Infamous1 Posted July 7, 2010 Author Share Posted July 7, 2010 when i upgrade my turbo, who do i turn to for a base map so i can go and log, then send said logs to infamous? If e-tuning with me, I provide the base map. Link to comment Share on other sites More sharing options...
james1612 Posted July 14, 2010 Share Posted July 14, 2010 im interested in getting a spt intake for my 2009 4eat, what kind of tuning does my car need? how much will it cost? how long will the SPT intake last before i should replace? thanks for the help james1612 Link to comment Share on other sites More sharing options...
Infamous1 Posted July 15, 2010 Author Share Posted July 15, 2010 http://legacygt.com/forums/showthread.php/opensource-tuning-now-available-103997.html Link to comment Share on other sites More sharing options...
andrew vento Posted August 11, 2010 Share Posted August 11, 2010 i have a 2005 subaru legacy gt, heres the mods, k&n typhoon intake with mafs, x02 cat back 3" dual exhaust, turbo turned up to 14psi, stage 2 clutch, aluminum flywheel, heres my problem the cats are all punched so my o2s go off, when i clear the codes the car spits and sputters and shuts off while driving and dosent idle right etc. also whenever its running fine my rpms between 2-4000 are spuddery u could say. so iam guessing its a tuning problem with the ecu right? if so im gonna have to get it on the dyno then get my buddy to hook his laptop up to it? Link to comment Share on other sites More sharing options...
Cincy05LGT Posted August 11, 2010 Share Posted August 11, 2010 i have a 2005 subaru legacy gt, heres the mods, k&n typhoon intake with mafs, x02 cat back 3" dual exhaust, turbo turned up to 14psi, stage 2 clutch, aluminum flywheel, heres my problem the cats are all punched so my o2s go off, when i clear the codes the car spits and sputters and shuts off while driving and dosent idle right etc. also whenever its running fine my rpms between 2-4000 are spuddery u could say. so iam guessing its a tuning problem with the ecu right? if so im gonna have to get it on the dyno then get my buddy to hook his laptop up to it? Sounds like you have a lot to learn about tuning... Our turbos run 14 psi stock. Do yourself a favor and take the typhoon intake off and replace the factory airbox and snorkel. The factory intake is proven to be effective and non-restrictive to around 400whp. Your ecu is scaled to the stock intake and is probably causing all your problems. Try this and see. And do LOTS of reading before swapping out parts on the fly. That's what we're here for. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted August 11, 2010 Share Posted August 11, 2010 OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Infamous1 Posted August 11, 2010 Author Share Posted August 11, 2010 The factory intake is proven to be effective and non-restrictive to around 400whp. This is definately not true, it will maxed its self out voltage wise in the 310-320whp range. But I agree with everything else for sure. Link to comment Share on other sites More sharing options...
Cincy05LGT Posted August 12, 2010 Share Posted August 12, 2010 Oops... here I go talking up our awesome cars again... Hey Infamous1 what happened to Mickeyd? Haven't seen him around in awhile on here or romraider. I'm halfway through finishing a Stg 1 tune. Link to comment Share on other sites More sharing options...
Infamous1 Posted August 12, 2010 Author Share Posted August 12, 2010 I have no idea, I rarely visit RR and he long ago stop veturing this site often as he once did. Link to comment Share on other sites More sharing options...
Cincy05LGT Posted August 12, 2010 Share Posted August 12, 2010 maybe I should have you aide me in finishing my tune... Link to comment Share on other sites More sharing options...
Infamous1 Posted August 12, 2010 Author Share Posted August 12, 2010 There isn't much to stg 1, set your targets and hit them....if its safe and feels good leave it alone. Link to comment Share on other sites More sharing options...
HDTurbo Posted August 15, 2010 Share Posted August 15, 2010 I wouldn't mind having the infamoustuning.com decal for my Legacies... Link to comment Share on other sites More sharing options...
Infamous1 Posted August 15, 2010 Author Share Posted August 15, 2010 I wouldn't mind having the infamoustuning.com decal for my Legacies... Email me your address Link to comment Share on other sites More sharing options...
subaggie Posted September 3, 2010 Share Posted September 3, 2010 Anybody tried out the Jet V-Force Plus Power Control Module. I can tell if it is like a one-size fits all gimmick or if actually has potential for a turbo car. It's not a plug and play and requires wiring, but would be worth it if it can do what they say it can. http://www.jetchip.com/shop/shopdisplayproducts.asp?sppp=10&vall=1 Link to comment Share on other sites More sharing options...
