boxkita Posted December 22, 2014 Author Share Posted December 22, 2014 Drop the bottom idler pulley off and pop goes the belt. MAKE SURE that the crank mark is lined up first as it will prevent any possibility of the valves touching pistons. I just put a belt kit on a 2.5 DOHC N/A Outback that I bought and it's a pain in the ass because of course, on this particular engine, it HAS REGULAR DAMN CAM BOLTS, so my Company 23 cam lock tool won't work...Figures. The Company 23 tool rules though. Put the belt on my engine build in about 15 minutes and it was correct the first time. When you go to put the belt back on, make sure and look at the lines on the timing belt and how they line up on the gears single hash marks and it will answer any questions about alignment. Boxman wanted to flip the motor right-side up before he left. Now I see why. :-) Thanks for info. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxman Posted December 22, 2014 Share Posted December 22, 2014 That damned pulley. I didn't think about the rubber having enough give to make the impact useless. I've had similar issues with nylock nuts absorbing just enough of the impact to make you grab a ratchet. I'm guessing that the flex is also why the breaker bars with extensions didn't work either. I'm really glad that you had purchased the flywheel lock or we'd still be bouncing on that thing and cursing it. Mine was nowhere near that hard to get off. You'll want to slide the pulley back on to line up the crank marks since it has the slot for the key on the crank snout. Fun times and Boxkita Drama™® Link to comment Share on other sites More sharing options...
SBT Posted December 22, 2014 Share Posted December 22, 2014 Also, before you pull the belt "guides" at the corners and above the main sprocket - these keep the belt from jumping teeth if the car is accidentally bumped while in gear - measure the gap and make sure it's 1.0 +/- 0.5 mm (0.039 +/- 0.020 in) when you reinstall these. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
boxkita Posted December 22, 2014 Author Share Posted December 22, 2014 Also, before you pull the belt "guides" at the corners and above the main sprocket - these keep the belt from jumping teeth if the car is accidentally bumped while in gear - measure the gap and make sure it's 1.0 +/- 0.5 mm (0.039 +/- 0.020 in) when you reinstall these. Looking at the corners, I have metal guides. Looks like those got upgraded in the build, as I thought they were plastic from the factory. Will check the clearance on reinstall. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
SBT Posted December 22, 2014 Share Posted December 22, 2014 My 05 corner and main sprocket guide are all metal. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
FJuan Posted December 22, 2014 Share Posted December 22, 2014 When are you going to start? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
MrTris Posted December 22, 2014 Share Posted December 22, 2014 B, I bought the Tomioka belt guide for $40, even comes in STi pink. See Amazon. Link to comment Share on other sites More sharing options...
boxkita Posted December 22, 2014 Author Share Posted December 22, 2014 When are you going to start? The hours of standing on concrete are taking their toll. Drugs are becoming a way of life. will start again tonight Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
MrTris Posted December 22, 2014 Share Posted December 22, 2014 Drugs are becoming a way of life. inb4rehab Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 22, 2014 Share Posted December 22, 2014 Inb4walterwhite 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
boxkita Posted December 22, 2014 Author Share Posted December 22, 2014 Ok. YOu got me there. SMH Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Gex Posted December 23, 2014 Share Posted December 23, 2014 We thinking mid January for reassembly? Link to comment Share on other sites More sharing options...
MrTris Posted December 23, 2014 Share Posted December 23, 2014 We thinking mid January for reassembly? Ha! He's shooting to have his car ready to rock come Skills Day! Link to comment Share on other sites More sharing options...
Gex Posted December 23, 2014 Share Posted December 23, 2014 So weekend after New Years? Link to comment Share on other sites More sharing options...
boxkita Posted December 23, 2014 Author Share Posted December 23, 2014 We thinking mid January for reassembly? Ha! He's shooting to have his car ready to rock come Skills Day! So weekend after New Years? I'm dependent on the machine shop and getting the heads to them. Not going to make it before Christmas, so will have to be next week. Regardless, I'm motivated to get it done and out of the garage. The longer it sits there, the more shopping I do (KillerB Motorsports has too much shiny). Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxman Posted December 24, 2014 Share Posted December 24, 2014 Hey moderator types mod the weed talk out and lets keep this semi-technical and topical...please. Link to comment Share on other sites More sharing options...
LatentWagen Posted December 24, 2014 Share Posted December 24, 2014 OP is a mod Has that hoist recovered yet? Cruel and unusual... LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
boxman Posted December 24, 2014 Share Posted December 24, 2014 , imagine that? Dunno, when I was over there on Sunday it was looking a little odd, I think maybe Tris knocked it up. I have no idea what the offspring are gonna look like though... Link to comment Share on other sites More sharing options...
boxkita Posted December 24, 2014 Author Share Posted December 24, 2014 grass is greener in the General Chat section - http://legacygt.com/forums/showthread.php/co-wa-members-only-235214.html Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted December 24, 2014 Author Share Posted December 24, 2014 Mod has spoken. This thread is about Boxkita's HG drama. Everything else, goes somewhere else. Capiche? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
FJuan Posted December 24, 2014 Share Posted December 24, 2014 So much talk and not enough build in herre. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
boxkita Posted December 24, 2014 Author Share Posted December 24, 2014 Working thru Christmas Eve. Looking forward to 4 days off to play with car. And post some pics...all 4 of them. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
FJuan Posted December 24, 2014 Share Posted December 24, 2014 And post some pics...all 4 of them. :lol: My wife's balls are delicious. Link to comment Share on other sites More sharing options...
boxkita Posted December 24, 2014 Author Share Posted December 24, 2014 Looks like I get to home early. IT decided to ignore "blackout" and do work anyways. Every server I need is offline. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxman Posted December 24, 2014 Share Posted December 24, 2014 Link to comment Share on other sites More sharing options...
