MrTris Posted December 30, 2014 Share Posted December 30, 2014 You may need to source a pin for the tensioner, otherwise, getting it back on will be a bitch. Or maybe just buy a new tensioner? Link to comment Share on other sites More sharing options...
SBT Posted December 30, 2014 Share Posted December 30, 2014 Summitt Racing .001 straight edge: http://www.summitracing.com/parts/cbi-56429/overview/ Please don't use a HF level !!! Ship date on that straight edge, if ordered today, is 2/5/2015. Drama must ensue Agree on the HF level. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
boxkita Posted December 30, 2014 Author Share Posted December 30, 2014 Ship date on that straight edge, if ordered today, is 2/5/2015. Drama must ensue Agree on the HF level. Part of the reason I chose to source something locally. I may have to the Miata in the future. So still contend this is good enough. The truth will come from the machine shop in a week or so. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted December 30, 2014 Author Share Posted December 30, 2014 You may need to source a pin for the tensioner, otherwise, getting it back on will be a bitch. Or maybe just buy a new tensioner? Doesn't a timing belt kit come with all those parts? Also, doesn't a 2mm allen wrench work for the tensioner? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxman Posted December 30, 2014 Share Posted December 30, 2014 I believe that a 2mm allen wrench would work just fine for the tensioner. You should be able to compress it again with a ratchet strap or a clever application of a pipe clamp. Link to comment Share on other sites More sharing options...
FJuan Posted December 30, 2014 Share Posted December 30, 2014 Doesn't a timing belt kit come with all those parts? Also, doesn't a 2mm allen wrench work for the tensioner? Yes & yes. The tensioner should come already compressed. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
MrTris Posted December 30, 2014 Share Posted December 30, 2014 Yes, it should. I had read it like he was gonna reuse the timing gear. . Link to comment Share on other sites More sharing options...
SBT Posted December 30, 2014 Share Posted December 30, 2014 Think I'm going to order this [ame=http://www.amazon.com/Starrett-380-24-24-Inch-Steel-Straight/dp/B0006J4GKK/ref=sr_1_1?ie=UTF8&qid=1419968626&sr=8-1]Starrett 24" straight edge[/ame] and a set of these [ame=http://www.amazon.com/Stanley-Proto-J000AA-Master-Feeler/dp/B001HWDOK8/ref=sr_1_2?s=hi&ie=UTF8&qid=1419969862&sr=1-2]Proto Feeler Gauges [/ame]just in case. Always good to have them in case you need them... and who doesn't need quality tools. [ame=http://www.amazon.com/Stanley-Proto-J000AA-Master-Feeler/dp/B001HWDOK8/ref=sr_1_2?s=hi&ie=UTF8&qid=1419969862&sr=1-2][/ame] - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
boxkita Posted December 30, 2014 Author Share Posted December 30, 2014 Think I'm going to order this Starrett 24" straight edge and a set of these Proto Feeler Gauges just in case. Always good to have them in case you need them... and who doesn't need quality tools. From Starrett's site - http://www.starrett.com/metrology/product-detail/1-Precision-Measuring-Tools/11-Precision-Hand-Tools/1111-Precision-Rules,-Straight/111103-Straight-Edges/380-24 Accuracy -± .0002” per foot Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted December 30, 2014 Author Share Posted December 30, 2014 Yes, it should. I had read it like he was gonna reuse the timing gear. . I'll try the spin test on the replaceable parts. The blue transfer on the gears, while benign, looks like it should go new gears. The timing belt has ~30k miles on it. Based on current usage, the HG will go before the belt. Debating (looking at cost) whether to replace the TG & belt or re-use. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
DavidInSeattle Posted December 30, 2014 Share Posted December 30, 2014 Starrett makes very nice stuff. Spendy, but nice stuff. Link to comment Share on other sites More sharing options...
