Solkid212 Posted November 29, 2016 Share Posted November 29, 2016 Hi I am new to the Subaru world and I'm looking for some advice. I've looked around on here and have not found a clear answer on dual exhaust if it's able to be purchased or it has to be customized. Also I've noticed that some of the part numbers 4 a cold air intake here are four earlier models if anybody can point me in the right direction that would be great thank you for your help Link to comment Share on other sites More sharing options...
BeastCoast Posted November 29, 2016 Share Posted November 29, 2016 Hi I am new to the Subaru world and I'm looking for some advice. I've looked around on here and have not found a clear answer on dual exhaust if it's able to be purchased or it has to be customized. Also I've noticed that some of the part numbers 4 a cold air intake here are four earlier models if anybody can point me in the right direction that would be great thank you for your help Use the search function. That being said: Unless you have the 3.6R, no direct fit dual exhaust. Requires some fabrication. Takeda 4303P is a direct fit intake- http://afepower.com/afe-power-tr-4303p-takeda-stage-2-pro-dry-s-cold-air-intake-system SSD Performance has a direct fit intake- http://ssdsubaru.blogspot.com/ @BeastCoast1 Link to comment Share on other sites More sharing options...
Solkid212 Posted November 29, 2016 Share Posted November 29, 2016 Use the search function. That being said: Unless you have the 3.6R, no direct fit dual exhaust. Requires some fabrication. Takeda 4303P is a direct fit intake- http://afepower.com/afe-power-tr-4303p-takeda-stage-2-pro-dry-s-cold-air-intake-system Thanks for the info on the search function as well as the intake and exhaust. SSD Performance has a direct fit intake- http://ssdsubaru.blogspot.com/ Link to comment Share on other sites More sharing options...
Jdog81 Posted November 30, 2016 Share Posted November 30, 2016 http://uploads.tapatalk-cdn.com/20161127/cf5e3c04c1a387b9be96af3b197e3172.jpg Like the rear seat headrest here? Sent from my iPhone using Tapatalk that is a picture of an outback as you can see the cargo cover behind the back seats. Link to comment Share on other sites More sharing options...
Grnlantern1 Posted November 30, 2016 Share Posted November 30, 2016 Thanks for sharing! The only thing i would ask about or get a picture of is how the Front Sway Bar is Mounted? I would hate to see someone spend the money and find out the Front Setup is Different. [emoji6] Sent from my SM-G930P using Tapatalk Link to comment Share on other sites More sharing options...
NavySubsSS Posted November 30, 2016 Share Posted November 30, 2016 Hi I am new to the Subaru world and I'm looking for some advice. I've looked around on here and have not found a clear answer on dual exhaust if it's able to be purchased or it has to be customized. Also I've noticed that some of the part numbers 4 a cold air intake here are four earlier models if anybody can point me in the right direction that would be great thank you for your help You have to go custom. I had a y-pipe welded and hangers installed on the right side. That and 2 MagnaFlow cost me 600 from a local shophttp://uploads.tapatalk-cdn.com/20161130/21223a4d6fb2fc73c8595de539712d34.jpg Sent from my SAMSUNG-SM-G891A using Tapatalk Link to comment Share on other sites More sharing options...
Solkid212 Posted November 30, 2016 Share Posted November 30, 2016 Looks sweet thanks for the info and I promise to use the search first before just throwing random questions out. Haha Link to comment Share on other sites More sharing options...
Solkid212 Posted November 30, 2016 Share Posted November 30, 2016 Also sounds like someone should go into business making just the midpipe going to dual probably would make a good amount of cash lol Link to comment Share on other sites More sharing options...
Opie Posted December 2, 2016 Share Posted December 2, 2016 (edited) CVT Transmission Cooler for Legacy 3.6R (May fit 2.5i as well), parts available from your local dealer: CVT Cooler - 45510AL00A - Qty Needed: 1 CVT Cooler Hose-In - 45520AL00A - Qty Needed: 1 CVT Cooler Hose-Out - 45520AL01A - Qty Needed: 1 CVT Fluid Pipe - 45522AL00A - Qty Needed: 1 Flange Bolt - 010008160 - Qty Needed: 3 Hose Clamp - 909170062 - Qty Needed: 4 Crush Gasket - 806914120 - Qty Needed: 1 High Torque CVT Fluid - Qty needed: 1-2 quarts Install walk through HERE! Same CVT Cooler as found on the Outback, similar design as found on the JDM Only, STI inspired, Forester XT/TS. Keep the tranny cool during track days or spirited driving. Edited December 2, 2016 by Opie Link to comment Share on other sites More sharing options...
