Boxkita's random thoughts while wagon collects dust in the garage
What color to paint head & valve covers?
78 members have voted
  1. 1. What color to paint head & valve covers?
    • Both cherry blossom (Subaru Pink)
      25
    • Both hello kitty pink
      3
    • Heads no paint, covers cherry blossom
      12
    • Heads no paint, covers hello kitty pink
      5
    • Both no paint
      11
    • Profanity - why would do that?
      22
Given the amount of time I've been on this forum, I'm somewhat ashamed to admit I've never done any engine work on my car. Whether I was lucky or had lots of bucks to pay someone else is not relevant. Times have changed and I can no longer "outsource" my engine work. So bring it...
With that out of the way, my stage 4 wagon started blowing white smoke after a dozen or so hard slalom runs back in May. I limped it home. Then took it to my shop of choice for a second opinion. They agreed that the HGs were on the way out (little black floaties in the upper coolant tank), as well as the radiator being toast. Me, being somewhat paranoid and desiring to avoid more drama, parked it and bought another car.
Now, many months later, after, in a moment of weakness, confessing to Mrs Boxkita that I was trying to find a sponsor who would be willing to finance the conversion of said wagon into a racecar; I can choose to sleep in the car or I can sell it. As the days of sleeping in my car still do not bring good memories, I need to fix it and sell it. As noted above, a change in finances means I'm doing this job in my garage with my tools and likely borrowed tools and hopefully some more experience help.
Given my tendency to incur drama with this car, feel free to comment/suggest/heckle as you see fit. I'll try to share my adventures with pictures and words. Although I do have a deadline, so at some point, I may get frustrated and part it out.
So...
  • Replies 1.5k
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Parts list:
Crank Seal: 806733030
Intake Cam Seal: 806742160
Exhaust Cam Seal: 806732160
Intake Cam Bolt: 13199AA000
Exhaust Cam Bolt: 13199AA010
Master Gasket kit: PN 10105AA720
Cam Gear Bolts: http://turninconcepts.com/tic-fu-cam-bolt-kit-single-avcs.html
Crank Pulley list: http://legacygt.com/forums/showthread.php/crank-pulley-list-price-weight-part-s-221509.html FluidDamper - http://www.fluidampr.com/
Crawford AOS v2 GB - http://forums.nasioc.com/forums/showthread.php?t=2683500
PW T-Bolts - http://legacygt.com/forums/showpost.php?p=4123347&postcount=3117
FuijBond/HondaBond - http://legacygt.com/forums/showpost.php?p=5318790&postcount=136
Tools list:
8mm-17mm, plus 22mm, 24mm deep, plus extensions & wobbly u-joint.
6mm 6-point 1/4 inch or 3/8 inch socket for the oil covers on the cam sprockets
14mm 12pt for the head bolts
17mm & 19mm open end wrench for the Company23 Cam Tool 1
22mm 6-point 1/2 inch for the crank pulley bolt
36mm wheel bearing socket for setting the cam seals with rubber mallet
5/16inch 12point socket for arp studs nut
T-25 Torx screwdriver for the fuel injector screws.
TorxPlus TP50 for flywheel nuts?
O2 sensor socket
set of metric hex bits so I can pull the pressure plate
a breaker bar
rubber mallet
What to buy threads:
MrTris rebuild list - http://legacygt.com/forums/showthread.php/engine-rebuild-shopping-list-226719.html
How to threads:
MrTris build thread - http://legacygt.com/forums/showthread.php/tris-build-thread-223568.html
Max Capacity build thread - http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106.html
Rebuild Head (JmP) - http://legacygt.com/forums/showpost.php?p=4812508&postcount=121
Rebuld head (YT) -
Replace Crank Pulley - http://legacygt.com/forums/showthread.php/install-lightweight-crank-pulley-224447.html
Remove Cam Bolts (TL) - http://legacygt.com/forums/showpost.php?p=4800753&postcount=74
Company23 CamTool usage - http://www.company23.com/download/Subaru%20Camlock%20Manual.pdf
Company23 Cam Sprocket tool usage - http://www.company23.com/download/Subaru%20Cam%20Sprocket%20Tool%20Manual.pdf
Replace Crank Cam Seals - http://legacygt.com/forums/showthread.php/replace-crank-cam-seals-222936.html
Replace Timing Belt - http://legacygt.com/forums/showthread.php/timing-belt-replacement-2-5t-106809.html
Replace Timing Belt (Video) - http://legacygt.com/forums/showthread.php/video-timing-belt-replacement-2-5t-229365.html
Remove Banjo Bolt screens - http://legacygt.com/forums/showthread.php/remove-all-banjo-filters-222758.html
HammerDown's version - http://legacygt.com/forums/showpost.php?p=4769949&postcount=2
Replace PW TMIC - http://legacygt.com/forums/showthread.php/processwest-intercooler-install-lgt-fitment-170515.html
CovertRussian's rebuild thread - http://legacygt.com/forums/showthread.php/covertrussians-05-lgt-build-thread-218363.html
Replace 2.8 LGT ratio with 2.4 STI - http://legacygt.com/forums/showthread.php/underdog-motorsports-2015-sti-steering-rack-swap-234351.html
Replace PS o-ring - http://legacygt.com/forums/showthread.php/power-steering-o-ring-fix-197481.html
FLuidDamper testing - http://www.motoiq.com/MagazineArticles/ID/2829/PageID/5561/Project-GD-STI--Improving-the-Fuel-System-with-Injector-Dynamics-and-Other-Details.aspx
