SubOperator Posted September 6, 2019 Share Posted September 6, 2019 Any guarantee on that stuff? I tried Blue Devil on a beater once. Ended up scooping it out of the cooling jacket with a wooden spoon, but they did give me my money back. Could be a free experiment. It's an oil additive, not coolant one - those are pretty much guaranteed to clog somewhere in coolant path. No guarantees of course, but empirically it got me out of tearing apart engines on my own LGT (blue smoke on WOT) and on my wife's Tribeca (white smoke on idle after overnight). When faced with possible engine tear down and either short block rebuild or new shortblock, I am willing to give an additive a try... 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
solidxsnake Posted September 6, 2019 Share Posted September 6, 2019 (edited) Before tearing it all apart again I decided to give it a shot with CERATEC oil additive from Liqui-Moly. This stuff supposedly dislodges carbonized deposits around rings, and I figured I will pretty much lose nothing if it does not help. To my own surprise and relief, the white smoke at start disappeared within couple of weeks. Some people may say it's not going to work but I'd say give it a shot. it's never late to take a motor apart. It also worked for me when my LGT started smoking on WOT (blue smoke though), and just adding it (CERATEC) helped. $35 vs $3500 experiment always wins in my book. I think the HG on Mike's motor deteriorated from it sitting. I picked it up from you in the June-ish timeframe, but closed on a condo just after and had no time to work on the car until the following April. At least, that's all I can fathom. i'm sure it's oil and not coolant. It smells like oil, and the consumption definitely fits the bill (burned a quart after 3 autox runs last season ). Coolant shows no consumption. The startup has a slight blue tinge, but the smoke under the hood when hot doesn't (which is why I think the hood smoke is just ATF from the steering system, it also smells a bit different). There's a ton of oil in the intake tract, so much so that the MBC I hooked up started sticking because of it, and when I reached down and touched the barb with the small hole in it, my hands got covered in oil I totally forgot about that CERATEC you gave me! I still have that bottle, no reason not to try that and see what happens. On a forum-related note: I find the double-spacing goes away if I use "shift+enter" to add line breaks, instead of just "enter." YMMV Edited September 6, 2019 by solidxsnake Link to comment Share on other sites More sharing options...
Bxm1799 Posted September 6, 2019 Share Posted September 6, 2019 Also do you guys know if carid is a good website to get parts from???? Link to comment Share on other sites More sharing options...
Notorious Posted September 6, 2019 Share Posted September 6, 2019 Also do you guys know if carid is a good website to get parts from???? No, their parts catalog isn’t true some of the time. Some parts listed say they will fit but I know for a fact they don’t. They group in GT and nonGT parts for example as well as universal parts. Unless you know what you’re looking for, I wouldn’t trust their catalog. Also, don’t add a turbo the the 2.5i. Just sell it and get a GT. There’s no reason for going down that path, trust us. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 6, 2019 Share Posted September 6, 2019 Also do you guys know if carid is a good website to get parts from???? I've been having good luck from this place lately. https://www.am-autoparts.com/?trk_msg=EN6MV1352S4KT2JOE14U2DPH7K&trk_contact=RL21KN1OJ71BQV5SKA5PCA1PU8&trk_module=bna&trk_sid=JK3S2AE5RF162D9QLINFGV1MLC&utm_source=Abandonment&utm_medium=Email&utm_term=Find+Something+Else&utm_campaign=AbSearch2&utm_content=BA+Product+Browse+Message+2 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Bxm1799 Posted September 6, 2019 Share Posted September 6, 2019 Okay I might just put in a cold air then exhaust the some cosmetics. Link to comment Share on other sites More sharing options...
Infosecdad Posted September 6, 2019 Share Posted September 6, 2019 Do you have a walkthrough on what you did to make it work, do all of your buttons work? Anything that doesn't work? Everything works perfectly, I honestly love having a mute button now (there isn't one on the stereo). I followed MasAyinde's guide here: https://legacygt.com/forums/showthread.php/installing-08-09-steering-wheel-w-audio-controls-into-05-253354.html There are two things to do, one is to run a couple more wires that you may not have yet, that is detailed here: http://legacygt.com/forums/showthread.php/install-steering-wheel-radio-controls-26232.html Then you can follow MasAyinde's guide to repin the connectors to fit your 05-07 clockspring. Link to comment Share on other sites More sharing options...
