New Short Block Time...
  • Replies 621
  • Created
  • Last Reply
  • 3 months later...
looking good so far! shiny pistons, nice new oil cooler/heater :)
BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT
  • 2 weeks later...
Clean those timing covers! If you have air and a die grinder, get a cheap soft brush and make those babies shine -- you'll thank yourself for it later when you find yourself opening the hood to show off to everyone. ;)
Hope it fits through the doorway. Turn it sideways if you have to. ;) Good luck!
Yup, it's a straight shot up the stairs and out the back door, shouldn't be an issue. :)
Thats not a terrible idea. Bling has never been a priority, but I should clean them up a bit. :)
Have you put the turbo on and fitted the tmic. Leave the turbo loose on the up pipe, start the tmic into the TB hose, start the two bolts at the turbo, start the support bracket bolts, tighten the TB hose, tighten the two bolts, tighten the up pipe nut's or bolts, tighten the rest.
Engine Build - Click Here
