Grimmrican Posted November 5, 2012 Share Posted November 5, 2012 My wife's 00 outback alternator has no voltage awesome when u get up first thing in the morning for work and see the battery light is on. Link to comment Share on other sites More sharing options...
Tr00b Posted November 5, 2012 Share Posted November 5, 2012 Thanks for the run down on the main bearing noise, I'll listen for it. I am thinking I am just hearing the exhaust leak. Performance is so far pretty solid. I have on an off CEL's for misfire on and an alarming knock like noise when the engine is very cold. the 10krpm over rev the other day did NOT help, if there is a problem... Link to comment Share on other sites More sharing options...
98sc00byGT Posted November 5, 2012 Share Posted November 5, 2012 I threw an IAC code and sometimes my car shuts off when I come to a stop..replaced the IAC sensor and still does it....any input? Link to comment Share on other sites More sharing options...
Grimmrican Posted November 5, 2012 Share Posted November 5, 2012 I threw an IAC code and sometimes my car shuts off when I come to a stop..replaced the IAC sensor and still does it....any input? Did u reset ur engine error code after u replaced it? If not try taking either battery terminal cable off for about 15-20 min. Put it back on and start the car. This should clear any and all codes ur car has. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted November 5, 2012 Share Posted November 5, 2012 I usually just remove the negative cable & step on the brake pedal about 10-15x slowly between each time, then wait for about 5mins. Link to comment Share on other sites More sharing options...
twisty Posted November 5, 2012 Share Posted November 5, 2012 Did u reset ur engine error code after u replaced it? If not try taking either battery terminal cable off for about 15-20 min. Put it back on and start the car. This should clear any and all codes ur car has. let it idle for a while, let it get up to temp as well. resetting the ecu is easy, but getting a good starting data trail is a good thing. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 5, 2012 Author Share Posted November 5, 2012 You need to drive to get the computers going. It needs to go through at least a few drive cycles for a CE light to pop on. Sometimes it only takes one. Link to comment Share on other sites More sharing options...
98sc00byGT Posted November 5, 2012 Share Posted November 5, 2012 Yeah i have reset it plenty of times. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 5, 2012 Author Share Posted November 5, 2012 I think part of my shifter linkage broke. I haven't had time to look into fixing it at all like I planned and now it's worse. I'm starting to have a hard time getting the shifter around and getting it through the gears. It's worse when I'm stopped... This, my left front axel, my exhaust, my oil leak, and my door latch still need to be replace. I also think that my steering rack is shot. There's a noticable clunk when turning the wheel left to right and right to left. I can also here and feel a weird shift in the rack somewhere when I grab the left wheel and use to some muscle to shift it back and forth. It doesn't do it when I do that with the right wheel though.. Link to comment Share on other sites More sharing options...
Grimmrican Posted November 5, 2012 Share Posted November 5, 2012 Hopped in my 95 leggy ob started shifting hard on some "touge" runs going to work lol and my shift linkage bushing busted and the return springs. So now when I put the car in 1st I can ouch it to the right and looks like its in 5th. Sloppy shifting to the extreme smh Link to comment Share on other sites More sharing options...
twisty Posted November 6, 2012 Share Posted November 6, 2012 You need to drive to get the computers going. It needs to go through at least a few drive cycles for a CE light to pop on. Sometimes it only takes one. Yup, that too Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 6, 2012 Author Share Posted November 6, 2012 That's how mine has been^^ BUT NOW it's SO much worse. It's added to the list of Wednesday's work. I'm not worrying myself about this car until then. I felt like I was going to have a heart attack from stress today.. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 6, 2012 Author Share Posted November 6, 2012 Well... I can't even get into second gear anymore. It shift into the slot but it won't go into gear. I can feel it hitting the gear but it won't go in. ugh... Link to comment Share on other sites More sharing options...
