Chappy Posted August 30, 2005 Share Posted August 30, 2005 Are any of you needing an alignment after this install? Link to comment Share on other sites More sharing options...
PGT Posted August 30, 2005 Share Posted August 30, 2005 Are any of you needing an alignment after this install? shouldn't be an issue. You don't need to unbolt anything that needs adjusting in the rear. Plus, only the toe can be adjusted in the rear, not camber. Link to comment Share on other sites More sharing options...
JuxtaGT Posted August 31, 2005 Share Posted August 31, 2005 Awesome, thanks for the write-up! I installed mine today. Only note after re-reading this thread is that if you are not replacing the endlinks you do not need to un-bolt them completely, just the top bolt. This might be obvious to anyone attemping such a mod though. Hmm, 6 bolts in total, and an hour of work including set-up / clean-up / clean the dirt and gease off myself. If you are reading this, why haven't you ordered yours yet? That's right, off to AVO you go. The JDM bar feels much lighter then stock, is it hollow or something? Link to comment Share on other sites More sharing options...
SBT Posted August 31, 2005 Author Share Posted August 31, 2005 The JDM bar feels much lighter then stock, is it hollow or something? Yes, it is hollow. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
BigT Posted November 13, 2005 Share Posted November 13, 2005 hey guys, Perrin has the option for 22mm front and rear. Do you guys think that that is a good set up? What about just the 22mm rear? Looking for answers. -T Link to comment Share on other sites More sharing options...
PGT Posted November 13, 2005 Share Posted November 13, 2005 Cusco is probably the better buy, if you are looking for aftermarket. I had Perrin bars, but ended up back with a JDM 20mm after issues with Perrin. Search...the issues are well documented. The Perrin bars were recently redesigned. Link to comment Share on other sites More sharing options...
Unilat Posted November 13, 2005 Share Posted November 13, 2005 hey guys, Perrin has the option for 22mm front and rear. Do you guys think that that is a good set up? What about just the 22mm rear? Looking for answers. -T If you can't find anything in a search, you might want to start a new thread for this kind of question - most folks hitting this one will be looking to find or supply info on the JDM sway. Link to comment Share on other sites More sharing options...
BigT Posted November 18, 2005 Share Posted November 18, 2005 how long did it take for you to get your JDM bar from AVO? Link to comment Share on other sites More sharing options...
PGT Posted November 18, 2005 Share Posted November 18, 2005 a week or so. It depends on whether the local Subaru dealer has it in stock. Link to comment Share on other sites More sharing options...
BigT Posted November 18, 2005 Share Posted November 18, 2005 Thanks, did you receive a confirmation e-mail? Link to comment Share on other sites More sharing options...
PGT Posted November 18, 2005 Share Posted November 18, 2005 yes, once it shipped. You can also check status by going to their website. The email from Ross corresponds from notes in 'order status' Link to comment Share on other sites More sharing options...
BigT Posted November 20, 2005 Share Posted November 20, 2005 no worries, got it today. Can't wait to put it on. And get my car back. Stupid NYC cabs drive like a-holes!!! Link to comment Share on other sites More sharing options...
graff48 Posted March 28, 2006 Share Posted March 28, 2006 Great instructions. I installed my Cusco RSB over the weekend and am loving it! Link to comment Share on other sites More sharing options...
OhBe1 Posted March 29, 2006 Share Posted March 29, 2006 Do the endlinks make much difference? 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
psucaptainkickass Posted April 9, 2006 Share Posted April 9, 2006 So yeah, put the bar in today..took me oh..5 hours. It was cool though, I was going slow, and getting frustrated with oh let's see the exhaust hangers, and getting the bar out. Then when putting the new one in, I got it in there backwards, so had to do it over. But it was fun, I took it for a little joyride, couldn't feel that much of a difference, but I am sure it will help when I am going a little faster around turns. It was dark by the time I could try it out, so I didn't want to risk going off a cliff or anything. By far the hardest part was getting the bar out. Like...at first I thought you could get it out over the mufflers....buzz...wrong. I had to finagle it out through the wheel well. Also, that JDM bar is HELLA lighter than the USDM one. Must be like 5 pounds or something. I was getting tired holding the USDM bar up while trying to get it out, not so with the JDM one. Anyways, its on now....I have the AVO endlinks, but I didn't put them on yet. I am going to wait until the iONs go on. Link to comment Share on other sites More sharing options...
