mwiener2 Posted May 16, 2011 Share Posted May 16, 2011 On an OBXT, the proper tire size for 18's would be 245/45-18 I run that and I get the slightest of rub at full lock. Once the fender plastic wore away, it stopped rubbing. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
lyncha00 Posted May 17, 2011 Share Posted May 17, 2011 Are you running the BTS kit, or are you using HDs with other springs like STI pinks or swifts? The one from ION Performance, I think that is the HDs Link to comment Share on other sites More sharing options...
lyncha00 Posted May 17, 2011 Share Posted May 17, 2011 What tire size were you running on the 18" wheels? I hadn't thought about potential issues with 18" wheels. Right now, I'm running stock wheels, but running 17"s with the stock tire size is starting to really limit my tire choices. In the summer, I like to run max performance tires (GY Eagle F1's right now, not available in stock size anymore). 245/45 on the 18x8 tarmac 3s Link to comment Share on other sites More sharing options...
ktmrider Posted January 2, 2012 Share Posted January 2, 2012 Revival bump, just installed the BTS kit purchased used from JMP on this site. Can't rave enough about the 5056 system, hands down the best option for DD duties. With some sway bar upgrades it could even dodge some cones however I'm not going that route quite yet. Side note, as noted in a thread on OB.com the rear struts have 5 grooves cut into the body to adjust spring height/preload. Today I moved it to the highest point, originally at center, and can tell you this makes the system "complete". Prior there was a slight drop in ride height of 1/2" plus the rear felt a bit soft relative to the fronts ( altho tons better than stock ). Moving the rear lower perches recovered 3/8" height and firmed up the ride. On local speed hump/rollers I could hit the stops at 20mph, now they barely touch at 30. Impatient I'll update the OB thread shortly. If you had any reservations about tweaking your ADM rears believe me it was well worth it! Link to comment Share on other sites More sharing options...
M. Schneider Posted January 2, 2012 Author Share Posted January 2, 2012 Hey ktmrider - Glad you like the (JDM) Bilstein BTS 5056 kit. Our MY05 Outback XT continues to drive all the better with the BTS kit. 20k miles since the upgrade. +1 to an uprated rear sway bar. The elephant in the room is the brakes, the brakes, the brakes.... Cheers, Mike |`94 E-Class Coupe |`98 Carrera 993 C2S |`14 Cayman S |`20 Outback Touring XT | All Debadged | Link to comment Share on other sites More sharing options...
ktmrider Posted January 3, 2012 Share Posted January 3, 2012 Hey ktmrider - Glad you like the (JDM) Bilstein BTS 5056 kit. Our MY05 Outback XT continues to drive all the better with the BTS kit. 20k miles since the upgrade. +1 to an uprated rear sway bar. The elephant in the room is the brakes, the brakes, the brakes....Thx MS, followed your/this thread with huge envy since the day I got my OBXT. I just aSSuMed the LGT suspension bits were the same, had GT revC 'Steins on my LGT and missed them big time. Brakes were another "oh heck" by SOA and a difference I was not aware of, hated them from the first lockup attempt. Swapped out for some LGT stoppers F&R including SS lines and ST pads. Must-do IMO for all OBXT owners. Appreciate your time and updates, will try and do the same! Link to comment Share on other sites More sharing options...
ssbtech Posted January 5, 2012 Share Posted January 5, 2012 Swapped out for some LGT stoppers F&R including SS lines and ST pads. Must-do IMO for all OBXT owners. How much of an improvement was there? I realize it won't come close to big brake kit for stopping performance or feel, but overall? It's been years since I drove an LGT so I don't remember what the brakes were like. Link to comment Share on other sites More sharing options...
ktmrider Posted January 6, 2012 Share Posted January 6, 2012 Here's the link for reference info: http://legacygt.com/forums/showthread.php/outback-brakes-and-rotors-38676.html It's more that the OB brakes are so much smaller than the LGT items, extra weight of the OB and power of the OBXT show how spindly the stock stuff is. If I had to put a number out the modulation and power improved by 20% much like the difference I saw when using Brembos on my old LGT. Link to comment Share on other sites More sharing options...
ktmrider Posted February 10, 2012 Share Posted February 10, 2012 Been awhile, work travel has kept me busy. I bought an 05 LGT with BC suspension bits while in CA and drove it for 3 weeks. Returned home to the OBXT for 5 days, love the Bilstein stuff that much more. Total bliss, to quote Ferris Bueller, "If you have the means I highly suggest one/some." Link to comment Share on other sites More sharing options...
ktmrider Posted April 7, 2012 Share Posted April 7, 2012 Update. More work travel. Sold the LGT. Love, love, love the BTS bits. No regrets AT ALL. Link to comment Share on other sites More sharing options...
valadares Posted October 13, 2012 Share Posted October 13, 2012 is this kit fit on outback H6? Link to comment Share on other sites More sharing options...
