Baddog Posted July 31, 2011 Share Posted July 31, 2011 did you ever pull your first cat? Or has anybody else pulled either of their cats? I pulled my muffler about a week and a half ago and it was just loud... put me on the market for a nice cat back but I didn't notice any power difference. it just heated my rear diff pretty good. RalliTEK is making the Rear Sway Bar again... or its at least on the site... Not yet. Trying to decide what I need to do exactly. Link to comment Share on other sites More sharing options...
JAC Wagon Posted July 31, 2011 Share Posted July 31, 2011 Im gonna pull my whole pipe off. Gonna have a shop bend me a custom 2.5 inch pipe and Ill add a high flow cat to it myself. I like my rumble and subtle exhaust note now, but I want it a little louder. So Ill delete all the resonators and the cat) I am thinking about getting those racelands here VERY soon. Wont I need camber bolts for the rear though? Link to comment Share on other sites More sharing options...
Baddog Posted July 31, 2011 Share Posted July 31, 2011 Possibly. Camber bolts are cheap though. ~$15 or so. Link to comment Share on other sites More sharing options...
JAC Wagon Posted July 31, 2011 Share Posted July 31, 2011 Ok, cool. Another noob question for those who have swapped seats... I like the look of wrx 02,03 seats. How do they sit in a leggy? Are they bolt in or need fabrication? What (if any) seats bolt straight in with little work. This is my DD so it cant be "down" for longer than a day at the most for the moment. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 31, 2011 I Donated Share Posted July 31, 2011 WRX seats or STI seats are a direct bolt in swap. They just sit a little higher then the stock Legacy seats. You will have to switch over the buckle thing for your seatbelt though. Its easy to do -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Zues Marine Posted July 31, 2011 Author Share Posted July 31, 2011 bolt in fine.. read the list of seats on page 1 Link to comment Share on other sites More sharing options...
JAC Wagon Posted July 31, 2011 Share Posted July 31, 2011 WRX seats or STI seats are a direct bolt in swap. They just sit a little higher then the stock Legacy seats. You will have to switch over the buckle thing for your seatbelt though. Its easy to do Thats what I figured, I just wanted to double check. Theres a guy selling 03 WRX seats (front and rear) on i-club. Thought it would be a better upgrade than my stock cardboard feeling ones. Not to mention, Im 6'1 and even I use that little crank thing to lift my seat all the way up. Then I dont feel like I need a booster seat I would like to find a set of HEATED seats to swap in too... that would be very nice. bolt in fine.. read the list of seats on page 1 I know I know! But I wasnt sure about the ride height or if they were bolt in or you had to swap the rails too or whatever. Link to comment Share on other sites More sharing options...
JAC Wagon Posted August 3, 2011 Share Posted August 3, 2011 Braking: WRX Brake Swap – increase braking power with 2pot calipers and larger, 11.5” diameter rotors from the Impreza WRX Am I to assume ANY year WRX will swap onto my outback? Is there anything special I need to know/do/look for while Im searching for a donor WRX? Link to comment Share on other sites More sharing options...
Zues Marine Posted August 3, 2011 Author Share Posted August 3, 2011 2002-2004 would be best, you'll need calipers, brackets, rotors, and its pretty much a straight swap Link to comment Share on other sites More sharing options...
JAC Wagon Posted August 4, 2011 Share Posted August 4, 2011 how much work is entailed in installing coilovers? is it something I can do in my garage in a few hours? Or should I wait and reserve a full afternoon at the hobby shop on base? Link to comment Share on other sites More sharing options...
Zues Marine Posted August 4, 2011 Author Share Posted August 4, 2011 unbolting struts (5 bolts)... reinstalling 5 bolts per wheel Link to comment Share on other sites More sharing options...
JAC Wagon Posted August 4, 2011 Share Posted August 4, 2011 What about the springs? Getting the old springs and struts off seems to be the most work involved... am I right? Will I need a spring compress? Link to comment Share on other sites More sharing options...
Baddog Posted August 4, 2011 Share Posted August 4, 2011 If you're getting a set of coilovers you should just be able to pull the brake line off the strut, 3 bolts at the top hat, 2 bolts at the knuckle. Lift and remove. Easy I have done this at least 10 times now. Link to comment Share on other sites More sharing options...
