whitetiger Posted November 15, 2008 Author Share Posted November 15, 2008 here http://www.torsen.com/products/products.htm http://www.torsen.com/files/Torsen%20Traction%20Differential%20Technical%20Sheet.pdf ther are 3 different types of torsen diffs, 1 of them being a helical type. I wonder which is in the sti and 07+ spec b rear. From whatr i understand, the subaru front helica i have is a similar design to the type-2 torsen diff. subaru-http://www.rallispec.com/images_thumb/rst1903.jpg Torsen t-2- http://www.torsen.com/images/T2color2.jpg Link to comment Share on other sites More sharing options...
whitetiger Posted November 15, 2008 Author Share Posted November 15, 2008 and heres the quaife unit http://www.gruppe-s.com/Subaru/subtrn/diff_cutaway_art.gif Link to comment Share on other sites More sharing options...
Guest Posted November 16, 2008 Share Posted November 16, 2008 Btw, this article claims helical is superior to suretrac: http://www.subdriven.com/news/publish/Features/article_340.shtml Seems consistent with others opinions that say 05+ STI understeers less than 04. So helical it is for me! Link to comment Share on other sites More sharing options...
whitetiger Posted November 16, 2008 Author Share Posted November 16, 2008 Good find. Helical FTW. I f scrape another 3k together ill be getting helicals for the center and rear diffs as well. Link to comment Share on other sites More sharing options...
Guest Posted November 16, 2008 Share Posted November 16, 2008 Yeah. For the rear I am actually thinking about putting clutch type diff, not Torsen. Have both (). Bought the clutch one real cheap in anticipation of 6spd swap, and the tranny I ended up buying came with Torsen in the package. I believe clutch is better for serious road racing, rallying and bad winter conditions. Stock JDM SpecC STI comes with clutch type, so FHI must think so as well. Torsen without traction becomes open diff unlike the clutch type. For the center I'll just keep the VLSD... going to DCCD is too expensive unless I came accross a cheap take-off, but these are rare. Link to comment Share on other sites More sharing options...
whitetiger Posted November 16, 2008 Author Share Posted November 16, 2008 +1, if you are not an autoxer, def keep the clutch type in the rear, it will work better in poor weather conditions. I think you will be fine with a helical in front, viscous center and clutch rear. Link to comment Share on other sites More sharing options...
Guest Posted November 23, 2008 Share Posted November 23, 2008 Got front helical LSD installed in my 08 SpecB tranny at Rallitek in NJ. Will know how it works in few weeks after I put the tranny on the car. Btw, install on 6-speed is pretty easy. I did not realize the bellhousing comes off separately so there is no need to disassemble the transmission unlike on 5-speed. Still one has to deal with adjusting backlash, getting the drive axles bearings adjusted properly and the side retainers require special tools.... better left to pros, I guess. Link to comment Share on other sites More sharing options...
MOMSWGN Posted November 28, 2008 Share Posted November 28, 2008 Spoke to Jeff with DS1, Mfactory's LSD won't be out until 2009. I've been having a hard time sourcing a RST-1903 from Japan as they are on backorder. Jeff happened to have just put a RST-1903 into the shop's LGT and sold it to me for a good price. Link to comment Share on other sites More sharing options...
whitetiger Posted November 29, 2008 Author Share Posted November 29, 2008 ^well its a good thing i got one when i did. the diff rocks so far. car has awsome grip. Link to comment Share on other sites More sharing options...
a1rocketpilot Posted December 8, 2008 Share Posted December 8, 2008 Whitetiger, I'm so insanely jealous of your Legacy! It seems like it would be such a fun car to autocross. This LSD doesn't bump you out of DSP does it? Link to comment Share on other sites More sharing options...
whitetiger Posted December 8, 2008 Author Share Posted December 8, 2008 The legacy is in ESP, and no it does not bump me out. If it had, i would not have gotten it. Link to comment Share on other sites More sharing options...
MOMSWGN Posted December 16, 2008 Share Posted December 16, 2008 Rallispec has one RST-1903 in stock now. Link to comment Share on other sites More sharing options...
Gator GT Posted December 17, 2008 Share Posted December 17, 2008 Whitetiger, I too am awaiting serious snowfall since getting my HLSD installed by RalliSpec back in March. yes, unclemat is correct, I had an 06 STI front HLSD installed in my 6MT. I think I'm one of the few (if not only) 07 USDM specB with 3 LSDs (2 mechanical and 1 viscous; fortunately I have an R180 rearend, stock). It was also in my plans to upgrade from 215 RE050's to 225 at some point...and that point came earlier than expected when I found a hole from glass in one of my tires (yay, I get to upgrade...booo, I get to over-extend my funds), so I stepped up to 225 Michelin PS2 tires and that elevates the game even FURTHER!!! And that's exactly it, power on in the corner and it's like the car is pulling itself through the corner (well, that's cause it is) and launches itself out of it! I did loads of research before settling on the Helical design for my DD. I wanted low maintenance, seamless operation and proven reliability. I don't truly rally the car (so having 1 wheel off the ground is not really going to be an issue in the daily environment) so there was no real need to have a clutch pack front LSD. Only daily scenario that would suck is being on sheer ice, as no tire would have better traction (in a true sheer ice situation). But now, I'm back on 205 Nokian snows and am salivating at the upcoming snow storms (no more ice storms PLEASE!!) Enjoy whitetiger and unclemat...now Christmas will be anyday there is snow on the ground and no one around! "If we are to guard against ignorance and remain free, it is the responsibility of every American to be informed." - T. Jefferson Link to comment Share on other sites More sharing options...
