RooTBeeR Posted August 31, 2015 Author Share Posted August 31, 2015 I don't have a tuner yet. The knock is from the higher CR on a stock tune. I just remembered that that AP allows me to retard the timing up to -5°. So I'll see how much that helps first. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
MTBwrench Posted August 31, 2015 Share Posted August 31, 2015 Keep in mind that's a global timing reduction, so when you get to the end of your break in and you start hooning it around, knock may actually get worse towards redline with full boost because the timing is so low. Orrrrrrr, you can do a little calculation and manipulation to the timing in the OTS stage (whatever stage you are at the moment) map, and adjust WGDC so that you're running on wastegate boost. I'd be too afraid to do it though Sent from my iPhone using Tapatalk MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 31, 2015 Author Share Posted August 31, 2015 I just put the economy tune on it. Once I'm broken in, I'll put on me TGV deletes, injectors, fuel rails, and high flow downpipe. Then tune time. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted August 31, 2015 Share Posted August 31, 2015 What sort of break in should I for for my new valve train?(bottom end has 14k on it already) You con't need a break in for just new valves. Get that car properly Tuned. Knock is not good. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 31, 2015 Author Share Posted August 31, 2015 Valves, heads, cams. Sounds good. After work I'm going to head over to the DMV and get my temporary registration so that I can go get it smogged. And hope it passes so that I can get my actual registration and then go down and see Mike about a tune "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 31, 2015 Author Share Posted August 31, 2015 http://images.tapatalk-cdn.com/15/08/31/c2258180cfbec7041c6214f51fc58e82.jpg Paid my registration, now to go see if it'll pass smog. And when I get home, ordering a downpipe, and talking to Mike about getting tuned. Someone buy my IP&T AVCS filtered oil supply line kit!!! "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 1, 2015 Author Share Posted September 1, 2015 It passed smog with flying colors like nyan cat. Just ordered a down pipe and fuel pump. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Chris GTO TT Posted September 1, 2015 Share Posted September 1, 2015 Did you force it ready with the AP? Otherwise I'm impressed it had enough of the monitors ready with how little driving you've said you've done. Either way congrats! Can't wait to hear about the tune! 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 1, 2015 Author Share Posted September 1, 2015 Got a CEL on my way to work, got scared/saddened. Which is just the cat low efficiency code, and I've no idea why it would suddenly be throwing that. Glad I got it smogged yesterday! Had to use the built in reader since the latest APv3 firmware is messed up and gives me a fatal error when trying to check DTC's. http://images.tapatalk-cdn.com/15/09/01/70f575f3eceee65a0099b91573110e17.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 1, 2015 Author Share Posted September 1, 2015 Did you force it ready with the AP? Otherwise I'm impressed it had enough of the monitors ready with how little driving you've said you've done. Either way congrats! Can't wait to hear about the tune! Nope didn't know you could force them on, or you mean with the tune? Had about 65miles, figured I'd try it. All went well. They always say drive 50-60 miles to get the monitors in ready state. I got lucky haha "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 2, 2015 Author Share Posted September 2, 2015 Downpipe and fuel pump will be delivered today. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
SneakyGT Posted September 2, 2015 Share Posted September 2, 2015 verr nayce Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 2, 2015 Author Share Posted September 2, 2015 Bank account is getting very angry with all the money going out all at once between two cars registration, rent, insurance, credit card bill, and all the car parts. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted September 2, 2015 Share Posted September 2, 2015 I hear ya. I'm building my account back up for future mantainace. Damn these cars. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 2, 2015 Author Share Posted September 2, 2015 Yeah, I'll have a minimum of $10k set aside just for this POS in the future. Haha Gonna take me a good little while to get back up to that thiugh, and then have my regular savings on top of that. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 3, 2015 Author Share Posted September 3, 2015 I found a BIG jug! http://images.tapatalk-cdn.com/15/09/02/099b951b7671904a0e5a4c004599407c.jpg Got my fuel pump. http://images.tapatalk-cdn.com/15/09/02/87d48dc17f9559e7b5750179c9469010.jpg And also my down pipe. "Stage 2" coming this weekend. http://images.tapatalk-cdn.com/15/09/02/dfdf6575d632c1b4ce7192634d830f93.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
MTBwrench Posted September 3, 2015 Share Posted September 3, 2015 Have you done an EBCS yet? MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 3, 2015 Author Share Posted September 3, 2015 Nope. Doubt I'll be running even 20psi, no need for one. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
rebourne Posted September 3, 2015 Share Posted September 3, 2015 How is stage 2 going to help with the high compression knock situation? And curious why Mike for tuning. We have WAY too many options here, it's literally given me decision anxiety. Church, Road Race (His name is also Mike, great guy, did my wife's evoX), Jesus/Jon (HBspeed -> Cobb -> 5150 Racing), Yimi Sport, Mike@Infamous, and of course Cobb. And I'm leaving out 3 or 4... I was hanging out with Shawn (Church) before he became a turner, back in my Honda days... and I also know Jon. But I like what Mike's doing with Delicious and the corn. I have no idea, but the time is coming soon to make a decision. We can take this one to PM if you want... don't need a tuning flame riot. pic thread build thread Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 3, 2015 Author Share Posted September 3, 2015 Stage 2 wont help knock lol... Less back pressure though? I'm going with Mike/William(Bill) Delicious because I want to have a flex fuel tune. Run 91 or corn all willy nilly, no tune switching, no worry about how much of the other fuel is left in the tank when switching back and forth. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 3, 2015 Author Share Posted September 3, 2015 Oh, and I believe that this little turd is the one that replaces the TMIC o-ring... which I will probably have the TMIC off in order to do the downpipe because of the factory heat shields so I figure I might as well change it over. http://images.tapatalk-cdn.com/15/09/02/cb1f83c12dedafef123a0caec1489f46.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Merc6 Posted September 3, 2015 Share Posted September 3, 2015 Oh, and I believe that this little turd is the one that replaces the TMIC o-ring... which I will probably have the TMIC off in order to do the downpipe because of the factory heat shields so I figure I might as well change it over. http://images.tapatalk-cdn.com/15/09/02/cb1f83c12dedafef123a0caec1489f46.jpg This be the one I used on both my 40 and 46. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted September 3, 2015 Share Posted September 3, 2015 Hard to tell, Is that DP need to be trimmed so it clears the waste gate ? You'll need to trim the heatshield too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 3, 2015 Author Share Posted September 3, 2015 Hard to tell, Is that DP need to be trimmed so it clears the waste gate ? You'll need to trim the heatshield too. It should be a direct fit. But I guess I'll find out. I know the heatshield won't fit without modification "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted September 3, 2015 Author Share Posted September 3, 2015 I might put one of my spare bungs on the DP before install and use my old wideband just for peace of mind. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
