kzr750r1 Posted August 22, 2015 Share Posted August 22, 2015 You both better knock on wood. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 22, 2015 Author Share Posted August 22, 2015 You both better knock on wood. Boom! There goes your seal. Haha "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 23, 2015 Author Share Posted August 23, 2015 When I picked up my trans cooler hose at pepboys the other day, I grabbed some of these plastic rivets to replace all of my broken and rotten old ones. http://images.tapatalk-cdn.com/15/08/23/e9aa1c92989dc6e9b36b8abc356e1b89.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 23, 2015 Author Share Posted August 23, 2015 Finished up my trans cooler. http://images.tapatalk-cdn.com/15/08/23/b865f1add788a74224ac80aec3e52e56.jpg http://images.tapatalk-cdn.com/15/08/23/16cefa8efafda8b16ba309c4ed283580.jpg http://images.tapatalk-cdn.com/15/08/23/3f6263fbc2029c4526c146ffea46d500.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 23, 2015 Author Share Posted August 23, 2015 I found the culprit! The banjo bolt in the head for the turbo coolant return line. http://images.tapatalk-cdn.com/15/08/23/5b435fe139ec0406fe00c04ab8b26e85.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted August 23, 2015 Share Posted August 23, 2015 OK, where's the crush washer ? Is that a bent thread I see ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
snm95ls Posted August 23, 2015 Share Posted August 23, 2015 OK, where's the crush washer ? Is that a bent thread I see ? Optical distortion because of the liquid sitting on that part of the bolt. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 23, 2015 Author Share Posted August 23, 2015 OK, where's the crush washer ? Is that a bent thread I see ? Exactly! Some how I forgot the crush washers and didn't even have the bolt snugged down. A 10sec job with the engine out of the car. Took me like an hour. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted August 23, 2015 Share Posted August 23, 2015 I'll admit I had a coolant banjo lose to on my rebuild, but at least I had the crush washers, just had to snug it up. Good Luck. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 23, 2015 Author Share Posted August 23, 2015 Yeah it's done. Full of coolant. Got the headlights back in. Got the grill back in. Got the O2 sensor in. Need to finish up the bumper. Re-Install the TMIC. Need to finish the turbo shields. Then I think pop the battery in and see if she cranks over. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted August 23, 2015 Share Posted August 23, 2015 Remember to turn the key to On a couple times for a few minutes so the ecu has a chance to primp the fuel system. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 24, 2015 Author Share Posted August 24, 2015 I have the fuel pump fuse pulled so I can crank it over without starting to get oil to everything. And then I still have to go get gas because I pretty much was running on fumes when I parked it. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 24, 2015 Share Posted August 24, 2015 Done yet??? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 24, 2015 Author Share Posted August 24, 2015 I made it do a thing. But at high idle it makes a rattle/tap/knock sound I don't like https://youtu.be/4579dCg-EKY "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
alex0856 Posted August 24, 2015 Share Posted August 24, 2015 I heard that in the vid. Fingers crossed for you. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 24, 2015 Share Posted August 24, 2015 What's your piston to wall clearance ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 24, 2015 Author Share Posted August 24, 2015 What's your piston to wall clearance ? It's and OEM assembled 257. I didn't do the bottom end at all. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted August 24, 2015 Share Posted August 24, 2015 I don't understand where that heavy knocking could be from. If it was a light knock, that would be valve train. But for some reason it does sound likes it up top. See if Underdog or m sprank can listen to it. PM them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted August 24, 2015 Share Posted August 24, 2015 That is definitely a different kind of sound, not sure either what it would be. How was your oil pressure after start up? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
FJuan Posted August 24, 2015 Share Posted August 24, 2015 Hard to hear on the video, is the sound more internal or external, like a loose bracket banging againt the motor? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 24, 2015 Author Share Posted August 24, 2015 I have no gauges. I'm ordering APv3 right now. It's not clear in that vid. I'll get fresh gas and see what's going on, try to get a better vid. It almost sounds like a loose idler pulley or something. Can't hear it reved up, cant hear it at idle. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 24, 2015 Share Posted August 24, 2015 How old is the gas in the tank? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 24, 2015 Author Share Posted August 24, 2015 Really old.(21 month...November of 2013) I didn't plan to fire it with out new gas. Last night I tried to turn it over just to get oil and coolant around in it and make sure it sounded right, but it only clicked. So i put the fuel fuse back in to see if it made a difference.(obviously it didn't) ended up finding the starter wire not plugged in, fixed that, and it fired right up. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 24, 2015 Share Posted August 24, 2015 I'm surprised that it even fire with that old ass gas. That could be knocks that you're experience, since there is very little octain lift in the fuel. Don't start the motor until you flush that tank. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 24, 2015 Author Share Posted August 24, 2015 I'm just going to fill it. There's so little in it I'm surprised it got pressure. It's below the red empty mark. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