OEM Gasket set - http://www.scoobymods.com/showthread.php/4th-gen-legacy-gt-engine-14437.html?t=14437
Starter Motor rebuild - http://www.scoobymods.com/showthread.php/diy-walk-through-ej2-x-14407.html?t=14407
Side Feed Injector R&R - http://www.scoobymods.com/showthread.php/4th-gen-legacy-2005-2006-14328.html?t=14328
Fuel Pump Control Module Wiring Upgrade - http://www.scoobymods.com/showthread.php/diy-4th-gen-legacy-gt-14434.html?t=14434
....Original thread - http://legacygt.com/forums/showthread.php/upgrading-your-fuel-pump-wiring-4th-gen-213570.html?highlight=FPCM+WIRING
Power Steering Pump Fluid Upgrade - http://www.scoobymods.com/showthread.php/diy-4th-gen-legacy-power-14640.html?t=14640
Fuel & Vacuum Line routing - http://legacygt.com/forums/attachment.php?attachmentid=167975&d=1384657978
Turbo stud solution - http://legacygt.com/forums/showthread.php/no-more-stripped-turbo-tmic-threads-75715.html
Before Startup:
http://legacygt.com/forums/showthread.php/diy-oil-system-priming-tank-214760.html
Shops:
Witch hunter Performance (for injector testing) - http://legacygt.com/forums/showpost.php?p=4803599&postcount=87
Edited by boxkita
Ordered List:
Purchased List:
[ame=http://www.amazon.com/Grimmspeed-Phenolic-Thermal-Spacer-3mm/dp/B0054RGIKU/]3mm Phenolic Spacers[/ame] - delivered
[ame=http://www.amazon.com/gp/product/B000CMF20O/]Mr Gasket 738G: [/ame] - delivered
cam gear bolts! $40 from TurnIn Concepts - borrowed from BMB until mine ship
Mishimoto X-Line radiator - delivered
Mishimoto hose kit (black) - delivered
OEM Subaru master gasket set - delivered
(6) cans of CRC brake cleaner - delivered (still owe MrTris)
(2) Blackstone oil analysis kits - delivered (still owe MrTris)
Infamous VenAir hoses (all 3 options) - delivered
Gates Racing TB Component Kit from Infamous
AEM DryFlow Panel Filter from Infamous
OEM Crank Pulley
(2) p/s pump o-rings
(3) OEM oil filters & gasket (need to return these)
PCV valve
(3) "black" oil filters & gasket - http://pages.ebay.com/link/?nav=item...d=181356739512
Hose kit from FreeRange Racing - delivered
(2) Napa "true black" RTV sealant/gasket maker. Had to buy a new one after destroying the first one with vise grips
07 Topfeed TGV, unmodified
SpecB front LCA, rear trailing arms, and upper rear arm
07 STI v25b heads - http://legacygt.com/forums/showpost.php?p=5177101&postcount=1 - 2007 sti v25b heads (unicorn heads :cool: ) with supertech springs, titanium retainers, inconel std size exhaust valves, std size intake valves, and stock cams. Cams were just polished, journals all line honed and polished a month ago, comes with all new cam cap bolts. The driver side head will need some new valves due to the timing belt tensioner failure. Nasioc post on the heads - http://forums.nasioc.com/forums/showthread.php?t=1471829
GTSpec EL headers w/welded slip joints - http://legacygt.com/forums/showpost.php?p=5177101&postcount=1
Headlights w/5k HID installed - http://legacygt.com/forums/showpost.php?p=5177101&postcount=1
Headlights w/HID installed - by MrTris
Stock Y-pipe with muffler deletes welded on - http://legacygt.com/forums/showthread.php/wa-catback-straight-pipes-stock-249310.html
Company23 TB guide
Company23 Valve Spring Compressor
2 OEM HG - cause you need 2 not 1.
Edited by boxkita
more parts
Parts/Tools on loan:
Company23 cam wrenches - Boxman
Crank Pulley Wrench - Boxman
Crane Leveler - Boxman
Crane & engine stand - MrTris
Tools returned:
Cam Bolts from TiC - BMB
Company23 cam wrenches + overnight shipping - BMB
Edited by boxkita
return BMB's tools
  • Moderators
John, FWIW, I don't think this is anything you can't handle with write ups that are here and else where. Pull the motor (easy enough, just some time), remove heads, have a shop R&R 'em, slap it back together.
Not currently in stock :(
So, I'm driving home thinking about taking the car apart. Pretty soon, I'm thinking of what else I could do, too. By the time I got home, I'd ported/polished the heads, added ELH, racing radiator, Infamous hose kit, Crawford AOS, custom single outlet exhaust, put on the aero bits, and thinking about caging it. Then I remembered why I was doing my own engine work. G'damn lotto.
  • Moderators
You have a problem :lol:
Now pull your motor, g'dammit! Don't buy anything, just pull it and disassemble. Then figure out what you NEED to reassemble and buy those bits.
You have read my thread haven't you...? only take apart what you have to. See my click here link...you should have seen it by now...your not new here.
The three of us can give you all the help you need.
305,000miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. CHECK your oil, these cars use it.
Engine Build - Click Here
Kettle meet Pot... :lol:
In for possible and inevitable future need to do myself. I have the same problem of thinking about all I want to do. I sketched out an priced a $20,000 fully closed deck engine build with all forged internals, larger cams, and all kinds of other stuff that would just end up causing damage to the car itself. Good luck with the HG repair.
2005 Vader Wagon
Material Tests on Ringland Failure Piston
I should have held off and purchased a wagon instead of the spec.B
Guest
This topic is now closed to further replies.
