itsme Posted February 21, 2008 Share Posted February 21, 2008 The IAM won't show up unless it's connected to the car. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Infamous1 Posted February 21, 2008 Author Share Posted February 21, 2008 Anyone ever encounter their AFR number's being off after they changed the AFR target? For instance my AFR targets for CA91oct are 11.0, my current scaling will be spot on with 91oct or even 100oct. But on my race gas map that calls for 12.0 the AFR for the most part never gets higher than 11.7-8ish. This is all in the same voltage range as well. Any theories??? Link to comment Share on other sites More sharing options...
Infamous1 Posted March 17, 2008 Author Share Posted March 17, 2008 Anyone care to share how tip-in works with our ECU's? What do the raw values represent? Link to comment Share on other sites More sharing options...
socomcaptain05 Posted March 17, 2008 Share Posted March 17, 2008 hey guys. New here, and I will be purchasing an 05 LGT in July. I know I really need to research, which I plan on, but ONE quick question. I just bought a vf39 turbo and sti tmic for my wrx. I just learned that the vf39 works good for the lgt also. So here is my question...how difficult/expensive would it be to install the vf39 on the 05 LGT? will it just bolt right up? What supporting mods do I need? I'm brand new to LGT's but cant wait to get one. Link to comment Share on other sites More sharing options...
spacejunkiehsv Posted March 17, 2008 Share Posted March 17, 2008 hey guys. New here, and I will be purchasing an 05 LGT in July. I know I really need to research, which I plan on, but ONE quick question. I just bought a vf39 turbo and sti tmic for my wrx. I just learned that the vf39 works good for the lgt also. So here is my question...how difficult/expensive would it be to install the vf39 on the 05 LGT? will it just bolt right up? What supporting mods do I need? I'm brand new to LGT's but cant wait to get one. You need to do a search for "sti swap". There is a list of parts you need in order to do the swap. I believe the biggest piece is the intake manifold. There is a girl on here that has done the sti swap that has an 08 sti on order. I'm pretty sure she is removing and selling her sti swap parts after her new sti is delivered. Her username is AKLGT. Link to comment Share on other sites More sharing options...
socomcaptain05 Posted March 17, 2008 Share Posted March 17, 2008 ^^ thanks. That def. helps. Link to comment Share on other sites More sharing options...
Infamous1 Posted May 20, 2008 Author Share Posted May 20, 2008 Bump for the noob tuners... Link to comment Share on other sites More sharing options...
z28dreams Posted May 20, 2008 Share Posted May 20, 2008 Hey all... Looking to get started learning about tuning, but unfortunately most of the boards I'm reading (romraider, osecuroms, etc) don't really have any good beginner guides. Suggestions on places to read / books to buy / things to do? If someone can help walk me through this, I'll put together a "how-to" guide with pictures/video/screen captures blog style so others can do it as well. Link to comment Share on other sites More sharing options...
Legend Posted May 20, 2008 Share Posted May 20, 2008 If your car is an '05 or '06 I'd continue reading forums and consider flashing mickeyd2005's stage 1 basemap. I'd speculate there isn't a better stage 1 map anywhere than that one, commericial or otherwise. Drive around a few miles and log a WOT pull in 3rd gear and post the log here or on the romraider forums. You'll get lots of feedback on logs. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
Infamous1 Posted May 20, 2008 Author Share Posted May 20, 2008 If your car is an '05 or '06 I'd continue reading forums and consider flashing mickeyd2005's stage 1 basemap. I'd speculate there isn't a better stage 1 map anywhere than that one, commericial or otherwise. Drive around a few miles and log a WOT pull in 3rd gear and post the log here or on the romraider forums. You'll get lots of feedback on logs. You won't get any better than that. There really isn't any starters guides to tuning because so many people have different opinions or strategies to acheive the same result. However don't flash anything until you get a better understanding of what things mean when logging. Start off first logging your stock vehicle and reviewing your stock rom. Link to comment Share on other sites More sharing options...
z28dreams Posted May 20, 2008 Share Posted May 20, 2008 You won't get any better than that. There really isn't any starters guides to tuning because so many people have different opinions or strategies to acheive the same result. However don't flash anything until you get a better understanding of what things mean when logging. Start off first logging your stock vehicle and reviewing your stock rom. I actually plan on using mickey's map as a starting point, but because I have the 5EAT he warned me that I really need a transmission cooler. I'd like the boost throttled down a bit under 3500 rpm so I don't ruin the torque converter. Link to comment Share on other sites More sharing options...
2005garnetGT Posted May 20, 2008 Share Posted May 20, 2008 uhh, thats interesting, because I've been running a stage2 setup on my 5EAT without a trans cooler for almost 2 years now no problems Link to comment Share on other sites More sharing options...