Saul_Good Posted February 10, 2009 Share Posted February 10, 2009 Whitetiger: How is this thing working out for you thus far? Link to comment Share on other sites More sharing options...
whitetiger Posted February 11, 2009 Author Share Posted February 11, 2009 Its working great. I dont drive it as much as i used to since i got the outback sedan, but the thing is a blast to drive when i do. I can power slide the thing much better now around turns. the car is very stable under power. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted February 11, 2009 Share Posted February 11, 2009 http://www.rallispec.com/Layout/product_titles/title_rst1903.gifhttp://www.rallispec.com/Layout/spacer.gifRST-1903 Subaru Helical Front LSD So that is the part number? I should be able to get from my dealer or KOP? Any special shimming required on install? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
SBT Posted February 11, 2009 Share Posted February 11, 2009 Crap... I can't remember who but somone already dropped the STI HLSD into spec. B 6MT. I believe that was GatorGT nm - just saw his post above. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Guest Posted February 11, 2009 Share Posted February 11, 2009 I believe that was GatorGT nm - just saw his post above. And me Link to comment Share on other sites More sharing options...
whitetiger Posted February 13, 2009 Author Share Posted February 13, 2009 So that is the part number? I should be able to get from my dealer or KOP? Any special shimming required on install? I dont think a regular deal can get it. Order it from rallispec.com Its where I got mine. with any diff install, preload and backlash must be set properly. You'll want a knowledgable shop to install this for you. Link to comment Share on other sites More sharing options...
f1anatic Posted February 16, 2009 Share Posted February 16, 2009 Hello all, I have 2 questions and I would like both WhiteTiger and unclemat to comment as well as anyone else with relevant experience. 1) Is the front LSD that WhiteTiger purchased from Rallitek usable on both the regular 5MT and the Spec-B 6MT ? If not, which aftermarket one would do ? I am looking to upgrade to a front LSD and a 6MT but I am not sure I have the money to do both at the same time. I understand the costs of taking the 5MT apart and installing the new diff but it is probably less expensive than taking/adding the front LSD to the 6MT which also requires the new rear torsen LSD. 2) If I choose to upgrade the front LSD, do I also have to upgrade the rear oem LSD ? If so, to which one ? Or can they function together ? I think Whitetiger already has an upgraded rear diff. 3) Who made this front LSD ? It is not an OEM part in another market is it ? 4) Was it money well spent ? While there are other things I could improve on the car like suspension, I really feel that a front LSD is what I want compared to say: coil-overs and bigger turbo and bigger intercooler. (currently pro-tuned Stage 2) Thanks. f1 Link to comment Share on other sites More sharing options...
Garandman Posted February 16, 2009 Share Posted February 16, 2009 Enjoy! That ought to get rid of the power on understeer. //Why? Would seem to make it worse on slippery surfaces, if anything. Who Dares Wins スバル Link to comment Share on other sites More sharing options...
Guest Posted February 16, 2009 Share Posted February 16, 2009 Ad 1) 5MT and 6MT parts are not interchangeable. Ad 2) No. Ad 3) Subaru in both cases. There are aftermarket units as well. Ad 4) Don't know yet. Car has new engine and I've not had opportunity to push it yet. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted February 16, 2009 Share Posted February 16, 2009 1) Is the front LSD that WhiteTiger purchased from Rallitek Purchased from Rallispec, not Rallitek http://www.rallispec.com/prod_diff.htm Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
Guest Posted February 16, 2009 Share Posted February 16, 2009 Btw 6MT LSD is easy to get because it's stock USDM STI part. Costs less than $500 new. 5MT LSD is JDM only and costs like $900 or so. I am not sure if it ever came stock, it probably did on old school STIs. Link to comment Share on other sites More sharing options...
f1anatic Posted February 16, 2009 Share Posted February 16, 2009 Btw 6MT LSD is easy to get because it's stock USDM STI part. Costs less than $500 new. 5MT LSD is JDM only and costs like $900 or so. I am not sure if it ever came stock, it probably did on old school STIs. Where did you buy the Spec B tranny and for how much and plz. answer the same for the 6MT LSD ? Given that it is so much easier to change, I would likely do both. You can also PM me if you deem necessary. Also for the love of God, please tell me what is your rpm at 60 mph in 6th gear. I have seen a million calculations here that it makes little to no difference but I just never saw an rpm readout at 60 or 70mph. I would not upgrade to the 6-MT in order to better cope with insane horsepower...if and when I upgrade the turbo, I will level off at 300 whp which is more than plenty for me and the current 5-MT trannies do take it well (already have the better clutch). Link to comment Share on other sites More sharing options...