Infosecdad Posted September 6, 2019 Share Posted September 6, 2019 Perfect thank you. I got caught in the middle with my 07 as it has aux in and a mute button on the radio but it has the old steering wheel controls and I like the look of the newer style. Are you using your older cruise control still? No, I went all in on it. I have the 08-09 back shell (no hole for the toggle CC on the lower right), and use the cruise buttons on the right hand side now. I used to have the older LL Bean wheel and style audio controls that split them across both sides. I like the newer style with audio on the left, cruise on the right. It's still reversible if I wanted to go back to OEM for 05 for some crazy reason, most of the difference is just connectors that need to be repinned. Link to comment Share on other sites More sharing options...
jaylew Posted September 6, 2019 Share Posted September 6, 2019 Everything works perfectly, I honestly love having a mute button now (there isn't one on the stereo). I followed MasAyinde's guide here: https://legacygt.com/forums/showthread.php/installing-08-09-steering-wheel-w-audio-controls-into-05-253354.html There are two things to do, one is to run a couple more wires that you may not have yet, that is detailed here: http://legacygt.com/forums/showthread.php/install-steering-wheel-radio-controls-26232.html Then you can follow MasAyinde's guide to repin the connectors to fit your 05-07 clockspring. That is one way, I ended up swapping out the 05 clock spring for an 09 so that the connectors at the wheel are the same. I then took a harness from a junk yard 05 and 09, to make an adapter harness to go from the 09 clock spring to the 05 car harness. Plug-n-play reversible. Also ran the additional wires to the stereo for the radio controls and back lighting. It is super helpful that the airbag didn't change harness or plugs through the MY. I agree, the 08-09 controls are much better than the split stereo controls. Also having the stereo controls on the left side is nice to change songs/volume while shifting! I can't go back now to the no control wheel I had Wagon is LIFE! - 265,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
awfulwaffle Posted September 7, 2019 Share Posted September 7, 2019 Staged for tomorrow's fun, and got the windage tray, oil pickup and oilpan installed on the Type RA shortblock so the RTV can set up overnight. Let's see if I can get away with using 90 minute RTV on the forward cam caps... Link to comment Share on other sites More sharing options...
SubaruTrissi Posted September 7, 2019 Share Posted September 7, 2019 Today i manual swapped my 4th gen[emoji23] Sent from my subie cave’s pc 1997 impreza GT: sold 2002 impreza WRX: sold 2005 forester sti: on jackstands 2004 legacy base: turbokit in da trunk Link to comment Share on other sites More sharing options...
Bxm1799 Posted September 7, 2019 Share Posted September 7, 2019 I've been having good luck from this place lately. https://www.am-autoparts.com/?trk_msg=EN6MV1352S4KT2JOE14U2DPH7K&trk_contact=RL21KN1OJ71BQV5SKA5PCA1PU8&trk_module=bna&trk_sid=JK3S2AE5RF162D9QLINFGV1MLC&utm_source=Abandonment&utm_medium=Email&utm_term=Find+Something+Else&utm_campaign=AbSearch2&utm_content=BA+Product+Browse+Message+2 What about for after market performance parts? The na has a small market so if anyone can give me some more links that’d be much appreciated Link to comment Share on other sites More sharing options...
SubOperator Posted September 7, 2019 Share Posted September 7, 2019 (edited) Okay I might just put in a cold air then exhaust the some cosmetics. Stock intake is already CAI, a washable oiled air filter may give you couple more ponies but that's it power wise. Spend money of suspension, most noticeable difference comes from having aftermarket or JDM RSB and Tribeca's FSB installed. All combined will be around $500-$600 at most and will change the car dramatically. Edited September 7, 2019 by SubOperator 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
SubOperator Posted September 7, 2019 Share Posted September 7, 2019 Staged for tomorrow's fun, and got the windage tray, oil pickup and oilpan installed on the Type RA shortblock so the RTV can set up overnight. Let's see if I can get away with using 90 minute RTV on the forward cam caps... Ah, I am almost jelauos... Spunky clean new SB. Wish I had a garage that big. Good luck with rebuild! 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
awfulwaffle Posted September 8, 2019 Share Posted September 8, 2019 (edited) Ah, I am almost jelauos... Spunky clean new SB. Wish I had a garage that big. Good luck with rebuild! Thanks! I wish I had a garage that big too - that's a DIY shop where I rent a stall. Ever since I moved to Michigan I've lived in an apartment, and this place has been wonderful. Shameless plug - they're called My Mechanics Place if anyone in the Detroit metro area hasn't heard of them. Great folks providing an awesome service to the community. Edited September 8, 2019 by awfulwaffle Link to comment Share on other sites More sharing options...
awfulwaffle Posted September 8, 2019 Share Posted September 8, 2019 (edited) Made some decent progress, though I was hoping to have the motor in the car today. Pics are at 9 am (well actually 9 pm when I left the shop last night) and 9 pm tonight. Plenty more taken for eventual population into the build thread. I also discovered the single incompatibility between the LGT EJ255 and the STI Type RA EJ257 - the mounting boss for the coolant hardline to the oil cooler. Nothing a hammer to the bracket on the hardline couldn't fix. All in all, not too bad! Also, neighboring stall was pretty rad. Edited September 8, 2019 by awfulwaffle Link to comment Share on other sites More sharing options...