boxkita Posted December 30, 2014 Author Share Posted December 30, 2014 Starrett makes very nice stuff. Spendy, but nice stuff. I buy Starrett at every garage sale. Along with other spendy high-end tools. Never found a straight edge. Spending $80 (feeler gauge + straight edge), then another $100-300 at a machine shop seems like overkill. However, I'm more than a bit curious how "flat" the heads are. And I'm sure the machine shop is just panting to have me stand over their shoulder with dumbass questions. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
FJuan Posted December 30, 2014 Share Posted December 30, 2014 If you have over 100k miles on those heads, and they are leaking, I guaranty they need to be machined. Better to be safe than sorry, because I took the sorry route the 1st time and had to go back in and pull them out. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
boxkita Posted December 30, 2014 Author Share Posted December 30, 2014 If you have over 100k miles on those heads, and they are leaking, I guaranty they need to be machined. Better to be safe than sorry, because I took the sorry route the 1st time and had to go back in and pull them out. The original heads are gone. These were pulled "STI" heads on the rack that had already been machined. In theory, they should have 30k miles on the machining. It's been roughly 3 years since the engine was worked on (Jan 2012 was the rebuild), so any warranty is long past expired. JmP says I should be be to remove old HG, check for flatness, and if good put a new set on and go. Seeing as I had no way to check for flatness, I bought a couple of tools. My hope is the car was parked soon enough that the HG have only a small failure and the heads are fine. Until I get the heads off, any speculation is just that. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted December 30, 2014 Author Share Posted December 30, 2014 Added a poll. Make your choice. Winner gets to share in the joy. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
MrTris Posted December 30, 2014 Share Posted December 30, 2014 I chose the closest option to , "You need a new shortblock." Link to comment Share on other sites More sharing options...
boxkita Posted December 30, 2014 Author Share Posted December 30, 2014 I chose the closest option to , "You need a new shortblock." I purposely left that option off, as it would be the only one picked. Thanks for proving me right. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
FJuan Posted December 30, 2014 Share Posted December 30, 2014 Well lets do the comparison. 1) Spend $100 in tools to measure the deck. If flat and within range, good to go. If not, spend another $130 to have them machine. 2) Spend $130 for the machine shop to inspect and machine, save yourself $100 in tools. No brainer for me, I'll spend the extra $30 bucks every time. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
DavidInSeattle Posted December 30, 2014 Share Posted December 30, 2014 If you buy the tools, they are an investment in the next head gasket job. Link to comment Share on other sites More sharing options...
MrTris Posted December 31, 2014 Share Posted December 31, 2014 If you buy the tools, they are an investment in the next head gasket job. But he wants to take it to Old Man Anal . . Machine Shops [/insidejoke] Link to comment Share on other sites More sharing options...
DavidInSeattle Posted December 31, 2014 Share Posted December 31, 2014 But he wants to take it to Old Man Anal . . Machine Shops [/insidejoke] Well...who doesn't really? Link to comment Share on other sites More sharing options...
boxkita Posted December 31, 2014 Author Share Posted December 31, 2014 If you buy the tools, they are an investment in the next head gasket job. Yeah, thanks for that insight. I'm sure the Miata will puke on me soon and will need a rebuild. Likely it will happen at the track, so we'll be doing a hack job to get back on track. Hence, $80 of tools will pay off. Reminds me, I need to throw in the angle grinder to get the head flat quicker. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
DavidInSeattle Posted December 31, 2014 Share Posted December 31, 2014 Nah, just get a piece of square tube (as a sanding block) and various grits of sandpaper. You'll have that thing flat in no time. Link to comment Share on other sites More sharing options...
boxkita Posted December 31, 2014 Author Share Posted December 31, 2014 Nah, just get a piece of square tube (as a sanding block) and various grits of sandpaper. You'll have that thing flat in no time. I'll that on the wagon, too. I've got some 40 grit left over from a house remodeling project. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxman Posted December 31, 2014 Share Posted December 31, 2014 just use some 3m spray adhesive to adhere sandpaper to the wide side of your machinists square and go to town. Or you can buy a 24" square of thick plate glass and some large sheets of sandpaper, 3m the paper down and move the heads over the glass and sandpaper... Link to comment Share on other sites More sharing options...
