scoobydoobie Posted August 31, 2009 Share Posted August 31, 2009 thats the wheel I want... How do rota's do for weight? I want to upgrade the wheels to something STI-ish looking but want to drop weight and clear brembo's.... check out wheelweights.net. My Rota SDRs are fairly light @ 16.5lbs a piece, but they are also only 17 x 7.5 Link to comment Share on other sites More sharing options...
N.sane Posted August 31, 2009 Author Share Posted August 31, 2009 ^some of the info on wheelweights.net is incorrect. If you do a quick Google search people have weighed them on their scale @ around 18lbs for the SDR. Nonetheless, it's still weight reduction from stock wheels. Link to comment Share on other sites More sharing options...
93turbo2 Posted September 1, 2009 Share Posted September 1, 2009 Here's some quick pics with my point and shoot digital cam. http://i21.photobucket.com/albums/b255/93turbo/Rota%20Gravel/IMG_5350.jpg http://i21.photobucket.com/albums/b255/93turbo/Rota%20Gravel/IMG_5386.jpg http://i21.photobucket.com/albums/b255/93turbo/Rota%20Gravel/IMG_5370.jpg http://i21.photobucket.com/albums/b255/93turbo/Rota%20Gravel/IMG_5376.jpg http://i21.photobucket.com/albums/b255/93turbo/Rota%20Gravel/IMG_5373.jpg Hopefully I can borrow my girls D40 and take some better pictures. Link to comment Share on other sites More sharing options...
vitaliy_08 Posted September 1, 2009 Share Posted September 1, 2009 Why do you need a better camera when you can just edit them with an HDR program? Link to comment Share on other sites More sharing options...
finalburden Posted September 1, 2009 Share Posted September 1, 2009 Why do you need a better camera when you can just edit them with an HDR program? Because that makes the pictures worse. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted September 1, 2009 Share Posted September 1, 2009 OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
crumbsnatcher Posted September 1, 2009 Share Posted September 1, 2009 So if a 17x8, 17x7.5, 18x8, or 18x7.5 option isn't available in this great looking wheel, will I have rubbing issues if I run a 225 wide tires on these? I know that most people feel it is pointless to run anything less than 235 on 8.5 wide wheel, but I really want to avoid the whole tire rubbing & rolling fenders situation. Also, will this offset clear BBK setup? BTW - 93turbo2, your car looks hawt!!! Is that gunmetal or hyper black? Link to comment Share on other sites More sharing options...
N.sane Posted September 1, 2009 Author Share Posted September 1, 2009 It's gunmetal. 225/40/18 should be fine as long as you're not slammed. Not sure about BBK clearance though. Link to comment Share on other sites More sharing options...
rnstein69 Posted September 1, 2009 Share Posted September 1, 2009 Most likely with a 225 tire on an 8.5" wide rim (depending on offset) you wont have rubbing issues. you might have to roll the rears a little bit, but I think that you should be ok. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted September 1, 2009 Share Posted September 1, 2009 225 on an 8.5 would just scream BROKEN!!!! because these are rota's not volks and with that little protection for the rim you are sure to crack it. I would go with a 235/40 as you get a bit more cushion to help absorb the jolts from road bumps. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
vitaliy_08 Posted September 1, 2009 Share Posted September 1, 2009 Falken FK452 235/40/18 He actually does have 235 not 225 Link to comment Share on other sites More sharing options...
vitaliy_08 Posted September 2, 2009 Share Posted September 2, 2009 It looks like the Gravels weigh 22.9 lbs and they clear brembos according to suby_dude at NASIOC (#343) Link to comment Share on other sites More sharing options...
N.sane Posted September 2, 2009 Author Share Posted September 2, 2009 dang, thats heavy Link to comment Share on other sites More sharing options...
naimouasta Posted September 2, 2009 Share Posted September 2, 2009 but arent the 17in stockers around that weight anyway? the 18in spec b are even more. Link to comment Share on other sites More sharing options...
N.sane Posted September 2, 2009 Author Share Posted September 2, 2009 from what I've read, 17" stockers are between 20-21lbs. Link to comment Share on other sites More sharing options...
93turbo2 Posted September 2, 2009 Share Posted September 2, 2009 Here's a few pics i took tonight. Enjoy! http://i21.photobucket.com/albums/b255/93turbo/Rota%20Gravel/DSC_1217_1-1.jpg http://i21.photobucket.com/albums/b255/93turbo/Rota%20Gravel/DSC_1216_1.jpg http://i21.photobucket.com/albums/b255/93turbo/Rota%20Gravel/DSC_1214.jpg Link to comment Share on other sites More sharing options...
SnowBound BP5 Posted September 2, 2009 Share Posted September 2, 2009 from what I've read, 17" stockers are between 20-21lbs. So it's only a couple more pounds heavier plus you get the aggressive 8.5" width. That's not too bad. Link to comment Share on other sites More sharing options...
lucas569 Posted September 2, 2009 Share Posted September 2, 2009 the wheels just dont look like they fit right... too bad. Link to comment Share on other sites More sharing options...
MiniStiGuy Posted September 2, 2009 Share Posted September 2, 2009 yeah that last picture just makes them look like they are like the 22' wheels people put on a C300. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Razor Posted September 2, 2009 Share Posted September 2, 2009 So there is no way you can run these on a lgt without rolling and etc? That stinks. Link to comment Share on other sites More sharing options...
SKYravefever Posted September 2, 2009 Share Posted September 2, 2009 WANT! We should've done some back to back SWP shots as I was out and about the city doing some logging with RR. Link to comment Share on other sites More sharing options...
N.sane Posted September 2, 2009 Author Share Posted September 2, 2009 So there is no way you can run these on a lgt without rolling and etc? That stinks. I think he only had to roll the rears. You could probably get away with it if you use a 225/40/18 tire. Link to comment Share on other sites More sharing options...
93turbo2 Posted September 3, 2009 Share Posted September 3, 2009 I think he only had to roll the rears. You could probably get away with it if you use a 225/40/18 tire. Actually I rolled all 4 corners to the on the safe side. I haven't had time to go have some camber dialed in the front. A 225/40/18 isn't recommended for an 8.5in wide rim. Most manufacturers list the max rim width for that size at 8in. and 235/40/18 min is 8.5in which is why I went with the 235s. Link to comment Share on other sites More sharing options...
93turbo2 Posted September 3, 2009 Share Posted September 3, 2009 yeah that last picture just makes them look like they are like the 22' wheels people put on a C300. lol. Yeah I didn't like my last pix too much either, I raised the fronts 2 threads from what I orig. had with the sti bbs wheels on due to the rubbing. I'll most likely bring it back down when i have time to get some negative camber dialed in up front. Link to comment Share on other sites More sharing options...
93turbo2 Posted September 3, 2009 Share Posted September 3, 2009 WANT! We should've done some back to back SWP shots as I was out and about the city doing some logging with RR. Cool, I was with my girl driving around the city and getting some ice cream at Ghiradelli Sq. Link to comment Share on other sites More sharing options...