Gex Posted September 8, 2019 Share Posted September 8, 2019 Getting the wagon put together for West Coast Subaru show. Finally put on my rebuilt/painted Brembo calipers along with new pads/rotors and a fresh bleed with some Motul 600. Also put a new grill on the car and got the double din all sorted. Going to 3 step polish it tomorrow. Should be looking good. Have some satin black vinyl on the way to wrap the console pieces so it all matches. Link to comment Share on other sites More sharing options...
SubOperator Posted September 8, 2019 Share Posted September 8, 2019 My clutch pedal rubber cover got worn out. Subaru quality is no good, what, only 14 years and 226K miles before it wears out? /S Might have to splurge for STi pedal covers set. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
rhino6303 Posted September 8, 2019 Share Posted September 8, 2019 I also discovered the single incompatibility between the LGT EJ255 and the STI Type RA EJ257 - the mounting boss for the coolant hardline to the oil cooler. Nothing a hammer to the bracket on the hardline couldn't fix. All in all, not too bad! I didn't have any incompatibilities with my RA shortblock. I have the first run from 2018 vehicles. I doubt there was an update though. What year LGT? Maybe the coolant hardlines were different for different years. Link to comment Share on other sites More sharing options...
Enlight Posted September 8, 2019 Share Posted September 8, 2019 Applied three coats of DEI's Hi Temp Silicone paint to my wrapped header, uppipe, and downpipe, curing each coat over my grill. Also primed the motor that has been sitting for almost two years now. Car had an Err 55 which I hope will go away on its own - the wheel sensors look to be in fine condition. All I have to do now is install all the exhaust from the turbo back, install the intercooler, and put the wheels back on. Hard for me to believe that everything is done - I feel like I must be forgetting something. muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
solidxsnake Posted September 8, 2019 Share Posted September 8, 2019 I didn't have any incompatibilities with my RA shortblock. I have the first run from 2018 vehicles. I doubt there was an update though. What year LGT? Maybe the coolant hardlines were different for different years. I believe that is the case between the '05-'06 and '07+ MYs. Today, I learned what regret feels like. Now I'm ready for your boat, awfulwaffle Compression test on cyl 1 and 3 returned 120psi, cyl 2 and 4 was 60 and 65psi I suppose I should re-check the timing, but I doubt I screwed that up. Also worth checking the OCVs I guess? Link to comment Share on other sites More sharing options...
awfulwaffle Posted September 8, 2019 Share Posted September 8, 2019 (edited) I didn't have any incompatibilities with my RA shortblock. I have the first run from 2018 vehicles. I doubt there was an update though. What year LGT? Maybe the coolant hardlines were different for different years. I'm a dumb dumb - realized today that it was a difference in oil pump casting, as that's where the mounting point is. I used the STI P/N pump. Got it in the car, primed and started today. Massive vacuum leak somewhere that I need to track down. But, all the fluids stayed where they should and I had good oil pressure. It's getting there. Edited September 8, 2019 by awfulwaffle Link to comment Share on other sites More sharing options...
awfulwaffle Posted September 8, 2019 Share Posted September 8, 2019 I believe that is the case between the '05-'06 and '07+ MYs. Today, I learned what regret feels like. Now I'm ready for your boat, awfulwaffle Compression test on cyl 1 and 3 returned 120psi, cyl 2 and 4 was 60 and 65psi I suppose I should re-check the timing, but I doubt I screwed that up. Also worth checking the OCVs I guess? Oof that would certainly do it. Are the OCVs even active during cranking? Link to comment Share on other sites More sharing options...
08legacygtturbo Posted September 9, 2019 Share Posted September 9, 2019 08 legacy GT limited EJ255 2.5 turbo 5eat I installed my 2.4"/3" Perrin turbo inlet intake hose and my New Tomei ARMS MX7960F turbo And my NTK front O2/AFR sensor Trying to add pics but it just says failed or invalid on all my pics does it not allow 4K quality pics ? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 9, 2019 Share Posted September 9, 2019 08 legacy GT limited EJ255 2.5 turbo 5eat I installed my 2.4"/3" Perrin turbo inlet intake hose and my New Tomei ARMS MX7960F turbo And my NTK front O2/AFR sensor Trying to add pics but it just says failed or invalid on all my pics does it not allow 4K quality pics ? You need to log out of the site and then log back in to fix that. You log out from the Home page upper left side under....your avatar area....you'll see a logout link. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
