Sarg Posted November 17, 2010 Share Posted November 17, 2010 i'm waiting to sleeve my block.... 24psi max is annoying We have run more than 24 psi on a variety of blocks without sleeves. Don't expect to run 25 degrees of timing while doing it, but I would not say there is some artificial 24 psi limit on stock sleeves. Link to comment Share on other sites More sharing options...
integroid Posted November 17, 2010 Share Posted November 17, 2010 i'm waiting to sleeve my block.... 24psi max is annoying I did a few passes at 30 psi on Q16 with the stock sleeves. On my 93 octane tune I only ran 22-23 psi. Link to comment Share on other sites More sharing options...
mwiener2 Posted November 17, 2010 Share Posted November 17, 2010 In stock form, there are no sleeves. at this altitude, 24psi is the magic number. I only daily it at 21psi during the tune we spiked 28psi a few times and made 500ftlbs at 4200rpm My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
camber Posted November 17, 2010 Share Posted November 17, 2010 The two smaller ones are the ones to be used for stock location. The things is "stock location" should be qualified: Stock inlet location, they are working on an UP and DP that will work, but stock turbo inlet should work fine, and stock STI style TMIC or many FMIC will work. The 6258 should see 15 psi by about 2500 rpm or so is the hopes, with near NA quality response. Geoff seems to think the 7670 will be the real Subaru Ticket for 2.5 liters (in TS 0.92 a/r IWG guise): I've always wanted to do TS but the FR kits can be pretty pricey. Hopefully, they have an awesome GB:lol: No doubt they look high quality and have great guarantees. Although, I'd be happy with a single scroll 350 WHP pump gas turbo that has a similar response similar to a VF40 and I think the stock location EFR Subaru turbos will have a similar boost threshold? Is anyone running a rotated intake manifold on a LGT? Link to comment Share on other sites More sharing options...
integroid Posted November 17, 2010 Share Posted November 17, 2010 In stock form, there are no sleeves. at this altitude, 24psi is the magic number. I only daily it at 21psi during the tune we spiked 28psi a few times and made 500ftlbs at 4200rpm Not trying to be an ass but what do you call the cylinder walls in a stock block? I would think those would be called sleeves since they are not aluminum like the rest of the block. Link to comment Share on other sites More sharing options...
urfsin Posted November 17, 2010 Share Posted November 17, 2010 ^^ I am not 100%, but I thought the cylinder wall was was the same material as the rest of the block (aluminum). If I am wrong, please point to some proof. I have seen open / cracked Subaru blocks before and the material of the "sleeve" seemed to be the same as the rest of the block. Slide It Sideways Link to comment Share on other sites More sharing options...
mwiener2 Posted November 17, 2010 Share Posted November 17, 2010 100% aluminium block in stock form I have a rotated manifold My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
06wrxlbart Posted November 17, 2010 Share Posted November 17, 2010 I like the idea of a 3'' Vband downpipe stock location!!!!! I hate taking off all 5 nuts from the stock downpipe! Link to comment Share on other sites More sharing options...
sumfoo1 Posted November 17, 2010 Share Posted November 17, 2010 I wish all the compressors were available with t4 flanged twinscroll turbines. Think... 1 kit rapid change turbos!! Do I want bottom end or top end today??? Hmm. Go to the track swap out the 40lb turbo for the 70lb turbo and switch back to drive home... Link to comment Share on other sites More sharing options...
Sarg Posted November 18, 2010 Share Posted November 18, 2010 ^^ I am not 100%, but I thought the cylinder wall was was the same material as the rest of the block (aluminum). If I am wrong, please point to some proof. I have seen open / cracked Subaru blocks before and the material of the "sleeve" seemed to be the same as the rest of the block. There is a sleeve in there in stock form. I forget who it was that made them, but there are sleeves. I have seen them and seen them with cracks. They are most definitely not the same as the rest of the block. They may be a bit thin, but they are sleeves none the less. Link to comment Share on other sites More sharing options...
mattg Posted November 18, 2010 Share Posted November 18, 2010 Aren't the cylinder walls just a cast part of the aluminum block? That's what it looks like. http://www.innovativetuningdl.com/images/Products/EngineBuilds/Subaru/STiBlockStg2PlusNew1.jpg Link to comment Share on other sites More sharing options...