Grimmrican Posted November 6, 2012 Share Posted November 6, 2012 Well... I can't even get into second gear anymore. It shift into the slot but it won't go into gear. I can feel it hitting the gear but it won't go in. ugh... Check ur fluids in the tranny. It can be quite a few things. Ur bushings, clutch, fluids, or even the tranny itself.... What u can do is bypass 2nd gear by redlining 1st and jump into 3rd lol. But y? Good luck man hope u figure it out Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 6, 2012 Author Share Posted November 6, 2012 The problem is most like the linkage.. I do go straight from 1st to 3rd. But sometimes that doesnt work because the shifter refuses to go forward into 3rd. So thenI have to go to 4th... I am going to try and put it on the lift tomorrow and take a look at it when I do all of my work to it. If the problem isnt with the linkage its with the trans Link to comment Share on other sites More sharing options...
Grimmrican Posted November 6, 2012 Share Posted November 6, 2012 Son of a fukin bitch. I was taking a buddy of mine home and my fukin tire blew out DX http://img.tapatalk.com/d/12/11/07/e9evu5un.jpg Link to comment Share on other sites More sharing options...
Stasis Posted November 7, 2012 Share Posted November 7, 2012 That'll buff right out Link to comment Share on other sites More sharing options...
Grimmrican Posted November 7, 2012 Share Posted November 7, 2012 That'll buff right out Lol yea tomoro I'm buying 2 new tires for the back. 205/55/15 Link to comment Share on other sites More sharing options...
subikid90 Posted November 7, 2012 Share Posted November 7, 2012 Lol yea tomoro I'm buying 2 new tires for the back. 205/55/15 just an fyi you cannot mix tire sizes on a subaru. All 4 tires must have the same tread wear and should be the same tread pattern. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Grimmrican Posted November 7, 2012 Share Posted November 7, 2012 just an fyi you cannot mix tire sizes on a subaru. All 4 tires must have the same tread wear and should be the same tread pattern. I'm fully aware I already have 205/55/15 in the front. That's what I always drive in all my cars. But thanx for letting me kno. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 7, 2012 Author Share Posted November 7, 2012 May I ask why? That makes absolutely no sense... Why would you not run stock size? Why that particular tire on all of your cars? Link to comment Share on other sites More sharing options...
subikid90 Posted November 7, 2012 Share Posted November 7, 2012 I'm fully aware I already have 205/55/15 in the front. That's what I always drive in all my cars. But thanx for letting me kno. Are they also new? If they have 1-2k more miles there is a very good chance they could mess with you diff. I see no reason not to run a smaller sidewall tire as long as they have the correct load rating. The shorter sidewall will improve handling. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Grimmrican Posted November 7, 2012 Share Posted November 7, 2012 I don't like how 195/70/15 looked on my car whatsoever. I've had wider tires on other cars. But of then all I like 205/55 it's not super wide or super low. It's just perfect. IMO anyways "/ Link to comment Share on other sites More sharing options...
Grimmrican Posted November 7, 2012 Share Posted November 7, 2012 Are they also new? If they have 1-2k more miles there is a very good chance they could mess with you diff. I see no reason not to run a smaller sidewall tire as long as they have the correct load rating. The shorter sidewall will improve handling. I just got the front 2 tires my last pay check and now getting the next 2 later. And I only drive my car to and from work which is combined 8 miles. So it's def not close to 1-2k lol. So I'll be fine. Its hard to buy everything I need in one shot when I'm the only one in the house who pays all the bills and has to get my son his needs. Link to comment Share on other sites More sharing options...
subikid90 Posted November 7, 2012 Share Posted November 7, 2012 I just got the front 2 tires my last pay check and now getting the next 2 later. And I only drive my car to and from work which is combined 8 miles. So it's def not close to 1-2k lol. So I'll be fine. Its hard to buy everything I need in one shot when I'm the only one in the house who pays all the bills and has to get my son his needs. I hear you, being in college does the same thing to me. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
