RooTBeeR Posted June 16, 2015 Author Share Posted June 16, 2015 Selling it because you aren't upgrading turbo? I was told just use the stock banjo bolt instead of the supplied ones. Yeah, JMP(who rebuilt my turbo) warned against it still. And I'll never be going bigger than a vf52(which still doesn't need that much oil) "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Merc6 Posted June 16, 2015 Share Posted June 16, 2015 Yeah, JMP(who rebuilt my turbo) warned against it still. And I'll never be going bigger than a vf52(which still doesn't need that much oil) Seller of said kit says it's ok but only with the OEM banjo bolt. Who knows, we both may say F it and go bigger turbo last possible second and now have the proper parts for it. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
alex0856 Posted June 16, 2015 Share Posted June 16, 2015 IIRC JmP does not recommend it because the increased flow runs the risk of floating the turbo bearings. I've had this same talk with him. Link to comment Share on other sites More sharing options...
Merc6 Posted June 16, 2015 Share Posted June 16, 2015 IIRC JmP does not recommend it because the increased flow runs the risk of floating the turbo bearings. I've had this same talk with him. I had the same talk and M prank he said just use the OEM banjo to slow the flow down. Both agreed it was overkill for the VF's but I was originally going for a BNR when I got it. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 16, 2015 Share Posted June 16, 2015 I ran a vf40 with the ipt kit for 65k miles. I'm now on my 18g with it. Just use the oem banjo bolt. Link to comment Share on other sites More sharing options...
boxman Posted June 16, 2015 Share Posted June 16, 2015 Yeah, JMP(who rebuilt my turbo) warned against it still. And I'll never be going bigger than a vf52(which still doesn't need that much oil) The orifice in the stock bolt will provide properly metered oil into the turbo irrespective of whether you're using the IP&T filter or not. The filter and upgraded supply pipe doesn't, and never will, cause more oil to flow into the turbo than the stock bolt will allow. Period. End of story. If you don't want to spend the extra money, then don't spend the extra money, but don't sell it out of fear that it'll kill your newly rebuilt turbo. I respect both JMP and msprank. I suspect that msprank doesn't counter this simply because he doesn't want the internet slap fight that would ensue and he's decided that any lost sales aren't impactful enough to his business to be worth the fight. I believe that JMP doesn't want to have to deal with customers that put in the upgraded bolt and kill their newly rebuilt turbo because they can't RTFM. IMO the situation is a damned shame and in the long run In the long run I think that JMP is doing a disservice to msprank. My intent isn't to call out JMP, as I said I respect him and his knowledge a great deal. I purchased one of his Custom VF40s and couldn't be happier with the performance increase. Link to comment Share on other sites More sharing options...
StkmltS Posted June 16, 2015 Share Posted June 16, 2015 The orifice in the stock bolt will provide properly metered oil into the turbo irrespective of whether you're using the IP&T filter or not. The filter and upgraded supply pipe doesn't, and never will, cause more oil to flow into the turbo than the stock bolt will allow. Period. End of story. I'm not familiar with how/where the IP&T filter installs, but wouldn't an inline filter only allow a higher flow if it was setup in a way that bypassed the stock banjo bolt... right? My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
Turkeylord Posted June 16, 2015 Share Posted June 16, 2015 The orifice in the stock bolt will provide properly metered oil into the turbo irrespective of whether you're using the IP&T filter or not. The filter and upgraded supply pipe doesn't, and never will, cause more oil to flow into the turbo than the stock bolt will allow. Period. End of story. Yes, the stock turbo banjo bolt has a small hole, but I was under the impression that the real restrictor orifice was built into the hard line. Link to comment Share on other sites More sharing options...
boxman Posted June 16, 2015 Share Posted June 16, 2015 Yes, the stock turbo banjo bolt has a small hole, but I was under the impression that the real restrictor orifice was built into the hard line. I've never read that assertion Link to comment Share on other sites More sharing options...
Turkeylord Posted June 17, 2015 Share Posted June 17, 2015 I've never read that assertion Here's a pic from Forced Performance http://store.forcedperformance.net/merchant2/graphics/subaru_oil/oil_manifold.jpg Link to comment Share on other sites More sharing options...
