integroid Posted November 19, 2010 Share Posted November 19, 2010 A sleeve is well over 3mm thick of iron. We don't have 1mm of iron in our blocks LOL, still fighting it even though everyone has pretty much stated you are wrong including Geoff at Full Race. Every aluminum block I have built has had factory sleeves in it that were iron. I didnt see why the Subaru block would be any different. Link to comment Share on other sites More sharing options...
NSFW Posted November 19, 2010 Share Posted November 19, 2010 http://i193.photobucket.com/albums/z151/Legacy_NSFW/EJ25T-Overview.png Link to comment Share on other sites More sharing options...
LittleBlueGT Posted November 20, 2010 Author Share Posted November 20, 2010 Wiener is wrong because this is my thread. It is not his fault, it is part of the custom here. At any rate it would be nice to get this thread back on track. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
mwiener2 Posted November 20, 2010 Share Posted November 20, 2010 yeah, and i don't see "sleeve" anywhere in the proof everyone is posting. Whether it has it or not, it's not any stronger and you have to sleeve it if you want to run more than mid 20's psi. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Scooby2.5 Posted November 20, 2010 Share Posted November 20, 2010 You lose again weiner, give it up Dictionary: liner noun a lining in an appliance, device, or container, esp. a removable one, in particular • the lining of a garment. • (also cylinder liner) a replaceable metal sleeve placed within the cylinder of an engine, forming a durable surface to withstand wear from the piston http://i193.photobucket.com/albums/z151/Legacy_NSFW/EJ25T-Overview.png Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 20, 2010 Share Posted November 20, 2010 incorrect... most aluminum block engines (subaru included) have cast iron sleeves, which are ribbed externally and then the block is poured around that. something i learned from the cosworth machinists is that many subaru blocks do not have perfectly straight cylinders, so when cosworth builds motors they will sometimes reject brand new subaru blocks because the machinists there demand such precise tolerances sarg - i agree, the most efficient turbo setup possible combined with conservative timing is the way to go.. ive never understood some of the aggressive ignition timing or small turbo philosophies, it just doesnt work nearly as well in the real world A lot of established folks are saying exactly this, to make power with boost, not timing. At least per this thread, hopefully the EFR units will make this more livable in traffic and around town. Geoff I'm dying at your recommendation for folks to go with the 7670 for big street use. It is almost the same compressor map as the S200SX 75-70, which no Subaru has ever used in straight BW form TTBOMK. If people start buying the 7670 all of a sudden, it will only be because of your recommendation, and I would bet money on that. It appears Subi folks jump from singlescroll anything right up to twinscroll 35R or greater, with very very few exceptions of twinscroll <35R. I too see the 7670 as being a street beast. The S200SX 7570 was spectacular on an EVO, can only imagine it on a 2.5L with upgraded bits... Hope to work on this project with your help in the future. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Sarg Posted November 21, 2010 Share Posted November 21, 2010 I am not sure that the 7670 is going to be for "big" street use. I think it is just going to be more of a spool happy little turbo that is 30Rish in size. Personally on the 2.5 block that is the absolute smallest I would go. With a 35R sized Borg we were able to make 12 psi off the line, 28 psi by 4700 in 3rd (6 speed) and 28 psi by 4200 in 4th. That to me is just about right. I guess it is all about what you are trying to accomplish. It's probably not good for autocross, but then again, I don't spend too much time racing around parking lots. Link to comment Share on other sites More sharing options...
