dosent make much sense. I also said I was richer and better looking. I was kidding. There is no way you could perceive any difference. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
G.T.Subie Posted May 14, 2007 Share Posted May 14, 2007 Hey I was asking a serious question. Just trying to educate myself. <<<<Noob Denial is your best friend Link to comment Share on other sites More sharing options...
whitetiger Posted May 14, 2007 Share Posted May 14, 2007 I also said I was richer and better looking. I was kidding. There is no way you could perceive any difference. oh, i thought you were serious about the running better part and then sarcastic about the other stuff. how fine does the filter in the bolts look? is it just a screen mesh or somthing more? Link to comment Share on other sites More sharing options...
direavenger Posted May 14, 2007 Share Posted May 14, 2007 rao, how many miles do you normally drive in 3 months? If the miles/OCI is low, we need to compare the filter to someone who has done extended OCI's for awhile. edmundu comes to mind... The Dude - Two inches and counting... Link to comment Share on other sites More sharing options...
rao Posted May 14, 2007 Author Share Posted May 14, 2007 Hey I was asking a serious question. Just trying to educate myself. <<<<Noob I apologize; I got 2 messages mixed up. There is a school of thought that you can't change back once you use synthetic oil, there is another school of thought that it doesn't matter. There is some merit to the idea that you shouldn't change to synthetic on a motor that has a lot of miles on it (like over 85k) because it might cause leaks due to changes in the seals. The key is to use oil that is properly rated and to change it at the right intervals, don't get hung up on the brand. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
rao Posted May 14, 2007 Author Share Posted May 14, 2007 oh, i thought you were serious about the running better part and then sarcastic about the other stuff. how fine does the filter in the bolts look? is it just a screen mesh or somthing more? Well I am better looking It is very fine screen mesh. rao, how many miles do you normally drive in 3 months? If the miles/OCI is low, we need to compare the filter to someone who has done extended OCI's for awhile. edmundu comes to mind... Not many - typically 2-3k miles. I just always change it every 3 months. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
G.T.Subie Posted May 14, 2007 Share Posted May 14, 2007 Gotcha , thanks Denial is your best friend Link to comment Share on other sites More sharing options...
whitetiger Posted May 14, 2007 Share Posted May 14, 2007 Well I am better looking It is very fine screen mesh. Its probably just there to prevent larger bits of metal from messing up the turbo or cam bearings. I bet even after 50K miles there wont be anything in these little filters. Link to comment Share on other sites More sharing options...
rao Posted May 14, 2007 Author Share Posted May 14, 2007 Its probably just there to prevent larger bits of metal from messing up the turbo or cam bearings. I bet even after 50K miles there wont be anything in these little filters. I think that is correct. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
unclemat Posted May 14, 2007 Share Posted May 14, 2007 Hmmm. The idea of a non-replaceable fitler does not make sense. If the filter catches something (serving it purpose) generally the stuff won't go away. Did SOA screw up something and forgot to include these filters in the maintenance schedule or forgot to remove them? So I guess we need either keep an eye on these filters or replace them, or just ditch altogether... Link to comment Share on other sites More sharing options...
laneygirlid Posted May 14, 2007 Share Posted May 14, 2007 I apologize; I got 2 messages mixed up. There is a school of thought that you can't change back once you use synthetic oil, there is another school of thought that it doesn't matter. There is some merit to the idea that you shouldn't change to synthetic on a motor that has a lot of miles on it (like over 85k) because it might cause leaks due to changes in the seals. The key is to use oil that is properly rated and to change it at the right intervals, don't get hung up on the brand. I am actually in the midst of trying to make a decision on whether to switch to synthetic or not. My previous car was an 1997 Audi A4 1.8T Q and was told to use synthetic because Audi/VW won't warranty turbos that didn't have synthetic oil in the engine. Now, Subaru is not saying anything about synthetic for turbo, etc. The service manager at local dealer says older mileage cars can convert to synthetic, which is contrary to the leakage theory you mentioned. I've also been told that once you switch you shouldn't keep going back and forth...I'm so confused. Can anyone provide some objective, more data driven information on this topic? Link to comment Share on other sites More sharing options...
rao Posted May 14, 2007 Author Share Posted May 14, 2007 I am actually in the midst of trying to make a decision on whether to switch to synthetic or not. My previous car was an 1997 Audi A4 1.8T Q and was told to use synthetic because Audi/VW won't warranty turbos that didn't have synthetic oil in the engine. Now, Subaru is not saying anything about synthetic for turbo, etc. The service manager at local dealer says older mileage cars can convert to synthetic, which is contrary to the leakage theory you mentioned. I've also been told that once you switch you shouldn't keep going back and forth...I'm so confused. Can anyone provide some objective, more data driven information on this topic? It is impossible to find a definitive answer to your question and it is outside the scope of this thread. http://www.bobistheoilguy.com is a good source of information. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
whitetiger Posted May 14, 2007 Share Posted May 14, 2007 Hmmm. The idea of a non-replaceable fitler does not make sense. If the filter catches something (serving it purpose) generally the stuff won't go away. Did SOA screw up something and forgot to include these filters in the maintenance schedule or forgot to remove them? So I guess we need either keep an eye on these filters or replace them, or just ditch altogether... no, these are not supposed to be replaced. they are there in case ther is some catastophic happens and metal get in to the oil, that it wont ruin anything more that what has already failed. there is another filter like this in the AC system also, right before the fixed orfice tube, and im sure there are some in the AT system on cars with the 4eats and 5eats. Link to comment Share on other sites More sharing options...
Balrock Posted May 14, 2007 Share Posted May 14, 2007 The screen is very fine, i tried my best to get a good picture of it. Link to comment Share on other sites More sharing options...
2005garnetGT Posted May 14, 2007 Share Posted May 14, 2007 congratulations subaru, you have a retarded design there. Link to comment Share on other sites More sharing options...
praedet Posted May 14, 2007 Share Posted May 14, 2007 So Rob, did you look at it, then put it back in, or remove it entirely... Ted Link to comment Share on other sites More sharing options...
