Max Capacity Posted August 17, 2015 Share Posted August 17, 2015 I'm sure you've seem pictures of mine... But most of the nuts and bolts come right off, anti-seize compound is your best friend. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted August 17, 2015 Share Posted August 17, 2015 Ha, the only thing I use anti-seize on are sparkplugs. Everything else gets a dab of blue thread lock. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Turkeylord Posted August 18, 2015 Share Posted August 18, 2015 Pick up one of these puppies for that new inlet and maybe avoid some of that damage in the future... [ame=http://www.amazon.com/gp/product/B0002QTK26]Amazon.com: Breeze CT-9436 Aero-Seal Constant Torque Liner Clamp with Stainless Screw Effective Diameter Range: 1-13/16" - 2-3/4" (46mm - 70mm): Automotive[/ame] I haven't had a chance to install mine on the inlet yet, but I did do the TB hose clamps. Link to comment Share on other sites More sharing options...
FJuan Posted August 18, 2015 Share Posted August 18, 2015 ^^ Bad link. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Turkeylord Posted August 18, 2015 Share Posted August 18, 2015 Son of a meat cigrit, I dickered it. Should be skookum now. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 18, 2015 Share Posted August 18, 2015 Works for me. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted August 19, 2015 Share Posted August 19, 2015 That's because he fixed it. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 19, 2015 Author Share Posted August 19, 2015 Clamp wasn't the issue. The inlet tube felt like a gummy bear... "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 19, 2015 Share Posted August 19, 2015 Yup, that's the best way to describe it. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 19, 2015 Author Share Posted August 19, 2015 Woohoo! Just got the new inlet tube, & I don't have work tomorrow. So I'm going to get a lot of shit done on that car. Got my torque converter service hole plug, and my turbo inlet tube. http://images.tapatalk-cdn.com/15/08/19/0027af2df5d735d503b4a21bc73564a8.jpg And no work tomorrow, so these will all be on there. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 19, 2015 Share Posted August 19, 2015 You better get that thing to fired up tomorrow then. No more excuses. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 20, 2015 Author Share Posted August 20, 2015 Blah blah blah... "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 20, 2015 Share Posted August 20, 2015 Are you done yet? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 20, 2015 Author Share Posted August 20, 2015 Got my panel filter about 1 minute ago. The box is all fucked up, but the filter looks good http://images.tapatalk-cdn.com/15/08/20/afe6e100eea16df82c7f552cc7c97115.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 20, 2015 Author Share Posted August 20, 2015 Are you done yet? Haven't even started! "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 21, 2015 Author Share Posted August 21, 2015 I'm not a fan of stickers, especially these noob stickers. However, I can have it on here but it will be hidden unless you take the intake apart... I really just wanted the extra 10 ricerpower. http://images.tapatalk-cdn.com/15/08/20/57e3d9f6e21dea3cf9bdd005caa36f32.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 21, 2015 Share Posted August 21, 2015 Are you done YET? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 21, 2015 Author Share Posted August 21, 2015 Are you done YET? This weekend. I'm not saying it will start, but it sure as shit will turn over. As long as this freaking thing is going down, I'm in no rush. Long as they get it done correctly. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 21, 2015 Author Share Posted August 21, 2015 Looks like one of the banjo fittings on my turbo doesn't have any washers in it and is leaking coolant. Luckily I started filling the coolant into the turbo reservoir first so I didn't even get much in it before it started leaking. So now I gotta figure out how much stuff I have to take back off to get to that banjo bolt and get washers on it and tighten it back down and hope that was the only issue. I'm not even sure how they aren't any washers in there. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted August 21, 2015 Share Posted August 21, 2015 I don't recall any banjos for the coolant line, it should be all hose clamps. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 21, 2015 Author Share Posted August 21, 2015 I'll have to look better later, I could barely see. Now that I think about it, it was a big fast leak. I probably forgot a hose somewhere. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted August 21, 2015 Author Share Posted August 21, 2015 http://kinugawa.co.nz/wp-content/uploads/2012/09/TD05_sub_VF52style_B2.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
snm95ls Posted August 21, 2015 Share Posted August 21, 2015 I don't recall any banjos for the coolant line, it should be all hose clamps. The coolant lines are bolted to the CHRA with banjo bolts. Link to comment Share on other sites More sharing options...
FJuan Posted August 21, 2015 Share Posted August 21, 2015 There you go, I haven't had the pleasure of disassembling the turbo yet. Still rocking the VF40 with 150k miles, might be a Subaru record. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
snm95ls Posted August 21, 2015 Share Posted August 21, 2015 There you go, I haven't had to pleasure of disassembling the turbo yet. Still rocking the VF40 with 150k miles, might be a Subaru record. I am right there with you on turbo mileage. Link to comment Share on other sites More sharing options...