mwiener2 Posted November 18, 2010 Share Posted November 18, 2010 stock block does not have sleeves. The case halves are cast and machined from a single pour. very few engines are sleeved from the factory My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Sarg Posted November 18, 2010 Share Posted November 18, 2010 I am sorry, but you guys are wrong. The factory block does in fact have sleeves. We have seen where the factory sleeve has cracked and peeled away from the block. It is my understanding (and I could be in correct on the process) that the factory block is poured and cast around the sleeves which have ribs built into them to help hold them in place. They are some what thin and may not be visible in the above picture, but they are there. Link to comment Share on other sites More sharing options...
integroid Posted November 18, 2010 Share Posted November 18, 2010 stock block does not have sleeves. The case halves are cast and machined from a single pour. very few engines are sleeved from the factory You are absolutely wrong. I cracked the cylinder wall only in one of my motors. The actual aluminum reinforcement didnt crack, just the cylinder wall. Like Sarg said, you could see it peeled away from the reinforcement. If this was not the case, why can you only bore the 2.5L blocks to 100MM? One last thing, if it was aluminum, the cylinder walls would not rust after being left out for a few weeks. I have seen plenty blocks with rusty cylinder walls. Link to comment Share on other sites More sharing options...
mwiener2 Posted November 18, 2010 Share Posted November 18, 2010 they rust because it's an aluminum alloy, not pure aluminum you can't bore it past 100 because then the walls get too thin My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
integroid Posted November 18, 2010 Share Posted November 18, 2010 they rust because it's an aluminum alloy, not pure aluminum If that was the case, then the entire block would rust and not just the cylinder walls. you can't bore it past 100 because then the walls get too thin You are saying the block is one big cast piece. have you seen a 100MM bored block? There is still plenty of material on the outside if it was one big piece. The walls of the cylinder sleeves get to thin and that is why you can't bore it past 100MM. I wish I could find the picture of my cracked sleeve. You can tell it is a sleeve and not just one big cast piece. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 18, 2010 Mega Users Share Posted November 18, 2010 cars101 and the vacation pix both say iron sleeves on aluminum block. Link to comment Share on other sites More sharing options...
06wrxlbart Posted November 18, 2010 Share Posted November 18, 2010 Alright Back on topic starting now ? lol. Link to comment Share on other sites More sharing options...
NSFW Posted November 18, 2010 Share Posted November 18, 2010 cars101 and the vacation pix both say iron sleeves on aluminum block. Vacation pix is pretty persuasive. Also see the first post here: http://www.wrxtuners.com/forums/f56/i-cracked-cylindar-sleeve-14048/#post113570 Link to comment Share on other sites More sharing options...
Beanboy Posted November 18, 2010 Share Posted November 18, 2010 New GT500 and I believe GTR aren't using sleeves, but they are some of the first modern performance engines to do away with sleeves. I think they may even be the first. At any rate, the fact that Ford did it was still news worthy a year ago, and 99% of any other cars still use sleeves, including Subaru. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted November 18, 2010 Mega Users Share Posted November 18, 2010 from manual: The cylinder block is made of aluminum die casting. A semi-closed deck structure is used to obtain a higher rigidity to hold the cylinder liners. The cylinder liners are made of cast iron. As they are of a dry type, their outer surfaces are entirely in contact with the cylinder block. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 18, 2010 Share Posted November 18, 2010 Phil @ Elenent ran a stock EJ257 long block for a full race season, 500whp at 30psi, big snail, "just to prove a point." I asked him what timing he was running. I think he said <17* at redline... [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Sarg Posted November 18, 2010 Share Posted November 18, 2010 There is something to be said about low timing high boost. The "JDM style" of tuning with high timing and lower boost can be harsh on the motor. Link to comment Share on other sites More sharing options...
Full-Race Geoff Posted November 19, 2010 Share Posted November 19, 2010 stock block does not have sleeves. The case halves are cast and machined from a single pour. very few engines are sleeved from the factory incorrect... most aluminum block engines (subaru included) have cast iron sleeves, which are ribbed externally and then the block is poured around that. something i learned from the cosworth machinists is that many subaru blocks do not have perfectly straight cylinders, so when cosworth builds motors they will sometimes reject brand new subaru blocks because the machinists there demand such precise tolerances sarg - i agree, the most efficient turbo setup possible combined with conservative timing is the way to go.. ive never understood some of the aggressive ignition timing or small turbo philosophies, it just doesnt work nearly as well in the real world Link to comment Share on other sites More sharing options...
mwiener2 Posted November 19, 2010 Share Posted November 19, 2010 A sleeve is well over 3mm thick of iron. We don't have 1mm of iron in our blocks My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