OhBe1 Posted May 23, 2006 Share Posted May 23, 2006 OK, I just realized the JDM is hollow. So the question is, is it really stiffer than the 16mm LGT bar I put in (replacing 15mm stock)? How much? 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
SBT Posted May 23, 2006 Author Share Posted May 23, 2006 It's definitely stiffer and tightened up the whole car, reducing lean and keeping the car square and true on the twisty turnys. Take a look at the swift sways/springs group buy, there's some information in that thread about swaybar comparisons including % stiffness vs each other. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
OhBe1 Posted May 23, 2006 Share Posted May 23, 2006 Thanks - Interesting.. Time to get out the calipers & calculator again... 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
OhBe1 Posted May 29, 2006 Share Posted May 29, 2006 The swift GB thread lists a 19.1 mm JDM hollow bar with a stifness of 8.8 - is that what the 20mm really is? Or is it really approx, given we don't know the wall thickness, (20/19.1)^4 * 8.8 = 10.6? Anyway, using their numbers of a 20mm solid bar having a stiffness of 15.8, the USDM 15 mm is (15/20)^4 * 15.8 = 5.0; USDM LGT = (16/20)^4 *15.8 = 6.5 ... 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
apexjapan Posted May 30, 2006 Share Posted May 30, 2006 There is more than one JDM bar, with the b and c revision Legacies getting a 19mm rear bar, and the Spec B even got down to a 18mm bar. The 20mm OEM JDM bar is from the A revision (first year) Legacy GT. Cheers, Paul Hansen http://www.avoturboworld.com | http://www.sevenphotos.com Link to comment Share on other sites More sharing options...
2006Specb122 Posted June 1, 2006 Share Posted June 1, 2006 There is more than one JDM bar, with the b and c revision Legacies getting a 19mm rear bar, and the Spec B even got down to a 18mm bar. The 20mm OEM JDM bar is from the A revision (first year) Legacy GT. Cheers, Paul Hansen www.avoturboworld.com | www.sevenphotos.com Interesting... sooooo what are the recomendations as to which bar to get? Is the 20mm JDM still the most popular upgrade???? Which bar will give me best performance over stock USDM Spec B. thanks Link to comment Share on other sites More sharing options...
psucaptainkickass Posted June 1, 2006 Share Posted June 1, 2006 20mm Jdm Ftw ....if you are talking only about OEM parts. Link to comment Share on other sites More sharing options...
Ken S Posted June 1, 2006 Share Posted June 1, 2006 There is more than one JDM bar, with the b and c revision Legacies getting a 19mm rear bar, and the Spec B even got down to a 18mm bar. The 20mm OEM JDM bar is from the A revision (first year) Legacy GT. Cheers, Paul Hansen http://www.avoturboworld.com | http://www.sevenphotos.com Any idea why SOJ is going to smaller rear sway bars? Ken Link to comment Share on other sites More sharing options...
2006Specb122 Posted June 1, 2006 Share Posted June 1, 2006 yeah..interesting... One of the things I liked abou the JDM is that it is lighter... I like reducing weight... although I already have reduced weight in rear, alum. rear arms, no engine in trunk etc. I've heard that if I reduce weight in the rear it will give me poor grip especially in snowy conditions.... I'm guessing changing out the sway bar isn't going to kill me...as far as wegiht reduction. Probably only a couple of pounds difference. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted June 1, 2006 Share Posted June 1, 2006 Any idea why SOJ is going to smaller rear sway bars? Ken On the JDM spec-B they had different revisions because people thought the original was too stiff, but just right for us performance minded folks. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