RooTBeeR Posted June 17, 2015 Author Share Posted June 17, 2015 Here's a pic from Forced Performance http://store.forcedperformance.net/merchant2/graphics/subaru_oil/oil_manifold.jpg I did notice that whenni had it off. And I honestly could use that money for a lot of other things, including the car. And I've already put that kid on and off too many times. So it's staying off. Lol hopefully I can find someone to buy it off of me. I know I'm going to take a bit of a loss, but oh well. And if I ever did do an aftermarket turbo later, I just buy a whole new kit.( the chances of that happening are slim to none ) "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted June 17, 2015 Author Share Posted June 17, 2015 So that being said, anyone want to buy my filtered oil line kit? "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
boxman Posted June 17, 2015 Share Posted June 17, 2015 I would, but I kinda already have one... Good find on the pics. I'll have to dig in and read more. Still gonna stick with the filter kit. Sent from my SM-G900T using Tapatalk Link to comment Share on other sites More sharing options...
StkmltS Posted June 17, 2015 Share Posted June 17, 2015 I would, but I kinda need to save for my own probable #ynansb adventure. My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
RooTBeeR Posted July 3, 2015 Author Share Posted July 3, 2015 Woohoo! I finally just got the tracking number for my TGV deletes. Still waiting on my venair hoses though "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted July 15, 2015 Author Share Posted July 15, 2015 07/06/2015 Zerolift TGV Delete Kit http://images.tapatalk-cdn.com/15/07/15/bdf51ca300b5f38b6f45d3fbf14ba65b.jpg 07/13/2015 Venair Silicon Hose Kits http://images.tapatalk-cdn.com/15/07/15/ad380d3a96897ca7192693915ca645b1.jpg Big thanks to Mike for helping me out and for the Shirt and Stickers!!! "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted July 15, 2015 Share Posted July 15, 2015 Awesome! My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted July 16, 2015 Share Posted July 16, 2015 Nice. Link to comment Share on other sites More sharing options...
RooTBeeR Posted July 16, 2015 Author Share Posted July 16, 2015 I blue the engine. http://images.tapatalk-cdn.com/15/07/16/de267524dd08bf87bf9d1c2e3880aa8d.jpg http://images.tapatalk-cdn.com/15/07/16/e41a972f16484792b4419b18f4330613.jpg http://images.tapatalk-cdn.com/15/07/16/e84306918d19a16fe7c03700aeceec56.jpg Put some silicon implants on it. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 5, 2015 Author Share Posted August 5, 2015 08/04/2015 Finally put my Flex(Drive) plate on. http://images.tapatalk-cdn.com/15/08/04/2d6fc20a0436e63fe9e3f7656c391594.jpg Plan to get the tq converter on the trans tomorrow. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 6, 2015 Share Posted August 6, 2015 Um....you have the turbo heat shield on backwards..... Wait...optical illusion? It sure looks like it's backwards but then again......hmmm....... Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 6, 2015 Author Share Posted August 6, 2015 Just an illusion. It only bolts on one way. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted August 6, 2015 Share Posted August 6, 2015 You do know you have to remove that heatshield to bolt the DP on....or is that an optical illusion...? Are you using anti-seize compound on the threads ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 6, 2015 Author Share Posted August 6, 2015 You do know you have to remove that heatshield to bolt the DP on....or is that an optical illusion...? Are you using anti-seize compound on the threads ? Yeah, I put it on they're like that so that I wouldn't lose hardware or Parts since my build has been taking so long. And yes, anti-seize on the exhaust hardware. Especially since I should be getting a downpipe in a few months. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 6, 2015 Author Share Posted August 6, 2015 Better than it was, but not as good as it needs to be. Started falling asleep under the car, had to call it quits for the night. 08/05/2015 Put the power steering pump on. Motor mounts on. Put the torque converter on. Mated the engine and trans. Nee to finish torquing bell housing bolts and then bolt the drive plate to the torque converter. http://images.tapatalk-cdn.com/15/08/06/a15fd3f922ac3032b1e9cb6b6b8bc20b.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