praedet Posted November 21, 2010 Share Posted November 21, 2010 Which one of the "bolt-on" turbos would have the same or greater top-end vs. a 20G or 68hta, but much better spool. Also, are all variants offered TS? Which TS piping do you have to use? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted November 21, 2010 Author Share Posted November 21, 2010 Which one of the "bolt-on" turbos would have the same or greater top-end vs. a 20G or 68hta, but much better spool. Also, are all variants offered TS? Which TS piping do you have to use? I would think the 6758 in SS would. It might not reach 20 psi in 3rd at 3100 rpm like a 68hta, but it would likely match the spool of a 68hta in the lower gears, which is what matters. It would also have quicker boost recovery when above the boost threshold point, and react quicker to partial throttle adjustments mid-corner, or while adjusting your 40 mph drift in the snow. For TS (FR should have a full kit minus intake for that soon) the 7064 would likely respond the same as the 6758, but have a bit more top-end. Get the 0.92 a/r T4 TS turbine housing. FWIW someone on NASIOC posted some prices, and they were in the 1700 range. Not sure if that is correct or not, but it seems like the street price will be a lot better then $2500 for the 7064 and 7670. All the above is just MO. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
praedet Posted November 21, 2010 Share Posted November 21, 2010 Would the 6758 come in TS? I would rather keep the same top-end as the 68hta and get even better low-end... I understand the comparison you are making about low gears though... Here is the part I am trying to get from the literature. Lower mass turbine wheels only effect transient response, not boost threshold per say. Blade Aero is what pushes boost threshold down. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 22, 2010 Share Posted November 22, 2010 Can somebody help me out with the Flow vs RPM calcs for these? The SquirrelPM utility gave me the following RPM plots: I haven't done the actual math yet (and am hoping to not need to), but don't know VE on a stock motor anyways... anyone have a better reference set straight away? RPMx1000 2 3 4 5 6 7 choke lbs/min 19 32 39 43 47 49 64 kg/sec 0.14 0.24 0.29 0.33 0.36 0.37 0.48 Note: Multiply lbs/min by 0.00756 to get kg/sec. Just putting these points on an EFR 7670 map, the outcome is downright nasty. Compressor efficiency can be kept above 70% from 3-7k rpm if you're not afraid of boost... and I'm not. Edit: These Calcs are probably a lot better, but aren't much for the turbo spinning out to 7k at really high Pressure Ratio, and don't account for compensations such as intercooler pressure drop. kg/sec lb/min L RPM VE Boost PR 0.08 10.3 2.5 2000 90 10 1.8 0.16 21.7 2.5 3000 90 20 2.5 0.26 34.8 2.5 4000 90 27 3.0 0.33 43.6 2.5 5000 90 27 3.0 0.40 52.3 2.5 6000 90 27 3.0 0.46 61.0 2.5 7000 90 27 3.0 [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
sumfoo1 Posted November 22, 2010 Share Posted November 22, 2010 Climber, when playing with engine parameters I usually go to not2fast turbo calculator with either a dyno of the stock car or sae crank numbers and reverse engineer the VE from that. Then I take those numbers and increase boost etc. Link to comment Share on other sites More sharing options...
Full-Race Geoff Posted November 26, 2010 Share Posted November 26, 2010 A lot of established folks are saying exactly this, to make power with boost, not timing.. It appears Subi folks jump from singlescroll anything right up to twinscroll 35R or greater, with very very few exceptions of twinscroll <35R. I too see the 7670 as being a street beast. The S200SX 7570 was spectacular on an EVO, can only imagine it on a 2.5L with upgraded bits agreed on all points! Would the 6758 come in TS? I would rather keep the same top-end as the 68hta and get even better low-end... For the setup you are proposing, i would tend to lean towards the 7064 Twinscroll, .92 a/r and dual internal gate setup. I expect this would outperform the 6758 in a twinscroll - in all respects. Link to comment Share on other sites More sharing options...
Hops Posted November 27, 2010 Share Posted November 27, 2010 For the setup you are proposing, i would tend to lean towards the 7064 Twinscroll, .92 a/r and dual internal gate setup. I expect this would outperform the 6758 in a twinscroll - in all respects. That's exactly what I want! I emailed you earlier... Need a manifold and V-band downpipe. Buy my cars! Link to comment Share on other sites More sharing options...
sumfoo1 Posted November 27, 2010 Share Posted November 27, 2010 What do you guys recommend for a intake/turbo inlet pipe? Link to comment Share on other sites More sharing options...
Hops Posted November 27, 2010 Share Posted November 27, 2010 Gotta go rotated. Buy my cars! Link to comment Share on other sites More sharing options...
Hops Posted November 30, 2010 Share Posted November 30, 2010 Just ordered my Full-Race manifold. They're running a Black Friday special all week! Buy my cars! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted December 1, 2010 Author Share Posted December 1, 2010 Just ordered my Full-Race manifold. They're running a Black Friday special all week! How much, just the manifold, or UP to? Details. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Hops Posted December 1, 2010 Share Posted December 1, 2010 Whole thing. Uppipe and manifold. 1700 shipped. Buy my cars! Link to comment Share on other sites More sharing options...
Hops Posted December 1, 2010 Share Posted December 1, 2010 And I ordered the ChrisTurbo shirt. Buy my cars! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted December 1, 2010 Author Share Posted December 1, 2010 Whole thing. Uppipe and manifold. 1700 shipped. 1.5 scroll? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Hops Posted December 1, 2010 Share Posted December 1, 2010 Twinscroll! Buy my cars! Link to comment Share on other sites More sharing options...
rockle3 Posted December 1, 2010 Share Posted December 1, 2010 what the deuce! that is the best deal I have heard in ages. Link to comment Share on other sites More sharing options...
camber Posted December 2, 2010 Share Posted December 2, 2010 what the deuce! that is the best deal I have heard in ages. I know.... The price listed of the FR manifolds were making me hesitant but $1700 is more doable. Still need DP. Link to comment Share on other sites More sharing options...
NSFW Posted December 2, 2010 Share Posted December 2, 2010 Twinscroll! And what turbo will you be perching atop your new tubes? Link to comment Share on other sites More sharing options...
