Moderators BarManBean Posted January 22, 2016 Author Moderators Share Posted January 22, 2016 ^^yes that makes sense. The one I'm dealing with is a cam sensor, found on the top/rear of the cylinder head. I was clarifying because every time I have every mentioned a cam sensor it seems like any replies default to a "crank" sensor. Locations make sense though. For anyone that cares, part number for cam sensor is 22056AA140, part number for crank sensor is 22053AA053. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
tsunami Posted January 22, 2016 Share Posted January 22, 2016 You know you want a blouch 1.5 lol this thread has been fun to read through so far. Link to comment Share on other sites More sharing options...
Rhitter Posted January 22, 2016 Share Posted January 22, 2016 You know you want a blouch 1.5 lol this thread has been fun to read through so far. He is on the stock block. Would probably end up breaking it with a 1.5. Although, mine broke at some point with just the VF46. So, I am with you. 1.5 time BMB. My OBXT build Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 22, 2016 Author Moderators Share Posted January 22, 2016 He is on the stock block. Would probably end up breaking it with a 1.5. Although, mine broke at some point with just the VF46. So, I am with you. 1.5 time BMB. Going with a JmP custom 16G for now. If my car ever needs a new shortblock I would consider something larger. But for now, I think a custom billet 16G from JmP is gonna rip. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
SBT Posted January 22, 2016 Share Posted January 22, 2016 I replaced both cam position sensor, the crank position sensor, the knock sensor and both OCVs. Also did PCV and the rear oil galley adapter for my DEFI oil pressure gauge while the IM was off. Though everything was working fine, everything also had 155K on it so replacing it with new OEM - and expecting at least another 100K out of the replacement parts - made sense. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted January 22, 2016 Share Posted January 22, 2016 Tightening torque for the Cam and Crank Position Sensor is only 4.7 ft-lb. Knock sensor is 17.4 ft-lb and the knock sensor cord must be positioned at a 60* angle relative to the engine rear. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
boxkita Posted January 22, 2016 Share Posted January 22, 2016 Going with a JmP custom 16G for now. If my car ever needs a new shortblock I would consider something larger. But for now, I think a custom billet 16G from JmP is gonna rip. Might as well get a new shortblock now. its another of those "might as well" items everyone skimps on Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 22, 2016 Author Moderators Share Posted January 22, 2016 Snow! http://i934.photobucket.com/albums/ad187/BarManBean/OBXT/AB175435-60CB-4301-8A03-AB3C4AA9245D_zpsuqda2i9w.jpg "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 23, 2016 Author Moderators Share Posted January 23, 2016 Ordered a bunch of OEM gaskets, seals, random parts from Heuberger. Let's get it on. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
LatentWagen Posted January 23, 2016 Share Posted January 23, 2016 Obligatory Kitteh-powered LGT shot? kiddie-powered-LGT.jpg Well met, sir. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
boxkita Posted January 23, 2016 Share Posted January 23, 2016 Ordered a bunch of OEM gaskets, seals, random parts from Heuberger. Let's get it on. list ? Need to compare yours to Sgt.Gator. Between you two and a couple of others, I should have a full list. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 23, 2016 Author Moderators Share Posted January 23, 2016 Well met, sir. I'll throw my corgi in there at some point for you too "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 23, 2016 Author Moderators Share Posted January 23, 2016 list ? Need to compare yours to Sgt.Gator. Between you two and a couple of others, I should have a full list. See post #2 in this thread for what I'm getting so far. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
magnusonsubie Posted January 23, 2016 Share Posted January 23, 2016 I'd put money on this being done before Boxkita has heads back on his engine I think I jinx'd myself. My car has been full of Drama these past 2 weeks! 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
boxkita Posted January 23, 2016 Share Posted January 23, 2016 I think I jinx'd myself. My car has been full of Drama these past 2 weeks! Have you met my friend...karma? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
rmoore5 Posted January 23, 2016 Share Posted January 23, 2016 She is a bitch ! Link to comment Share on other sites More sharing options...
magnusonsubie Posted January 23, 2016 Share Posted January 23, 2016 Have you met my friend...karma? Yeah I believe its in the form of black LGT wagons. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
boxkita Posted January 23, 2016 Share Posted January 23, 2016 bMB is going to wake up to 3 feet of snow and the West Coasters dumping all over his thread... Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Rester5350 Posted January 23, 2016 Share Posted January 23, 2016 He is on the stock block. Would probably end up breaking it with a 1.5. Although, mine broke at some point with just the VF46. So, I am with you. 1.5 time BMB. Going with a JmP custom 16G for now. If my car ever needs a new shortblock I would consider something larger. But for now, I think a custom billet 16G from JmP is gonna rip. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 23, 2016 Author Moderators Share Posted January 23, 2016 The car was here this morning... http://i934.photobucket.com/albums/ad187/BarManBean/OBXT/29894DA6-6056-46FA-A66D-4B3F5563A2B9_zpsnyhimkal.jpg But now it's GONE http://i934.photobucket.com/albums/ad187/BarManBean/OBXT/B0E167A6-0C6F-432D-A92C-E9F9D9BB48F6_zps7ylvbxhj.jpg "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Chris GTO TT Posted January 23, 2016 Share Posted January 23, 2016 Figures you pull the motor on the Outback and get the best snow storm of the last 20 years lol 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 23, 2016 Author Moderators Share Posted January 23, 2016 Figures you pull the motor on the Outback and get the best snow storm of the last 20 years lol Well, my '97 OBS is on blizzaks and wife's van is on nokian R2's, so we're set "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Chris GTO TT Posted January 24, 2016 Share Posted January 24, 2016 Sure but they lack turbocharged fun... 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
LatentWagen Posted January 24, 2016 Share Posted January 24, 2016 FWIW, I'd rather drive an NA Subie in the snow. Better resolution and control of power delivery; boost not needed. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 24, 2016 Author Moderators Share Posted January 24, 2016 Out of all 3 cars (OBXT, OBS, Honda Odyssey) I think I'd take the Odyssey for safety / roadworthiness. All 3 have snow tires, but the Hakka's on the Odyssey are just ridiculous (and also total overkill for the area, I won't replace them with the same--but they are seriously awesome when we actually get snow). "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
