N.sane Posted August 12, 2011 Share Posted August 12, 2011 LGT: 21mm front, 16mm rear 2.5i & Outback: 20mm front, 15mm rear Link to comment Share on other sites More sharing options...
SBT Posted August 13, 2011 Author Share Posted August 13, 2011 Thank you for the updated info... providing from fading memory isn't always the most reliable - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
N.sane Posted August 13, 2011 Share Posted August 13, 2011 You're welcome! And thank you for this write-up Link to comment Share on other sites More sharing options...
TheEvilTwin69 Posted September 29, 2011 Share Posted September 29, 2011 Even easier, disconnect the exhaust cans with 4 bolts and slip the bars in and out through there. Definately take the tires off though, way easier to get to the endlinks. I did my car one side at a time since I only had one working jack at the time. you got under your car with a jack?are you crazy or stupid? Link to comment Share on other sites More sharing options...
lgkahn Posted May 21, 2012 Share Posted May 21, 2012 put new rallitek end links in today... have one good stock endlink and one with the cut bolt.. if anyone damages one and needs a replacment Link to comment Share on other sites More sharing options...
tmb1956 Posted June 16, 2012 Share Posted June 16, 2012 Installed a rear whiteline sway on my 2008 specB today. Thanks for the write up, still helpful years later. Parked on ramps, left the mufflers on their hangers but disconnected one of the mufflers from the exhaust to sneak the sway out the passenger side.  Set the sway on the softest setting and went for a drive. Results are immediately noticeable and well worth the effort. The car corners much better than stock, and is a blast to drive through the roundabouts where I live. Link to comment Share on other sites More sharing options...
dr_sharp Posted August 29, 2012 Share Posted August 29, 2012 bumping this - gonna be useful this evening. Thanks for the write up. Its crazy to think this was written 7 years ago lol. lol Link to comment Share on other sites More sharing options...
SBT Posted August 30, 2012 Author Share Posted August 30, 2012 Still valid today... especially at the 4th gens get more and more into the secondary market. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
maineSubi Posted May 11, 2015 Share Posted May 11, 2015 Bump for use next week. Throwing a hotchkiss adjustable on with kartboy end links. Link to comment Share on other sites More sharing options...
whitrzac Posted May 11, 2015 Share Posted May 11, 2015 If only a 25mm rear sway bar was still available... Link to comment Share on other sites More sharing options...
henhead Posted May 31, 2016 Share Posted May 31, 2016 Used this to install the JDM bar I picked up. Thanks again! Best bang for the buck mod yet. Link to comment Share on other sites More sharing options...
housemusic1 Posted June 1, 2016 Share Posted June 1, 2016 Used this to install the JDM bar I picked up. Thanks again! Best bang for the buck mod yet. Do you by chance have the part# for the JDM bar? Link to comment Share on other sites More sharing options...
SBT Posted June 1, 2016 Author Share Posted June 1, 2016 These were special-ordered (in a large group buy) late in 2004, early 2005. They were shipped to two members here in the U.S. and then further distributed to other members in the GB. They are actual Subaru OEM 20mm bars that were installed on the Japanese (JDM) 4th Gen Subaru Legacys. They were never available in the USDM. To the best of my knowledge, these are no longer available, unless you can find one here, or through another outlet like JDMParts.com. If you want a similar hollow 20mm bar, you might find them through Whiteline, Perrin, or another distributor. Check with Mike @ AZP or Mike @ Infamous Performance to see what they can find for you. Good luck. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
housemusic1 Posted June 1, 2016 Share Posted June 1, 2016 I think I may have found it, but was just looking for somebody to confirm. Anyway, here the part # I came up with: Â http://jp-carparts.com/subaru/part_detail.php?maker=subaru&car_baseid=F18000&type=B13&cartype=102&fig_id=201&part_id=20451%20%20&part_code=20451AG090Â Partsouq.com has them for $67 + shipping. All said and done, less than $100 for a 20mm rear sway bar. Not too bad, considering that a Whiteline 20mm runs about $180-$200 + shipping. If this turns out to be the correct part, it could be an inexpensive upgrade over my stock 15mm rear sway. Link to comment Share on other sites More sharing options...
fotofan Posted June 1, 2016 Share Posted June 1, 2016 I wrote down a part number for this sway bar from somewhere, 20451AG001. Not sure what the diff is. I put something here like all the cool people, except there's nothing cool to put here. Link to comment Share on other sites More sharing options...
housemusic1 Posted June 1, 2016 Share Posted June 1, 2016 From what I've been able to find, the AG090, and AG001 are the same bar, just used in different months of production. Link to comment Share on other sites More sharing options...
bobbydd21 Posted July 17, 2016 Share Posted July 17, 2016 So I'm planning to buy either the 19mm or 20mm RSB for my 2016 Legacy. I've been reading a ton of threads and there does not seem to be a consensus to which one is more preferable. I live in the Northeast so roads can get bumpy at times, which is why I'm nervous about going up to the 20mm. Will I still notice a difference with the 19mm? Any opinions and/or advice? Link to comment Share on other sites More sharing options...
