Turkeylord Posted August 24, 2015 Share Posted August 24, 2015 ^Do that, and cycle the key a bunch of times to flush the old stuff out of the lines. A 10sec job with the engine out of the car. Took me like an hour. Working on the engine sucks when it's in the car! #spoiled Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 24, 2015 Author Share Posted August 24, 2015 I think I'm going to wait until Mike send me my AP v3, then I'll pop off the fuel lines, turn the key on and let it pump the old crap out the new stuff in the tank and then put it all back on and see how it goes. But I'm pretty sure that noise has nothing to do with the fuel unfortunately "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 24, 2015 Share Posted August 24, 2015 Dude, you're dealing with 2 year old fuel. Fuel starts breaking down within 4 months. Take that fuel and put it in a lawn mower and see what happens. Did you get any CELs after start up? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 24, 2015 Author Share Posted August 24, 2015 I know old had is bad, but I still don't think it's causing the noise. Sounds mechanical. How long do the AVCS take to get full oil pressure ususlly No cels "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 24, 2015 Share Posted August 24, 2015 As soon as the oil pumps, should only take a second or 2. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 25, 2015 Share Posted August 25, 2015 One of the cams off a tooth possibly? That is a strange noise. Link to comment Share on other sites More sharing options...
FJuan Posted August 25, 2015 Share Posted August 25, 2015 If the cams are off a tooth then you'll get rough idle and/or some back fires. He has some major knocks going on. Hopefully it's just a fuel issue. Fingers crossed. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 25, 2015 Share Posted August 25, 2015 Yeah I hear you... It's just such a weird noise. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 26, 2015 Author Share Posted August 26, 2015 I bought, and got, a thing for it. http://images.tapatalk-cdn.com/15/08/25/80e7405411daff9a16d2045bcf1a43dc.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 26, 2015 Author Share Posted August 26, 2015 Cruise control keeps flashing. https://youtu.be/eT5Odvg1qTI And I do have a code, by there wasn't a CEL. http://images.tapatalk-cdn.com/15/08/26/44ad4384cc4980c765f5ced865c48d3e.jpg So I suppose I need to look into my pcv "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 26, 2015 Share Posted August 26, 2015 Yup, make sure the PVC connector and hoses are secured. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 26, 2015 Author Share Posted August 26, 2015 haha, i disassembled and reassembled the engine, and dont know where the pcv is:lol: "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 26, 2015 Share Posted August 26, 2015 Edit: It's located to the right of the turbo, top back middle of the block, under the I/C. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 26, 2015 Author Share Posted August 26, 2015 oh, its that little POS thats a PITA to get to. wonderfull "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 26, 2015 Share Posted August 26, 2015 Yup, that would be the one. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
rhino6303 Posted August 27, 2015 Share Posted August 27, 2015 Do you have the original pcv set up still? There is an electrical connector where the pcv connects to the inlet; it is a gray plug. If you removed the gray plug you must take the metal clip from the plug and insert it in the connector. Without the clip in the connector the car will have that code. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 27, 2015 Author Share Posted August 27, 2015 Do you have the original pcv set up still? There is an electrical connector where the pcv connects to the inlet; it is a gray plug. If you removed the gray plug you must take the metal clip from the plug and insert it in the connector. Without the clip in the connector the car will have that code. I did pull it off and put it back on. I'll check out the plug tomorrow though, thanks! "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 27, 2015 Author Share Posted August 27, 2015 Gas, and cokstain booster. Done. https://youtu.be/78JXz89mt3Q "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
MTBwrench Posted August 27, 2015 Share Posted August 27, 2015 cokstain booster. I'm not sure if that's supposed to be pleasurable or painful... MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 27, 2015 Author Share Posted August 27, 2015 UPDATE! Ran some old fashioned sound diagnostics(I listened, and used my previous experiences). narrowed it to the PS pump, or ALT. Pretty sure its the alternator though. going to throw the belt back on and then use a socket extension to see if im right...im hoping bearings are ok and that i jsut had the belt too tight. 1st clip, control, no change 2nd clip, A/C on, no change 3rd clip, no PS/ALT belt, sound is gone. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
MTBwrench Posted August 27, 2015 Share Posted August 27, 2015 Yay for easy diagnosis! Maybe your belt was just too tight? Not gonna lie though, sounds like bad bearings to me... or one of the brushes cracked and is chunking around against the commutator on the alt. MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 27, 2015 Share Posted August 27, 2015 Can you run the engine with out the belt on the Alt ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 27, 2015 Share Posted August 27, 2015 Yes but it will use up the battery pretty quickly, since all electrical power is only coming from the battery. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 27, 2015 Author Share Posted August 27, 2015 Can you run the engine with out the belt on the Alt ? Of course. I did in that vid actually. The belt is sitting on the intake. Yes but it will use up the battery pretty quickly, since all electrical power is only coming from the battery. This. Only ran it for a little bit, & I did have the battery charger on it while I was running it. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Matt166 Posted August 28, 2015 Share Posted August 28, 2015 Glad you got it figured out and it's an easy fix! Link to comment Share on other sites More sharing options...
