Turkeylord Posted May 12, 2016 Share Posted May 12, 2016 Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 12, 2016 Share Posted May 12, 2016 So your saying it's the SB that failed? Sorry to hear man. Link to comment Share on other sites More sharing options...
RooTBeeR Posted May 12, 2016 Author Share Posted May 12, 2016 Um, did the JMP get contaminated in the process? I haven't touched it yet, but when I drain the oil, I'll check my drain plug magnet see if it still looks normal or not. But I'm pretty sure the turbos fine. If not...maybe jmp vf52 time? [emoji38] So your saying it's the SB that failed? Sorry to hear man. Yeah, most likely another cracked piston / ring land "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
rebourne Posted May 13, 2016 Share Posted May 13, 2016 I just read this and it's relevant if you decide to rebuild: http://legacygt.com/forums/showpost.php?p=5398354&postcount=18 TL;DR: "If you suspect you might get the itch to go bigger, ... , then just get the damn forgies in there and be sure and use the tougher 2618 material while you're at it." pic thread build thread Link to comment Share on other sites More sharing options...
Merc6 Posted May 18, 2016 Share Posted May 18, 2016 I just read this and it's relevant if you decide to rebuild: http://legacygt.com/forums/showpost.php?p=5398354&postcount=18 TL;DR: "If you suspect you might get the itch to go bigger, ... , then just get the damn forgies in there and be sure and use the tougher 2618 material while you're at it." So "drop in" is actually drop in? Whenever I talk to Subaru owners outside of this forum, they insist I take the A or B pistons (BBBB in my case) and the sealed crate SB still in the plastic to a machine shop and have the cylinders bored to match the A or B "drop in" pistons. If they are drop in then I'll do just that, drop them in. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 18, 2016 Share Posted May 18, 2016 Once you bore your not in the stock A/B sizes. Depending on the manufacturer you can go up three sizes depending on how much your sleeves need to be hogged out. Link to comment Share on other sites More sharing options...
FJuan Posted May 18, 2016 Share Posted May 18, 2016 +1 My wife's balls are delicious. Link to comment Share on other sites More sharing options...
MTBwrench Posted May 18, 2016 Share Posted May 18, 2016 Assuming the cracked ringland hasn't done any damage... I would just hone the cylinders, do drop in pistons and call it a day. And get a JMP VF52 with that pretty 11 blade compressor Sent from my iPhone using Tapatalk MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
Merc6 Posted May 18, 2016 Share Posted May 18, 2016 Once you bore your not in the stock A/B sizes. Depending on the manufacturer you can go up three sizes depending on how much your sleeves need to be hogged out. OK cool, that's what I was looking to hear. Didn't want to have a untouched SB still in plastic and then start machine shopping it canceling out the new SB completely when I already have a decent but blown SB that got me into this question. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Rhitter Posted May 18, 2016 Share Posted May 18, 2016 OK cool, that's what I was looking to hear. Didn't want to have a untouched SB still in plastic and then start machine shopping it canceling out the new SB completely when I already have a decent but blown SB that got me into this question. A lot of people recommend a new SB and calling it a day, because it's hard to find a machine shop that does a decent job (it seems). If you have a trusted machine shop, might as well rebuild with that block (if you want forged). My OBXT build Link to comment Share on other sites More sharing options...
RooTBeeR Posted May 19, 2016 Author Share Posted May 19, 2016 I have OutFront performance pretty close to me. They do a lot of closed deck blocks. I know they have the big plates of aluminum they bolt up in place of the heads and torque to spec when machining. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Merc6 Posted May 19, 2016 Share Posted May 19, 2016 A lot of people recommend a new SB and calling it a day, because it's hard to find a machine shop that does a decent job (it seems). If you have a trusted machine shop, might as well rebuild with that block (if you want forged). I got a BBBB crate and a ABAB blown. Went crate for simplicity and same shop fears but if I can just drop in B pistons I'll be set for my goal and be safe. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Rhitter Posted May 19, 2016 Share Posted May 19, 2016 I have OutFront performance pretty close to me. They do a lot of closed deck blocks. I know they have the big plates of aluminum they bolt up in place of the heads and torque to spec when machining. Outfront did my block when M Sprank rebuilt my engine. (shipped my car down to him) My OBXT build Link to comment Share on other sites More sharing options...
rebourne Posted May 19, 2016 Share Posted May 19, 2016 Outfront did my block too, via AQ motorsports. AQ ran the numbers with me, and the (il-) logic of tearing down a new SB (to properly hone for the drop ins to have a long life ie 100k+ miles) versus rebuilding mine. Even with mine needing a new crank, rebuilding still came out ahead. pic thread build thread Link to comment Share on other sites More sharing options...
alex0856 Posted May 19, 2016 Share Posted May 19, 2016 Lol you know something is up when we consider 100k miles to be a long life. I'm already at 11k on my SB and I can only think that I've already gone through 10% of its life. Lol Link to comment Share on other sites More sharing options...
kzr750r1 Posted May 19, 2016 Share Posted May 19, 2016 You know $3150 isn't bad for a Outfront shortblock. Link to comment Share on other sites More sharing options...