NSFW Posted September 8, 2010 Share Posted September 8, 2010 I don't think it's worth it, even if it really can do what they claim. Hardware-based tuning tools like those are not cost-effective for modern Subarus. Our ECUs have been reverse engineered pretty thoroughly by hobbyists, and they can be retuned with inexpensive hardware and free software. And with that system, you'll be dependent on that one company to make time for you every time you need to retune for a new upgrade (turbo, exhaust, whatever). Whereas with EcuFlash (or Cobb's AccessPort) there are a ton of tuners out there to choose from. Link to comment Share on other sites More sharing options...
MasAyinde Posted September 8, 2010 Share Posted September 8, 2010 Hey guys, this is actually my first post on this forum. I'm relatively new to turbo powertrains/tuning but fairly knowledgeable about most engine related things. My question is about the COBB AP. I know that they offer their own maps (valet, 91 octane, 93 octane, economy) and that their stage 2 is tuned for a TBE only. I'm wondering if any shops have duplicated maps such as these for cars that have a full exhaust, IC, turbo, or anything that the AP does not support. I think that it would boil down to whether the AP can be used to store custom maps (as opposed to only being able to store COBB maps) or if when going the protune route, it is used only as a device to load the maps onto the car. I see one of the benefits of just going COBB stage 2 as having a variety of different maps to choose from, but I thought that one would lose that flexibility if they chose to go with a protune. Does anyone have similar maps that they are able to choose from? Have any tuners loaded corresponding maps onto an AP? I have not bought a Legacy GT yet, but am beginning to shop around. My question stems from a friend who has a 93 octane map on his Audi A4 and had to drive 25 miles, essentially running on fumes, to find 93 octane since he couldn't switch maps on the fly. Link to comment Share on other sites More sharing options...
dudeondacouch Posted September 8, 2010 Share Posted September 8, 2010 the AP can store the protune map and the COBB maps, and you can switch back and forth as far as I know. Also, the V2 has a feature that you can use to retard the timing on your protune map a few degrees across the board in case of bad gas or the inability to find 93. protuners have maps that they start with, but tweak for each car. as far as just getting someone elses protune map, not really possible because tuners lock their maps with PINs so they can't be "stolen" Link to comment Share on other sites More sharing options...
MasAyinde Posted September 8, 2010 Share Posted September 8, 2010 But if someone gets a protune, they can store multiple maps from that tuner on the AP to switch back and forth as they see fit? I figured the COBB maps couldn't be used once more than just the TBE was modified on a car. Link to comment Share on other sites More sharing options...
dudeondacouch Posted September 8, 2010 Share Posted September 8, 2010 yes, you should be able to store multiple protune maps. and no, i wouldn't recommend using the COBB maps after extensive mods, but I doubt it would cause any tragic failure if used in an emergency. Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted October 5, 2010 Share Posted October 5, 2010 Here is what I'm installing: BNR HTA68 AVO IWG actuator 850cc witch hunter injectors walbro fuel pump grimmspeed EBCS IPR TMIC STi uppipe autospeed downpipe magnaflow catback 93 octane OS tune from shamar I need advice on the following (need Shamar's input) Intake - planning a KStech 73mm w/heat shield BOV - GFB 50/50, cobb xle 50/50 or forge full recirc? I like the option of the 50/50, for the sound if wanted . Can the same tune run full recirc or 50/50? turbo inlet - GMS or perrin? Link to comment Share on other sites More sharing options...
Infamous1 Posted October 5, 2010 Author Share Posted October 5, 2010 Don't put too much thought in the BOV, 50/50 or recirc won't affect tuning parameters. As for the inlet, really not needed but Perrin if you choose to do so. Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted October 5, 2010 Share Posted October 5, 2010 ok. which intake? Link to comment Share on other sites More sharing options...
Infamous1 Posted October 5, 2010 Author Share Posted October 5, 2010 I like the K & N best. Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted October 7, 2010 Share Posted October 7, 2010 is the K&N large enough diameter if i switch to E85 in the future? I've heard of other running out of range with this intake and thats why I was leaning toward the KStech. I don't plan on E85 initially because there isn't much available near me, but you never know so I'm just trying to be as well prepared as possible and not have to change parts/tunes a whole bunch Link to comment Share on other sites More sharing options...
Infamous1 Posted October 7, 2010 Author Share Posted October 7, 2010 The K & N will be fine on the hta in 20+ degree weather even on E85. Link to comment Share on other sites More sharing options...
