zmarko Posted January 23, 2009 Share Posted January 23, 2009 No idea. Too small to tell. Link to comment Share on other sites More sharing options...
firepyro515 Posted January 23, 2009 Share Posted January 23, 2009 This is the same problem that i ran into. I bought a couple different model flip keys, this is because i found one that already had a pre cut blank. I used a small hammer and a T-6 size torx head. Since i don't really have a sized punch set, i went through different hex keys to find approx size, then went with the torx because it has a flatter surface on the top. It will require some force, get the pin almost halfway and then you can take some pliers to it. Have you tried it from both sides? Link to comment Share on other sites More sharing options...
zmarko Posted January 23, 2009 Share Posted January 23, 2009 This is the same problem that i ran into. I bought a couple different model flip keys, this is because i found one that already had a pre cut blank. I used a small hammer and a T-6 size torx head. Since i don't really have a sized punch set, i went through different hex keys to find approx size, then went with the torx because it has a flatter surface on the top. It will require some force, get the pin almost halfway and then you can take some pliers to it. Have you tried it from both sides? Yeah, tried it from both sides. Lemme go rummage through our engineers tool box and see what I can come up with. So, I'll assume from what you're saying it's just a slide and not a screw-in type. Link to comment Share on other sites More sharing options...
firepyro515 Posted January 23, 2009 Share Posted January 23, 2009 yep, its just pinned in there. took me a couple days to find somthing that was the right size. I did have one that was screwed in as well, but it seems like the honda ones are pinned Link to comment Share on other sites More sharing options...
zmarko Posted January 23, 2009 Share Posted January 23, 2009 F**ker is finally out. Now I just gotta cut the key I had made to fit, and I should be good to go. Link to comment Share on other sites More sharing options...
phildog33 Posted January 23, 2009 Share Posted January 23, 2009 Doc, is there anyway to get a FOB with remote-starter in there my car is working great with the factory remote-starter and fob, but id like a flip style p Link to comment Share on other sites More sharing options...
firepyro515 Posted January 23, 2009 Share Posted January 23, 2009 post a couple of pictures of your fob and keys Link to comment Share on other sites More sharing options...
JAvery529 Posted January 23, 2009 Share Posted January 23, 2009 How the heck do you go about getting your key blade onto the flip part of the new key? Link to comment Share on other sites More sharing options...
zmarko Posted January 24, 2009 Share Posted January 24, 2009 How the heck do you go about getting your key blade onto the flip part of the new key? I'm going to have to dremel it to fit into the joint, and then dremel a groove across the key so the pin can hold it in there. But that's a job for tomorrow. Link to comment Share on other sites More sharing options...
firepyro515 Posted January 24, 2009 Share Posted January 24, 2009 Yep dremel ftw, i guess I was lucky when a found a prefitted key blank Link to comment Share on other sites More sharing options...
leggtnut Posted January 24, 2009 Share Posted January 24, 2009 Got the key cut and the imobilizer and fob programmed to the car. The Hundi blank, they weren't able to cut it for some reason. So I had them cut the subaru blank and that it works ok. The fob has to fit inside the ring, so it can be a little hard to turn with the fob turned in one direction. But it WORKS . I am thinking of trying to find a subaru key that doesn't have the plastic on it and having it cut, then cutting it down to fit the flip, so that the fob doesn't have to fit inside the ignition ring. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
DocHolladay23 Posted January 24, 2009 Author Share Posted January 24, 2009 good news, go to wal mart and have them cut a key and use that blank to get a little extra metal on there [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
leggtnut Posted January 24, 2009 Share Posted January 24, 2009 Don't have a walmart near by. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
leggtnut Posted January 24, 2009 Share Posted January 24, 2009 Oh, almost forgot, got all buttons to work, I think w/out problem. I took out the white button back from the Hundi fob and put in the black rubber from the subaru fob and the front buttons work better now. I also used the red rubber from the pannic button to between the pannic button on the fob and the internals. So far my tests have showed it to work better. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
zmarko Posted January 24, 2009 Share Posted January 24, 2009 good news, go to wal mart and have them cut a key and use that blank to get a little extra metal on there Exactly what I did, I went to Lowe's and had a spare cut that I'll take the dremel to. Link to comment Share on other sites More sharing options...
zmarko Posted January 24, 2009 Share Posted January 24, 2009 Well, it's done. Dremeling the key was the biggest pain in the ass as you have to trim down the neck to fit in the part that rotates (the slot is thinner and narrower than a normal key), and getting the angle right (so the key doesn't hit the sides when folded away) wasn't as easy as I thought it'd be. So after all that, and cutting a groove for the pin to go back in in the right spot, while putting it back together, I screw up the spring that actually makes it pop out. Anyone know where I can source a spring like that? Link to comment Share on other sites More sharing options...
firepyro515 Posted January 24, 2009 Share Posted January 24, 2009 I may have a couple lying around. I will check! Link to comment Share on other sites More sharing options...
zmarko Posted January 24, 2009 Share Posted January 24, 2009 I may have a couple lying around. I will check! Sweet. Thanks man. I feel like a doof. Link to comment Share on other sites More sharing options...
DocHolladay23 Posted January 25, 2009 Author Share Posted January 25, 2009 Still waiting on a couple more people to get some keys, I'm going to order them later this week so if anyone else wants one let me know [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
mikeyan Posted January 25, 2009 Share Posted January 25, 2009 Well, it's done. Dremeling the key was the biggest pain in the ass as you have to trim down the neck to fit in the part that rotates (the slot is thinner and narrower than a normal key), and getting the angle right (so the key doesn't hit the sides when folded away) wasn't as easy as I thought it'd be. So after all that, and cutting a groove for the pin to go back in in the right spot, while putting it back together, I screw up the spring that actually makes it pop out. Anyone know where I can source a spring like that? I did mine tonight... dremel with a remote extension... i didn't have too much difficulty making my 08 (yes, i bought an 08 key fob for my 06 back in the day) key fit in the switchblade slot.... Cutting disc to make the sharper marks and outlines, and the drum sander to gradually make it fit snugly... took about 20-30 minutes including the groove. SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
pter Posted January 25, 2009 Share Posted January 25, 2009 Well, it's done. Dremeling the key was the biggest pain in the ass as you have to trim down the neck to fit in the part that rotates (the slot is thinner and narrower than a normal key), and getting the angle right (so the key doesn't hit the sides when folded away) wasn't as easy as I thought it'd be. So after all that, and cutting a groove for the pin to go back in in the right spot, while putting it back together, I screw up the spring that actually makes it pop out. Anyone know where I can source a spring like that? Getting the pin out was the biggest pain! I didn't know the pin was freaking angled. Broke two drill bits And now because my groove is a bit wider, the key wiggles. So now it gets stuck too! But I'm keeping it, it was fun. Link to comment Share on other sites More sharing options...
mikeyan Posted January 25, 2009 Share Posted January 25, 2009 I used a punch tool to knock out the retaining pin, then a finishing hammer to knock it back in. SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
trademark Posted January 26, 2009 Share Posted January 26, 2009 I used a punch tool to knock out the retaining pin, then a finishing hammer to knock it back in. using the right tools >* Link to comment Share on other sites More sharing options...
mikeyan Posted January 26, 2009 Share Posted January 26, 2009 Define right tool, it was a punch from a cheaaaap set of Harbor Freight punches, but it fit the retaining pin perfectly. Mike SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
trademark Posted January 26, 2009 Share Posted January 26, 2009 well using a punch to punch a pin out sounds like the right way to do it to me.. even if it was a cheap punch... Link to comment Share on other sites More sharing options...