JAC Wagon Posted August 4, 2011 Share Posted August 4, 2011 Wanna do it 11 times? Link to comment Share on other sites More sharing options...
Baddog Posted August 4, 2011 Share Posted August 4, 2011 If you were closer I would help out! Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 4, 2011 I Donated Share Posted August 4, 2011 Installing coilovers is EASY Remove the rear seat Jack up and jackstand all 4 wheels...remove wheels unbolt the two bolts that hold the strut to the steering knuckle (all 4 wheels) unclip the brake line from the sturt and undo the brake line from the caliper (front wheels) feed the brake line through the thing on the strut undo the top 3 bolts on each strut (you can access the rears by removing the back seat) bolt everything up the same way! bleed the brakes top off brake fluid go gen an alignment If you have access to a shop, I would suggest using it. Having access to air tools to do this job will make your life A LOT easier. On the bottom steering knuckle bolt on the rear, you will probably have to use a swivel&extension on one side....and a open end wrench on the other side of the bolt (because the axle). Thats really the only "hard" part to it. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
JAC Wagon Posted August 5, 2011 Share Posted August 5, 2011 Got em done! http://i35.photobucket.com/albums/d160/JeepinGoose/021.jpg Link to comment Share on other sites More sharing options...
Jab83 Posted August 5, 2011 Share Posted August 5, 2011 orange?? i like! Link to comment Share on other sites More sharing options...
JAC Wagon Posted August 5, 2011 Share Posted August 5, 2011 haha no. Red, the orange is the damn street light! Ill get better pics today. Link to comment Share on other sites More sharing options...
Jab83 Posted August 5, 2011 Share Posted August 5, 2011 I liked it better thinking it was orange. I think i'll paint mine that color. It looks awesome. Link to comment Share on other sites More sharing options...
JAC Wagon Posted August 5, 2011 Share Posted August 5, 2011 More pics of the coilovers installed. http://i35.photobucket.com/albums/d160/JeepinGoose/CanonT1i027.jpg http://i35.photobucket.com/albums/d160/JeepinGoose/CanonT1i025-1.jpg http://i35.photobucket.com/albums/d160/JeepinGoose/CanonT1i022.jpg http://i35.photobucket.com/albums/d160/JeepinGoose/CanonT1i015.jpg http://i35.photobucket.com/albums/d160/JeepinGoose/CanonT1i013.jpg http://i35.photobucket.com/albums/d160/JeepinGoose/CanonT1i012.jpg http://i35.photobucket.com/albums/d160/JeepinGoose/CanonT1i011.jpg http://i35.photobucket.com/albums/d160/JeepinGoose/CanonT1i010-1.jpg http://i35.photobucket.com/albums/d160/JeepinGoose/CanonT1i009.jpg http://i35.photobucket.com/albums/d160/JeepinGoose/CanonT1i008.jpg Link to comment Share on other sites More sharing options...
JAC Wagon Posted August 5, 2011 Share Posted August 5, 2011 Once I get the spring rate set, ill adjust the ride height back to where I want it. till then, its fun to show off and even more fun to drive!!!! Link to comment Share on other sites More sharing options...
Baddog Posted August 5, 2011 Share Posted August 5, 2011 Loving the OB. How is the ride on them? Adjustability? Anything you can say about them. Link to comment Share on other sites More sharing options...
JAC Wagon Posted August 6, 2011 Share Posted August 6, 2011 Ive got some rubbing issues from the tires being so wide, they rub on the fenders outside edge. The ride is surprisingly nice! I tweaked the spring rate a little too tight tonight, so every bump feels like a massive pothole, ill fix it tomorrow. The ride height is low, lower and drag yo sheet on da ground. Link to comment Share on other sites More sharing options...
WESTcoast Posted August 7, 2011 Share Posted August 7, 2011 Hey Zues Here is some stuff to update the suspension list coilovers -raceland Coilovers 450 bucks camber bolts -Ebanchi camber bolts 17.50 for a set of 2 Aluminum Control Arms -JDM GC Control arms -alumminum and are direct bolt on Caster kits (adds caster to the front wheels giving the car more turn in response -GTSpec anti lift kit -Whiteline Caster kit -Perrin positive steering kit Brakes helps prevent flex amoung the master brake cylinder by adding more holding points to it - Grimmspeed Master Cylinder brace Link to comment Share on other sites More sharing options...
