BMB's Motor Pulling Thread with MAX Boxkitty Drama
  • Moderators
So I first starting thinking / talking about this a while back, and just put it off for a while. Well now my radiator has crapped the bed and it's likely to happen soon. Plans so far:
  • Timing belt, all idlers, water pump, crank/cam seal replacement
  • TiC FU bolts will get reinstalled
  • Koyo Radiator
  • Front banjo bolt removal
  • Oil cooler gasket
  • Passenger VCG
  • Motor mounts (maybe)
  • Up pipe bracket replacement / repair--pretty sure I cross threaded it into the block last time and one of the heat shield bolts broke of in it as well
  • Passenger cam sensor (drivers side as well?)
  • New OCVs
  • Heat blanket for up pipe (maybe)
Other things that I could do "while I'm there" or while there is extra room:
  • replacement hoses as needed (heater hoses, breathers) [freerangeracig kit?]
  • Drive belts
  • 1/2 moon seals
  • A bit of a wire "tuck" with the new fuel line setup
  • Install oil pressure setup in the main galley plug
  • Driver's side VCG as preventative maintenance
Not currently in stock :(
  • Replies 804
  • Created
  • Last Reply
  • Moderators
Current Project Plan:
Steps that need to occur in order:
Remove coilpacks
Perform compression check (possibly...)
Remove spark plugs
Remove valve covers
Check valve clearances with stock timing and record (target values here, http://legacygt.com/forums/showpost.php?p=5314112&postcount=62)
Loosely reinstall VCs
Set engine to timing marks
Install C23 cam lock tool
Mark timing belt with paint pen, check against new belt to confirm
Remove timing belt
Break loose cam sprockets
Recheck valve clearances with no timing and record
Remove remaining idlers / gears
Remove all cam sprockets
Remove rear timing covers
Pull banjo bolt and screen, reinstall
Remove cams, marking EVERYTHING with location and orientation
MIC offending buckets as needed, do math, order correct buckets, reinstall
Reinstall cams, torque to spec, remeasure valve clearances
Replace cam / crank seals
Clean AVCS gears (maybe)
Reinstall all 4 sprockets with TiC FU bolts
Replace timing components--idlers, gears, belt, WP
Recheck valve clearances with new timing installed and record
Replace half moon seals
Replace valve covers with new gaskets and spark plug gaskets
Reinstall new spark plugs
Reinstall coil packs
Reinstall turbo and up pipe
***ALL OTHER WORK NEEDS TO BE COMPLETED AT THIS TIME
Move engine to table (off stand)
Remove fly wheel
Inspect and address rear seals as needed
Reinstall flywheel and clutch
Clean&chase engine-to-trans studs
Antiseize dowel pins
Reinstall motor into car
Steps that can occur at any time:
Replace OCVs, left / right
Rotate IP&T oil line for better fitment, new crush washers needed
Replace oil cooler gasket
Clean and paint VCs
Replace coolant crossover pipe
Replace passenger cam sensor (or reseal if possible?)
Clean timing belt covers, leave off until motor is running and no leaks are evident
Repair up pipe bracket (retap if needed)
Replace all / most hoses as needed
Install oil pressure setup in main galley
Install motor mounts
Parts to order:
Coolant crossover pipe (21328AA011, $23)
copper crush gaskets for IP&T banjo x2 (p/n should be 803912040, $1 each)
copper crush gaskets for passenger banjo bolt x2 (p/n should be 803912040, $1 each)
New rear main seal (806786040, $8)
New cam sensor? (22056AA140, $79)
Header-to-motor gaskets x2 (14038AA000, $12 each)
Half moon seals x4 (11051AA070, $5 each)
Turbo oil return hose (807515712, $8)
PCV (11815AB790, $28)
Power steering gasket (34621AC020)
Header stud (800910550, $1.30)
Dipstick O-ring (806908080, $1.28)
Front Timing belt cover seals (13581AA050, 13594AA000; $17, $11)
Power steering suction hose (34611AG23A, $38.21)
Oil filler neck O-ring (806922040, $2.28)
Oil cap O-ring (803942010, $3.08)
Valve Cover Gasket, Left (13272AA140, $8.94)
Valve Cover Gasket, Right (13270AA190, $8.94)
Spark plug gaskets x4 (13293AA051, $6.87)
Thermostat/gasket assy (21210AA030, $20.67)
New TOB (30502AA130 / 30502AA080, ~$100)
Samco radiator hoses (TCS272C, $103.86 shipped from OAKOS)
Permatex ultrablack
ACT Monoloc?
New clutch?
STi Flywheel (12310AA410)
No longer going to order:
IP&T AVCS replacement line
  • Moderators
So anything that I seem to be missing that folks would due with easy access to everything while the motor is on a stand? I'm thinking about working with JmP to get a bit of a turbo upgrade, but likely staying with something in the 16g-sized-and-similar, just looking for better spool and reliability.
Other than that I really don't think there's anything else I can add that would truly increase performance without getting into true built motor territory...
  • Moderators
I don't think I'm dramatic enough for 50 pages, lol.
Still cleaning up the garage and finishing up some work in our basement apartment before we have a new renter. I'm determine to start this up with things organized, otherwise I fear the whole thing will turn into a total mess. So clearing out some dedicated space for parts, tools, etc.
They say the devil is in the details, but good preparation is the best predictor of success in my opinion. It's good to have a staging area for dirty parts and then a separate space for clean parts. Simple Green commercial strength (purple in color) is good for general cleaning and won't attack aluminum unlike regular Simple Green. Brake cleaner (non-chlorinated) is also good for cleaning most metal parts, but for anything in the lubrication system I would stick to an engine degreaser like Joe Gibbs. Brake cleaner always leaves residue that you don't want in your oil system.
Finally get a big jug of 90%+ isopropyl alcohol and some good lint-free wipes (clean-room grade). A selection of wire and acid brushes, along with a variety of steel wools and scotchbrite pads will come in handy.
  • Moderators
Thank you x100, Rick. I'll look into all of that, would not have known.
Feel free to PM me your cell number for free tech support :lol:
Fuel lines underneath the intake manifold. replace them now. new fuel injection clamps over the shitty worm gear type
I converted to topfeed a while back with the Injector Dynamics kit, so my fuel lines are all AN fittings now. No more winter fuel smell!
  • Moderators
Downpipe off. Most transmissions bolts / nuts off. Motor mounts loose.
Will pull turbo out next, then starter. Remaining trans bolts, disconnect fuel line, and I think that's it. Need to track down and engine crane!