ammcinnis Posted December 2, 2016 Share Posted December 2, 2016 (edited) ... (May fit 2.5i as well) ... Thanks for pioneering this mod, and double thanks for documenting it so well. For a 2.5 installation, which uses the G2 CVT and a discrete heat exchanger, the cooler itself will be the same but the hard pipe and hoses will be different due to the different heat exchanger arrangements. Edited December 2, 2016 by ammcinnis "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
CT2015Legacy Posted December 3, 2016 Author Share Posted December 3, 2016 CVT Transmission Cooler for Legacy 3.6R (May fit 2.5i as well), parts available from your local dealer: CVT Cooler - 45510AL00A - Qty Needed: 1 CVT Cooler Hose-In - 45520AL00A - Qty Needed: 1 CVT Cooler Hose-Out - 45520AL01A - Qty Needed: 1 CVT Fluid Pipe - 45522AL00A - Qty Needed: 1 Flange Bolt - 010008160 - Qty Needed: 3 Hose Clamp - 909170062 - Qty Needed: 4 Crush Gasket - 806914120 - Qty Needed: 1 High Torque CVT Fluid - Qty needed: 1-2 quarts Install walk through HERE! Same CVT Cooler as found on the Outback, similar design as found on the JDM Only, STI inspired, Forester XT/TS. Keep the tranny cool during track days or spirited driving. I'll work on getting this added over the next few days. Thank you very much for sharing this with everyone. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Opie Posted December 4, 2016 Share Posted December 4, 2016 You have to go custom. I had a y-pipe welded and hangers installed on the right side. That and 2 MagnaFlow cost me 600 from a local shophttp://uploads.tapatalk-cdn.com/20161130/21223a4d6fb2fc73c8595de539712d34.jpg Sent from my SAMSUNG-SM-G891A using Tapatalk Any pictures of the setup underneath the car? How does it sound? Part numbers of mufflers & tips used? Link to comment Share on other sites More sharing options...
Opie Posted December 5, 2016 Share Posted December 5, 2016 Can anyone confirm or deny if the OEM engine cover on the 3.6R still fits with the Takeda intake? Link to comment Share on other sites More sharing options...
Grnlantern1 Posted December 5, 2016 Share Posted December 5, 2016 Can anyone confirm or deny if the OEM engine cover on the 3.6R still fits with the Takeda intake? Yes it will fit.. Sent from my SM-G930P using Tapatalk Link to comment Share on other sites More sharing options...
NavySubsSS Posted December 7, 2016 Share Posted December 7, 2016 Any pictures of the setup underneath the car? How does it sound? Part numbers of mufflers & tips used? http://uploads.tapatalk-cdn.com/20161207/c22de8c9ca21fae8cce88cb5a7bc3c6d.jpg Sent from my SAMSUNG-SM-G891A using Tapatalk Link to comment Share on other sites More sharing options...
NavySubsSS Posted December 7, 2016 Share Posted December 7, 2016 Any pictures of the setup underneath the car? How does it sound? Part numbers of mufflers & tips used? It's still pretty quiet. They are two street series MagnaFlow. Tips are built into it so no need to buy a set of tips. It has a low resonance but nothing over the top. I can hear the engine more than the exhaust. Again I did it for the looks. If you want a good sound muffler delete is the way to go but that gets annoying fast Sent from my SAMSUNG-SM-G891A using Tapatalk Link to comment Share on other sites More sharing options...
leumaskrap Posted December 7, 2016 Share Posted December 7, 2016 Just a note I installed the new 4inch single wall nameless axlebacks after installing the midpipe from a 3.6r, I dont know if it was just mine, but one of the axlebacks were longer than the other so one side was poking out more. The shop I went to tried to fix it but there was no way to make it even with the other side unless modifying the nameless exhaust. Might end up doing that since I cant send them back since it was already installed during the process. Link to comment Share on other sites More sharing options...
SubiFTW Posted December 8, 2016 Share Posted December 8, 2016 Just a note I installed the new 4inch single wall nameless axlebacks after installing the midpipe from a 3.6r, I dont know if it was just mine, but one of the axlebacks were longer than the other so one side was poking out more. The shop I went to tried to fix it but there was no way to make it even with the other side unless modifying the nameless exhaust. Might end up doing that since I cant send them back since it was already installed during the process. You got an OEM mid pipe from 3.6r from Subaru? How much did it cost ya? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
leumaskrap Posted December 8, 2016 Share Posted December 8, 2016 You got an OEM mid pipe from 3.6r from Subaru? How much did it cost ya? Sent from my iPhone using Tapatalk Around $175ish shipping included Link to comment Share on other sites More sharing options...
SubiFTW Posted December 8, 2016 Share Posted December 8, 2016 Around $175ish shipping included You have a pic of your setup? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
leumaskrap Posted December 8, 2016 Share Posted December 8, 2016 You have a pic of your setup? Sent from my iPhone using Tapatalk Ill take a pic of it when lifted up tomorrow for the better fitment. Link to comment Share on other sites More sharing options...
Solkid212 Posted December 8, 2016 Share Posted December 8, 2016 Ill take a pic of it when lifted up tomorrow for the better fitment. Did you have to modify the 3.6 midpipe? That would be great if it matches up. Link to comment Share on other sites More sharing options...
leumaskrap Posted December 8, 2016 Share Posted December 8, 2016 (edited) Nameless 4 inch Single wall tip deletes with a 3.6r stock midpipe. Thanks to all that have helped me, you know who you are and if anyone needs help I can answer your questions just like how a handful of guys helped me. Just message me, dont worry my reply wont be "use the search bar" https://vimeo.com/194850861 Sent from my iPhone using Tapatalk Edited December 8, 2016 by leumaskrap Link to comment Share on other sites More sharing options...
TruNoLies Posted December 8, 2016 Share Posted December 8, 2016 Nameless 4 inch Single wall tip deletes with a 3.6r stock midpipe. Thanks to all that have helped me, you know who you are and if anyone needs help I can answer your questions just like how a handful of guys helped me. Just message me, dont worry my reply wont be "use the search bar" https://vimeo.com/194850861 Sent from my iPhone using Tapatalk Man that sounds great, No way I can stick with the single pipe! Link to comment Share on other sites More sharing options...
leumaskrap Posted December 8, 2016 Share Posted December 8, 2016 Man that sounds great, No way I can stick with the single pipe! If you need help message me. I need to give the other guys a break after helping me out on the forums haha. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
