Posts
516 -
Joined
Content Type
Profiles
Forums
Gallery
Everything posted by Prime Power
Another hack! Now KEYLESS REMOTE unlocks ALL DOORS at once!
Prime Power replied to centerpunch's topic in Interior/Audio
I believe it would, it worked on my 07. -
Headlight clearing (w/pics)
Prime Power replied to Rexmobbin's topic in Walkthroughs :: Performance Modifications
I just did it this morning. Great instructions. The 07's have screws instead of the torx bit on the inside. I used the actual torx bit to get the outside ones. I don't feel so good about that bumper after taking it off. I am real impressed with this mod, it compliments my theme well. I baked them @ 200 for 15 min. Now just to take care of the tails. I used the sylvania silverstars that look silver, rainbowish and light up amber. It looks better lit up too. Great stuff. -
Got it fixed. Read your instructions wrong first and hooked it up to the part coming from the connector. Well, that blew a fuse. Replaced fuse and wired it up according to instructions. Working great so far. Thanks. However, it doesn't unlock the tail on the wagon, which is odd because before if you pressed it twice it would. Oh well, I have another button for that. Thanks -
Put it back to original state and can't even lock the doors with the remote or from the inside using the lock lever. HELP. -
Just tried it on my 07 obxt. Now no doors lock. -
If you have an auto definitely get a tranny cooler. I had a 4 person waverunner I used to haul, maybe about 1200lbs no problem. Now I have 2 quads on a trailer and if not positioned right it sways badly. I have a sway control device I use, but the outback doesn't have enough weight to overcome it sometimes.
I spent about 3 hours on the car this morning to not find it. I found the one up top, and no filter was in it. I found one more at the end of the line but there was no way to get to it. I removed 3 bolts attached but only one was a banjo and no filter was in it. Do the 07's have these, or did I waste my time?
I have one on my truck, and have for about 3 years now. No problems. Also, all large diesel engines have these, and the power plants I work on also have bypass filters. The only concern one really should have with these, is to ask themself is it overboard? I say no because I plan to remove the banjo bolt filters and use this to cover the smaller particles.
Well, placed the order. I have leave 17-21 march so I will probably install it then. They wanted $50 for the 90 degree fittings. That is crazy, and I am a dealer. I will go to the local store and pay a few bucks instead. Ordered the eao-15, I hope that is smaller. Couldn't find a dimensions page. How long do you think it took you to install it all?
