Max Capacity Posted November 25, 2013 Share Posted November 25, 2013 Maybe go with one step colder plugs too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Chris GTO TT Posted November 26, 2013 Share Posted November 26, 2013 On a street car i've always been a fan of higher compression ratio with less boost. Sure you may give up top hp but you gain a lot on the off boost drive-ability dept. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
Turkeylord Posted November 26, 2013 Author Share Posted November 26, 2013 Got some work done last night. Cams and valve covers took longer than expected, but I made progress. http://i.imgur.com/Hw0xSXbl.jpg Did run into one unexpected problem - the lower left-hand oil pump bolt hole is stripped... Link to comment Share on other sites More sharing options...
FJuan Posted November 26, 2013 Share Posted November 26, 2013 Retread it or Helicoil. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Turkeylord Posted November 26, 2013 Author Share Posted November 26, 2013 Missing some torque specs in the vacation pix, so I just put 5# on the small stuff like the coolant line bolts and 20# on the bigger 12mm hardware like the rear bracket thingy. <shrug> Link to comment Share on other sites More sharing options...
Max Capacity Posted November 26, 2013 Share Posted November 26, 2013 WOW, impressive, I only torqued the flywheel bolts and clutch bolts. Everything else was tight enough. Ok Axle nuts too. But I've been working with nuts and bolts for over 40 years. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BrenTuning Posted November 26, 2013 Share Posted November 26, 2013 Hi-comp motors tend to run less ignition and boost safely, nearly everywhere with no gain in power or off idle response (pre turbo). This in turn makes less power. While it is do-able they tend to be knock prone on lower quality fuel (less then 100 octane) and require some creative tuning. This may not be obvious on low horsepower setups 250-280whp, but increasingly obvious as power goes up. In the case of the customer being on E85, this will negate alot of issues with compression due to octane. Bren Link to comment Share on other sites More sharing options...
Turkeylord Posted November 26, 2013 Author Share Posted November 26, 2013 Thanks Bren, appreciate the clarification. I think I'm going to run with them, as I run E85 99.9% of the time. I forgot to introduce you guys to my friend, Lexi Loaner. http://i.imgur.com/EpIyikkl.jpg Link to comment Share on other sites More sharing options...
Turkeylord Posted November 28, 2013 Author Share Posted November 28, 2013 I was able to get a longer bolt to grab in the stripped out oil pump hole, but in the process of re-installing the pump I Hicksta'd the oil seal. so now I have to wait till tomorrow to pick one up. Otherwise the bottom of the engine & exhaust are finished. The dipstick tube was a PITA to get seated, I had to clearance the bigger of the 2 up pipe brackets for the turbine housing inlet flange, and I had to tweak one of the turbo water pipes BNR provided to fit. Other than that everything went pretty well. http://i.imgur.com/sdyf9O8l.jpg Link to comment Share on other sites More sharing options...
Max Capacity Posted November 28, 2013 Share Posted November 28, 2013 When will you be putting on the intake and turbo inlet tube ? I would do that now before you put it in the car. It should look like this, http://i185.photobucket.com/albums/x40/92Si/DSCN4776.jpg Did you remove the front banjo filter ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Turkeylord Posted November 28, 2013 Author Share Posted November 28, 2013 Yep, that's next, I just need to finish porting one of the TGVs. Front banjo filter? I removed them both from the back of the heads, is there one in the front too? I left that little line on the driver's front pretty much assembled so I could've easily missed it... Link to comment Share on other sites More sharing options...
lingling1337 Posted November 28, 2013 Share Posted November 28, 2013 When will you be putting on the intake and turbo inlet tube ? I would do that now before you put it in the car. Good little piece of advice there. Really not fun wrestling with that inlet pipe inside the engine bay. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 28, 2013 Share Posted November 28, 2013 The front banjo filter is behind the timing belt cover on the drivers side. Get it before you put the timing gears on. Use a good oil filter and you should be fine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Turkeylord Posted November 28, 2013 Author Share Posted November 28, 2013 I pulled that banjo bolt, but it didn't have a filter. I think I must've already pulled it. Finished porting the TGVs between families, lol. Should be ready to install the intake. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 29, 2013 Share Posted November 29, 2013 Good to hear. Hey wait a minute, you worked on it on Thanksgiving... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Turkeylord Posted November 29, 2013 Author Share Posted November 29, 2013 My wife was passed out, fair game! Link to comment Share on other sites More sharing options...
FJuan Posted November 29, 2013 Share Posted November 29, 2013 Looks like you're ready to drop the motor back in. Awesome! My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Turkeylord Posted November 30, 2013 Author Share Posted November 30, 2013 Getting close! http://i.imgur.com/4z17BFol.jpg http://i.imgur.com/mF61Ig4l.jpg Link to comment Share on other sites More sharing options...
Andyjo Posted November 30, 2013 Share Posted November 30, 2013 Where is your turbo oil supply plumbed to!?!? Link to comment Share on other sites More sharing options...
Turkeylord Posted November 30, 2013 Author Share Posted November 30, 2013 To the oil galley near the PCV Link to comment Share on other sites More sharing options...
Max Capacity Posted November 30, 2013 Share Posted November 30, 2013 Are you going to remove the EGT probe and do the 2.2k ohm resistor delete. Tell me there on cat in that up pipe. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Turkeylord Posted December 1, 2013 Author Share Posted December 1, 2013 http://i.imgur.com/K1kOeljl.jpg Link to comment Share on other sites More sharing options...
boxkita Posted December 1, 2013 Share Posted December 1, 2013 fail...repost http://i.imgur.com/K1kOeljl.jpg Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Turkeylord Posted December 1, 2013 Author Share Posted December 1, 2013 LOL, video to follow! Link to comment Share on other sites More sharing options...
Turkeylord Posted December 1, 2013 Author Share Posted December 1, 2013 It lives! [ame=http://www.youtube.com/watch?v=gWA_MwWCFIM]2005 Subaru Legacy GT - New Short Block - YouTube[/ame] Link to comment Share on other sites More sharing options...