mwiener2 Posted October 14, 2012 Share Posted October 14, 2012 Have more than 2 people done this? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
dan04103 Posted October 14, 2012 Share Posted October 14, 2012 I performed the LGT brake upgrade and LOVE it! Got LGT calipers/stoptech blanks/stoptech pads and the difference is night and day. The difference in the rear being vented rotors and the fronts are about and inch larger diameter. This was an H6 by the way. Link to comment Share on other sites More sharing options...
mwiener2 Posted October 15, 2012 Share Posted October 15, 2012 I was referring to the shocks, of which this thread is for. BTW, if you had done just the pads, you probably would have had a similar improvement. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
dan04103 Posted October 15, 2012 Share Posted October 15, 2012 I was referring to the shocks, of which this thread is for. BTW, if you had done just the pads, you probably would have had a similar improvement. My bad on the reply your response wasn't directed that way but I get it, no harm done... absolutely disagree, I had upgraded ST pads before the GT conversion. Night and day friend. I apologize for the offtopic however. Enjoy! Link to comment Share on other sites More sharing options...
Impatient Posted February 10, 2013 Share Posted February 10, 2013 There is a guy in Porirua (Wellington), New Zealand with a set of used BTS 5056 springs for sale. I saw them on TradeMe.co. I can't register since I don't live in NZ or AU. Anyone know him (TradeMe account is duchess_de....of course it might not be a "him")? I would like to buy them but don't know how to reach "him." So, I guess this post does one of 2 things. Either: 1) alerts someone else who might want them and can bid in NZ, or 2) lets someone who know him, or knows of another listing for them on a forum I can subscribe to, somehow help me get in touch with "him" about them. Link to comment Share on other sites More sharing options...
Wittyfull Posted February 10, 2013 Share Posted February 10, 2013 I have a BTS 5056J kit on order from Japanparts. Hopefully, it should get here in a month or two. My plan is to reverse engineer the springs and struts and see if I can put together a comparable kit using locally sourced parts. Link to comment Share on other sites More sharing options...
Impatient Posted February 11, 2013 Share Posted February 11, 2013 You'll need front & rear tophats. Fronts readily available (spec b), rears avail as JDM only I think. I think I have a pair:rolleyes:...if I decide I don't need to hoard them. Link to comment Share on other sites More sharing options...
Impatient Posted February 11, 2013 Share Posted February 11, 2013 http://legacygt.com/forums/attachment.php?attachmentid=141714&thumb=1&d=1360561643 Does this look like the rear tophat needed for the BTS 5056 kit? Link to comment Share on other sites More sharing options...
Wittyfull Posted February 11, 2013 Share Posted February 11, 2013 Yes, I think that is the JDM tophat. This is a picture of the rear spring top seat. This is a pic from M. Schneider. Link to comment Share on other sites More sharing options...
Wittyfull Posted February 11, 2013 Share Posted February 11, 2013 This is what the USDM rear tophat looks like. This is a pic from M. Schneider. Link to comment Share on other sites More sharing options...
Impatient Posted February 11, 2013 Share Posted February 11, 2013 Yeah saw those, and he mentioned a 20370AG010 kinda number which I found a hazy picture of on JapanParts. But I do think I have the tophats....just no BTS springs or kit. Link to comment Share on other sites More sharing options...
Impatient Posted February 23, 2013 Share Posted February 23, 2013 Do these rates seem really soft? Like Spec B soft? Product Specs Brand: Bilstein Product: BTS Coilover Suspension Part Number: BTS5056J SPECIFICATIONS: Spring Rates - Front: 3kg - Rear: 4.6kg Link to comment Share on other sites More sharing options...
M. Schneider Posted February 23, 2013 Author Share Posted February 23, 2013 Revival bump, just installed the BTS kit purchased used from JMP on this site. Can't rave enough about the 5056 system, hands down the best option for DD duties. With some sway bar upgrades it could even dodge some cones however I'm not going that route quite yet. Hey ktmrider - Glad to hear of another BTS suspension convert, how many is that now? .. 4 or 5 years and 25k miles has pasted since our BTS install - I can report all is well with the Subi, although it’s worth mentioning the cars pampered duty cycle. Monday: Up and out of the garage by 5am starting a 50 mile hwy/airport run – parked at ATL until Thursday evening for the 50 mile hwy run home. – pretty lite duty for any car. The BTS suspension feels the same since new. Cheers, Mike |`94 E-Class Coupe |`98 Carrera 993 C2S |`14 Cayman S |`20 Outback Touring XT | All Debadged | Link to comment Share on other sites More sharing options...
ktmrider Posted February 25, 2013 Share Posted February 25, 2013 ^^ Good to hear from ya MS! Last I heard there were three total, not sure of the third party tho. Couldn't be happier with mine. Link to comment Share on other sites More sharing options...
