Moderators BarManBean Posted January 15, 2016 Author Moderators Share Posted January 15, 2016 Is Tris the "Guest" Currently viewing? He likes to watch... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Max Capacity Posted January 15, 2016 Share Posted January 15, 2016 Don't forget to replace the oil return hose from the turbo. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Underdog Posted January 15, 2016 Share Posted January 15, 2016 So are these the pressure plate / flywheel marks I'm looking for? Yes, you want to reinstall the pressure plate with the paint mark 120 degrees off from the paint mark on the FW. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 15, 2016 Author Moderators Share Posted January 15, 2016 Yes, you want to reinstall the pressure plate with the paint mark 120 degrees off from the paint mark on the FW. Thanks. Clockwise or counterclockwise? Or will it only go on one way really assuming the 120* requirement? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Underdog Posted January 15, 2016 Share Posted January 15, 2016 Sorry, should have said 120 degrees or greater. Direction doesn't matter, so as long as they are 120-240 degrees out of alignment you are good. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 15, 2016 Author Moderators Share Posted January 15, 2016 Sorry, should have said 120 degrees or greater. Direction doesn't matter, so as long as they are 120-240 degrees out of alignment you are good. Got it. Just so the heavy sides are opposed. Will do! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 16, 2016 Author Moderators Share Posted January 16, 2016 I'd be lying if I said this isn't tempting right now: http://legacygt.com/forums/showthread.php/fl-fresh-stage-1-5-ej25-shortblock-248963.html "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
boxkita Posted January 16, 2016 Share Posted January 16, 2016 I'd be lying if I said this isn't tempting right now: http://legacygt.com/forums/showthread.php/fl-fresh-stage-1-5-ej25-shortblock-248963.html My boxkitty stamp of approval for this idea is stuck on a NSFW thread. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 16, 2016 Author Moderators Share Posted January 16, 2016 My boxkitty stamp of approval this idea is stuck on a NSFW thread. WTF? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 16, 2016 Author Moderators Share Posted January 16, 2016 Talked to JMP for a good bit tonight. Should be sending him my 16g for some upgrades here shortly "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Rhitter Posted January 16, 2016 Share Posted January 16, 2016 WTF? He said he would approve this post with his stamp of approval. BUT, his stamp of approval is permanently in a NSFW thread. Talked to JMP for a good bit tonight. Should be sending him my 16g for some upgrades here shortly Nice, what are you having done? How long is it expected to take? My OBXT build Link to comment Share on other sites More sharing options...
boxkita Posted January 16, 2016 Share Posted January 16, 2016 I'd be lying if I said this isn't tempting right now: http://legacygt.com/forums/showthread.php/fl-fresh-stage-1-5-ej25-shortblock-248963.html Nice, what are you having done? How long is it expected to take? I'm guessing RiderDude sold his block and BMB is searching for 500hp Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 16, 2016 Author Moderators Share Posted January 16, 2016 Nice, what are you having done? How long is it expected to take? Pretty much whatever JmP feels like doing, but overall replacing the rotating assembly with an inconel (sp?) custom 11-blade piece and possibly going back to a smaller / stock exhaust housing. Also looking to add an upgraded actuator if I can find one to fit a BNR turbo--not sure what fits at this point. He will replace all other reliability pieces while he's in there because that's really the only way he operates. I'm sure it will be great "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 16, 2016 Author Moderators Share Posted January 16, 2016 Started putting together the battle plan / sequence of events in the second post here: http://legacygt.com/forums/showpost.php?p=5305444&postcount=2 Anything I'm missing? Gonna go through the steps while looking at the motor and figure out what gaskets, crush washers, etc I'll be needed. Definitely a few odds and ends to order and I don't want to be stuck stopping every other step to wait for dealer parts "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 16, 2016 Author Moderators Share Posted January 16, 2016 Might toss one of these in with the new TOB, might not http://www.rallysportdirect.com/shop/product/act-884006p-act-monoloc-collar "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
boxkita Posted January 16, 2016 Share Posted January 16, 2016 I predict post #100 by day's end. With that posting rate, you'll be overmy 1100 posts in a couple of weeks. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 16, 2016 Author Moderators Share Posted January 16, 2016 Anyone happen to have part numbers for crush washers for the passenger side banjo bolt and also for the front bolt for the IP&T oil line kit? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
boxkita Posted January 16, 2016 Share Posted January 16, 2016 standard copper washer. all same size. Any hardware shop will have them. dealer price will make you cry. $60 for 20 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
kzr750r1 Posted January 17, 2016 Share Posted January 17, 2016 I have two separate sizes in the Subaru gasket kit. I'll measure them in a moment. Large id .475 x od .630 Small Id .400 x od .552 .040 Thickness for both I'm probably going to replace the stock capped hard line. Need to call Mike and get the thing ordered. :/ More washers as well, just in case. Hate it when not having a little part like this kills momentum. Link to comment Share on other sites More sharing options...
kzr750r1 Posted January 17, 2016 Share Posted January 17, 2016 Who am I kidding... What they have in this kit isn't even enough. So off to Monument and see what they have in stock. I can't even install the left OCVS hardline. :/ Link to comment Share on other sites More sharing options...
boxkita Posted January 17, 2016 Share Posted January 17, 2016 Anyone happen to have part numbers for crush washers for the passenger side banjo bolt and also for the front bolt for the IP&T oil line kit? standard copper washer. all same size. Any hardware shop will have them. dealer price will make you cry. $60 for 20 I have two separate sizes in the Subaru gasket kit. I'll measure them in a moment. Large id .475 x od .630 Small Id .400 x od .552 .040 Thickness for both I'm probably going to replace the stock capped hard line. Need to call Mike and get the thing ordered. :/ More washers as well, just in case. Hate it when not having a little part like this kills momentum. my notes on this: http://legacygt.com/forums/showpost.php?p=5118720&postcount=734 Actual PN - Gasket, 803912040 - 12mm ID, 1mm thick, 2.25mm wide Screw - Screw-union, 15194AA270 banjo bolt - Union screw and filter assembly, 14445AA090 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 17, 2016 Author Moderators Share Posted January 17, 2016 I'll be putting together an OEM order most likely from Heubergers. Looks like the part number you list John is under $1 each so I'll just order OEM stuff and be done with it, thanks! Kzr just reminded me that I should also order the AVCS replacement line as well to get rid of the capped stock line. Will add it to the list. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 17, 2016 Author Moderators Share Posted January 17, 2016 *might* be adding a new clutch to the rebuild as well. My current one looks pretty damned good, but it does have 15k miles on it. If I'm going whole hog on this refresh I might just do a new clutch. Break in period with new turbo would suck tho Regardless, that will be towards the very end so I have some time to mull it over. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
boxkita Posted January 17, 2016 Share Posted January 17, 2016 At least a year... Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted January 17, 2016 Share Posted January 17, 2016 i predict post #100 by day's end. With that posting rate, you'll be overmy 1100 posts in a couple of weeks. #100 Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