BDII Posted June 5, 2008 Share Posted June 5, 2008 I was wondering if one of you non-accessport guys could do a write up for this thread about the non-cobb tuning possibilities? http://legacygt.com/forums/showthread.php?t=67940 It only covers the AP as of right now. If you could do the write up, maybe include a few Pics I can have a mod unlock the thread and you can add it to the end as an additional topic? I think it may help the new members who are generally pointed in that threads direction upon arrival Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
JTaz Posted August 20, 2008 Share Posted August 20, 2008 First of all i am a noob. Sad, i know. In the best interest for my car, i want to keep it as "healthy" as possible. So if i buy an AP what sort of tuning would i need to do so i dont risk causing damage to anything? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted August 20, 2008 Share Posted August 20, 2008 the good kind of tuning. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
qikslvr Posted August 20, 2008 Share Posted August 20, 2008 First of all i am a noob. Sad, i know. In the best interest for my car, i want to keep it as "healthy" as possible. So if i buy an AP what sort of tuning would i need to do so i dont risk causing damage to anything? Start off with the Cobb maps and log them to see how they run on your car and then get their StreetTuner Software and adjust any areas that show problems in the logs. Let's kick this pig! Link to comment Share on other sites More sharing options...
JTaz Posted August 20, 2008 Share Posted August 20, 2008 Cool, thanks. Would it be advisable to start with a catback before i get an AP? And would i have to tune anything just for the CB? Thanks for your patience with the noobs! Link to comment Share on other sites More sharing options...
derffred Posted August 21, 2008 Share Posted August 21, 2008 Quick question, I'm debating if I should swing by Precision Tuning here in NJ for a Dynotune/Street tune.. but their price is 450 to tune with the AccessPort or 400 for Open Source... what would the actual difference be in the tune (why is it cheaper for Open Source Tuning) and would there be difference between the two tunes? Link to comment Share on other sites More sharing options...
Infamous1 Posted August 21, 2008 Author Share Posted August 21, 2008 Quick question, I'm debating if I should swing by Precision Tuning here in NJ for a Dynotune/Street tune.. but their price is 450 to tune with the AccessPort or 400 for Open Source... what would the actual difference be in the tune (why is it cheaper for Open Source Tuning) and would there be difference between the two tunes? No difference at all in the total tune, most shops charge more for OS tunes vs AP's because they take a bit longer due to no realtime tuning. Link to comment Share on other sites More sharing options...
dudeondacouch Posted August 24, 2008 Share Posted August 24, 2008 Link to comment Share on other sites More sharing options...
mksenak07specb Posted August 31, 2008 Share Posted August 31, 2008 Daily driver. Don't know whether to start slow and go stage 1 to stage 2 or jump right in. If stage 2 which exhaust is best with cobb accessport. Looking at reviews all exhausts seem to not fit well. Installed spt high air flow intake and then read cobb testing which suggests it decreases hp. Any recommendations would be appreciated. If it helps, I was really wanting 07 sti buut couldn't find one locally, so this tells you the kind of performance I would like. Link to comment Share on other sites More sharing options...
praedet Posted September 1, 2008 Share Posted September 1, 2008 So, I did something I know I am not supposed to do, but I was lazy. I changed out the AVO Intake for the COBB Intake, and DW 740cc inj. for 811cc modified stockers... Right now I have the Inj scale adjusted for the 811cc injectors and the intake scaling back to stock (what COBB recommends) The car is running rich, so I am guessing I need a higher injector scaling... Thoughts? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 1, 2008 Share Posted September 1, 2008 So, I did something I know I am not supposed to do, but I was lazy. I changed out the AVO Intake for the COBB Intake, and DW 740cc inj. for 811cc modified stockers... Right now I have the Inj scale adjusted for the 811cc injectors and the intake scaling back to stock (what COBB recommends) The car is running rich, so I am guessing I need a higher injector scaling... Thoughts? I have heard of a number of injectors that didn't match their "flow numbers". Who knows. Put injectors that you know you have a good scaling for back in and tune the intake, do it right! This is the foundation of your tune, g/s translates into load, which plays an important part in many tables. Then put the new injectors in and I think you will find sclaing them to be not too difficult. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted September 1, 2008 Share Posted September 1, 2008 The only way I would keep the stock scaling is if I heard feedback from others saying that the COBB intake works extremely well with the stock scaling. FWIW I found that the stock airbox (w/ stock MAf calibration) was off by up to 5%, so just listen to my above post. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
praedet Posted September 1, 2008 Share Posted September 1, 2008 Well, the reason I took off the DWs is that I had been getting misfires on cylinder 1... Anyone got their stockers the want to send me to borrow for a week or so? Link to comment Share on other sites More sharing options...
